Quantcast How do I take the doors off of my '94 Jeep Wrangler? - JeepForum.com
Go Back JeepForum.com > General > General Discussion > How do I take the doors off of my '94 Jeep Wrangler?
Old 06-10-2001, 07:42 PM   #1
rstube
Guest
Posts: n/a
Can anyone help me?
Old 06-10-2001, 08:51 PM   #2
bluebellyday
You should find this easy.
If the doors have never been removed you will find a nut on the bottem of each hinge pin. you will need to remove these. 2 per side.
If you have full doors Warning they are heavy. I like to open the door,roll down my window and reach through the window opening this way I know if I slip the door will catch on my sholder.
Grab the door somewhere near the hinge end. You will now need to pull upward as you work the door back and forth on the hinge. Once you work them free find a safe place to put then Doors are often stolen.
you can set then on an old piece of carpet or buy a special hanger just foor doors.
careful not to scratch them. More damage is done off the Jeep than on.
once they are off check out my post in the YJ section for Harley motorcycle footpegs that will mount on the lower hinge of Yj's and Cj's
bluebellyday is offline   Reply With Quote
Old 06-20-2001, 10:53 PM   #3
thumper
Hey buddy.
Allright if your short standing on a step ladder may help in the leverage factor .
Okay next step undo the bolts set in a very safe place,like a zippy bag and staple it to the wall of you garage door.
second, if its stuck get some silicone lubricant ( no ky, tried that didnt work)
and spray into it best us you can.
Get your shoulder under the top window frame on a full door other grab the bottom and EVENLY pull not yank upwards.
if that dosent work get someone named moose or bubba to help.
dont forget to grease up the fastner rod thing that goes into the two holes though, you will find the passenger door a witch to get off if you dont.
Thumper
Stop all this silliness stop it I say!! And now for something completely different.
thumper is offline   Reply With Quote
Old 06-23-2001, 10:15 AM   #4
Tonka
my full doors took me almost a week to remove(trying about twice a day) once you get the doors off, sand the rust off of the pins, and coat them with some white lithium grease.
Take off the door stop straps and while evenly pulling up, walk the door to the front of the jeep then back to the near closed position. Repeat about 500 times per door(estimate) and they should come off. the second time will be alot easier.
98 TJ
90 MJ short bed converted to 4x4
90 XJ 2 dr 4x4
Tonka is offline   Reply With Quote
Old 08-16-2001, 06:18 PM   #5
Big Blue
I know how to take my doors off on my '90 wrangler, but I have a sound bar and the light stays on when I take the doors off. I don't know how to make the light stay off!!!
Please help.
'90 Jeep YJ, 4.2 L Inline 6, Dana 30's in front and 44's in back, Blue with Grey soft top.
Keep Jeepin'
Big Blue
Big Blue is offline   Reply With Quote
Old 08-16-2001, 06:46 PM   #6
OhYeah
I think the easiest way to keep the light off is to disconnect the push connecter right at the door. That way when you put them back on it is easy to reconnect. It is just a wire connecter on the back side of the door frame. Take a look...it is easy to find.
91 YJ, 4 banger, 3" Rough Country, 3" body lift, 31X10.5 BFG KO's on 15X10 bajas, K&N, restrictor removed.
O_O_O_O
o-I_ ___ _ I-o
(O IIIII O)
[_ O__O _ ]
{{}}}--o-{{{}}
OoOoOoooOOOoOOO
(oO0O(oOo)0o0O0o()o
OhYeah is offline   Reply With Quote
Old 08-17-2001, 08:51 PM   #7
mrInfinit
Guest
Posts: n/a
I think the easiest way to disable the light on the sound bar would be to pull the fuse; the fuse box is located behind the glove box, just take out the glove box and pull out the fuse (its the one labelled DoorSw Defeat , the very last fuse)
Old 06-03-2009, 02:18 AM   #8
94YJTech
The nuts at the bottom of the hinges are rounded and I cant get a good grip on them, any help ?
94YJTech is offline   Reply With Quote
Old 06-03-2009, 02:41 AM   #9
EJames1226
Damage Initiation Specialist: Eric's Jeep Repair Club, San Diego Chapter
EJames1226 is offline   Reply With Quote
Old 06-03-2009, 02:54 AM   #10
corndogduff
feelin a little nostalgic are we?
Duff.
[COLOR="Silver"]98 ZJ 5.9[/COLOR]
[COLOR="Green"]96 ZJ Laredo[/COLOR]
[URL="http://www.jeepforum.com/forum/groups/utah-jeepcrew/"]UT Jeepcrew #13[/URL]
[QUOTE=southerngirl]McDuff ftw[/QUOTE]
[SIZE="5"][URL="www.nightcrew.org"]NIGHTCREW[/URL][/SIZE]
corndogduff is offline   Reply With Quote
Old 06-03-2009, 02:57 AM   #11
EJames1226
Without valuable, helpful threads like this, jeepforum would just be a forum where people talk about politics and gas prices. Hooray for bringing up old important threads.
Old 06-03-2009, 02:58 AM   #12
corndogduff
very true, very true!
huzzah for old threads with good info!!!!
Duff.
Old 06-03-2009, 04:11 AM   #13
CMARJEEP
Ahhh. Memories of JF as a young child.
-Connor KI6TMX
www.norcaljeepers.co
CMARJEEP is offline   Reply With Quote
Old 06-03-2009, 06:18 AM   #14
jeepdavetj
jeepdavetj's Avatar
1991 XJ Cherokee
So thats why my doors have threads on them.................................
I don't blame people for their mistakes, but I do expect they pay for them.
Ash from Army of Darkness
Alright you Primitive Screwheads, listen up! You see this? This... is my boomstick! The twelve-gauge double-barreled Remington. S-Mart's top of the line. You can find this in the sporting goods department. That's right, this sweet baby was made in Grand Rapids, Michigan. Retails for about a hundred and nine, ninety five. It's got a walnut stock, cobalt blue steel, and a hair trigger. That's right. Shop smart. Shop S-Mart. You got that?
jeepdavetj is offline   Reply With Quote
Old 06-03-2009, 07:04 AM   #15
ionakana
Grand Poobah
ionakana's Avatar
sawzall maybe
"Is America ready for a real leader not just a reader?." _ Herman Cain
http://www.oddhammer.com/tutorials/debt_clock/US_debt_clock.swf
Live in Georgia? click here--> http://georgiacrawlers.com/
ionakana is offline   Reply With Quote
Glock Forum
