High temp grease means high temp grease
| Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line | GR8TOPS Introduces the Exogate HD Tire Carrier | The Original 3/8" Ruffstuff Diff Cover! |
#1 | |
Im an idiot. 3 weeks ago I replaced the clutch in my s10. The throwout bearing was shot so I did everything. I was almost positive that the grease in my gun was high temp. Today I found out it wasnt. The TO bearing started squealing while I was in spokane, I got home 2 hours later, parked in the driveway, went in to change and when I came out, the clutch wouldnt move. It took me 3 hours to free it up and grease it through the clutch fork dust cover.
So, dont be like me, make sure that **** is high temp.
#2 |
I tend to learn best from experience as well. Glad to hear you were able to fix it.
#3 |
Pull fuse #4 !!!!!!!
Couple the need for High temp grease along with having to weigh a specific amount to the gram. Have to use this method on high speed spindles, too much or too little causes the spindle to overheat and lockup. Pain in the ***.
BTW Bender.........CONGRATS ON YOUR COUSIN GETTING DRAFTED!!!!!!
'99 Gun Metal Blue TJ 5 spd Manual 31x10.50 BFG KO's 2" Tereflex lift, Rancho Steering Stablizer Mauser K98 (1941),K31(early 50's), Mosin-Nagant M44 (1946), BUL Impact .45, Ruger Mark2, CZ-50, Marlin .22, Winchester.22 Low Output 4-Cylinder Jeep Club #50 "Dyslexia for cure found" |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
