Help me with how to tow my jeep - JeepForum.com
Go Back JeepForum.com > General > General Discussion > Help me with how to tow my jeep
RuffStuff Memorial Day Sale!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineBuild your Dream Jeep with Poison Spyder's Interactive Gar
Unread 06-03-2007, 05:06 PM   #1
Red_Ak_Ranger
So I sorta want to drag my Jeep back to Alaska with me. It's something like 2500 miles drive. I don't know about towing a 4WD vehicle but Grewe told me to buy a towbar.
So here's my questions.
1) Where do I buy a towbar? I'm in Minneapolis and if anybody knows where I should look, I'd like to get one tomorrow(I need to tow the jeep to a storage unit).
...I'll figure out how to attach it to the jeep. I have a slightly aftermarket bumper. After****typieceofcrapmarket.
2) My Jeep is a CJ7 with A dana 300 Tcase and turbo400 tranny. What position do I need the tcase in?
3) Should I take out the rear driveshaft or front driveshaft? I'm not really interested in doing that.
Thanks, Aaron
Red_Ak_Ranger is offline   Reply With Quote
Unread 06-03-2007, 06:19 PM   #2
drummerwookie
Thanks, Aaron
im not from around that area, but any where that sells trailers should have them, or maybe even a Tractor Supply or something
im assuming you have lock out hubs on your CJ, so just make sure they arent engaged, and so your front shaft wont even matter then anyways, but really just put the T-case in neutral and your should be set anyways
1993 YJ 4.0, 5-spd, 31x10.5 MTRs wrapped around AR Outlaw II's, tabor 9k winch, 4 inch trailmaster lift
gone, but never forgotten: 2006 rubicon, 1998 ZJ, 1995 YJ 4.0
metalhead jeep club #4
drummerwookie is offline   Reply With Quote
Unread 06-03-2007, 06:29 PM   #3
dyna
I towed my 78 CJ-5 around a bunch using a towbar attached to the front bumper. You can double plate the attach points if needed or I think you can also buy "tow shackles" where the tow bar will attach directly to them. I had welded one up for but the same type can be had from various jeep places for about $150 or so. If I recall I pulled the rear DS and made sure the hubs were unlocked. If I recall flat towing with a auto case would damage the rear output bearing etc, but even with the pulled DS I ran the TC in neutral and the trans in gear so oil drag wouldent spin things. Dont forget to unlock your steering also if it has it by putting the key on the first click. have a look at Tomken machine they offer tow bars and shackles so you can get an idea of what there is out there.
Good luck, enjoy Alaska.
dyna is offline   Reply With Quote
Unread 06-03-2007, 06:35 PM   #4
Jerry Bransford
Do it right or not at all
Jerry Bransford's Avatar
You'll need the "paddle wheel" modification to your Dana 300 before you can flat tow your CJ unless you disconnect the front and rear axleshafts. That mod welds oil splashing paddles to the output shaft to keep the bearings lubed.
Jerry's Geezer Jeep II Website
Getting Savvy...
Coolest offroad magazine ever! CRAWL Magazine
Jerry Bransford is offline   Reply With Quote
Unread 06-03-2007, 06:59 PM   #5
Camo Deere
What happened to the good ol' duct tape and nylon rope?
Camo Deere is offline   Reply With Quote
Unread 06-03-2007, 11:39 PM   #6
Trouble Maker
Trouble Maker's Avatar
Yep, one of the drawbacks of the 300.
Russ
02 Dakota Quad Cab 4.7 5 spd
93 ZJ Stolen and wrecked Mar29/08
Trouble Maker is offline   Reply With Quote
Unread 06-04-2007, 08:52 AM   #7
mdm
Farm Wheeler
If you haven't made that drive before you need to protect the front of your CJ. Towed vehicles get beaten up pretty bad if not protected. Rock rash is very bad, broken head lights and windshields are normal.
mdm is offline   Reply With Quote
Unread 06-04-2007, 09:16 AM   #8
Red_Ak_Ranger
Okay I'll remember that. Protect the front end. Luckily I don't have a front windshield!
