HELP! Jeep high centered in mud 2 miles into forest! - Page 4 - JeepForum.com
post #46 of 84 Old 06-05-2012, 12:03 AM Thread Starter
pbuchanan
Here's the pics:
pbuchanan is offline
post #47 of 84 Old 06-05-2012, 12:18 AM
jumbojeepman
1976 CJ7
Looks really similar to the Croatan National Forest in eastern NC, which is a layer of soil a couple of feet thick on top of a bottomless peat bog. Break through the surface, and you've got real problems. Croatan mean shaking earth in the local Native American language.
Couple of suggestions, I was able to pull my truck that wasn't quite as buried as yours by wrapping a tow strap around several bushes, and then using a high lift jack as a winch. A group of bushes actually has a stronger root system than the trees, as I pulled a couple of those right out of the ground. The burying a log trick doesn't work in this terrain because the ground gets softer rather than harder when you dig down.
Only other thing to do is jack it up and keep throwing logs under it. Or find someone with a bigger truck and very wide tires than can make it there and pull you out. As you have discovered standard Mud terrains are doing you absolutely no good, you need Swampers, or if this is your normal terrain to go wheelin' go back to all terrains, you won't bury yourself as quick.
jumbojeepman is offline
post #48 of 84 Old 06-05-2012, 12:49 AM
JFranko
Originally Posted by Budke View Post
whoops, only one zero, did mean to put 200k. lol
Yeah, the only reason I know is because my dream is to someday own one. And hopefully be able to grow a handlebar mustache. I have seen them go for over a million though depending on the year and hours. Flying ain't cheap I guess
Originally Posted by mopar408 View Post
he could get it out for you:
Sorry to all you Jeep Forum old-timers but I just couldn't resist...........
1992 YJ Wrangler 4.0L, NV3550, 2.5" suspension lift, 32" BFG M/Ts, lots of other cool stuff
RED JEEP CLUB MEMBER #494
JFranko is offline
post #49 of 84 Old 06-05-2012, 06:42 AM
rasbutan
2016 JK Wrangler
So did you get it out?
rasbutan is offline
post #50 of 84 Old 06-05-2012, 08:01 AM
Wintermute
1967 FSJ Gladiator
heck, I'd personally go back with a chainsaw and start cutting down those bushes that are all around you and laying them down like bog mats. Once I had a good mat behind and mostly under the jeep, I'd lay down some sections of 2x8 on top of the mat to give a hi-lift a base to jack off of. Then while the jeep was up I'd pile more matting under the tires. Keep going from there. I bet it's gonna take you a while though (especially if you have to mat the trail all the way back out).
--Wintermute
"No man's knowledge here can go beyond his experience." - John Locke
"Vi Et Armis" - Cicero
Wintermute is offline
post #51 of 84 Old 06-05-2012, 08:12 AM
jchappy
2011 JK Wrangler
Find a buddy that has some trailer ramps and shove them under your tires, drop your air pressure to 12lbs
Be sure your lockers are engaged and start shoving thing under the tires
MY NEW JEEP- 2011 JEEP JKUR, Body Armor front bumper, Warn XD9000I winch, Synthetic winch line,XRC Rear Bumper W/Tire carrier, OBA W/1Gal Tank, Terafex 2.5in spring lift, Bilstein 5100 shocks,GY 315/70R17 Duratracs, 4.88 G2 gears, Cobra 75 CB
MY OLD JEEP-1999 Wrangler Sport 4.0L, 4" Pro Comp Lift, 33" BFG's, 8K winch, SYE, Viking soft top, onboard CO2 and all the recovery straps and equipment
jchappy is offline
post #52 of 84 Old 06-05-2012, 08:42 AM
jeepwhore
Originally Posted by kg4kzv View Post
Mud can suck literally so why is it so addictive to play in!!!!!
For me, it's not anymore. After enough multi-miled midnight walks out of the bush I realized that if I didn't have the money to afford proper recovery gear I should find a different wheeling interest. I can afford the gear now but the excessive clean up and maintenance time from being submerged in muck has stripped the appeal.
I like trail riding and more diverse terrain. I get more satisfaction out of testing my Jeeps abilities to navigate obstacles rather than trying to get across a mud pit with the pedal down approach.
Originally Posted by pbuchanan View Post
Yep hindsight is 20/20 that's for sure!
Don't feel bad, you aren't the first and won't be the last it happens to, especially in ft. mac. If I lived up here I would own a quad before I owned a jeep.
Better pick up some OT shifts so you can have both!
'84 CJ-7: Yota axles (spartan locked front, e-locked rear) 4" BDS, 1" Daystar & 3/8" shackle lifts, 35" X-Terrains on steelies, YJ Tub & family roll bar, heater blower upgrade, 4.2L w/MC2100 & Team Rush, Warn 8274. Rebuilt 4.2/4.0 hybrid, AX15 and twin sticks/clocking ring waiting to go in.
The advertised position for a topless, dirty jeep girl has been filled......by my wife. Thanks to all that applied.
<------------and yes, that is her.
:-D
jeepwhore is offline
post #53 of 84 Old 06-05-2012, 10:53 AM
dwbrown
2014 JK Wrangler
At least you're not stuck in the ocean, had high tide come in and your vehicle end up being stuck 20 feet out in salt water. This picture is after we pulled it from the water.
USAF
dwbrown is offline
post #54 of 84 Old 06-05-2012, 02:19 PM
Imped
Imped's Avatar
Lesson:
Open diffs are for the road.
OlllllllO
IndyORV
Imped is online now
post #55 of 84 Old 06-05-2012, 02:23 PM
ChrisHager
Administrator
ChrisHager's Avatar
Isn't that a Rubicon in the pic?
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift -
His: 1979 J-10 - 3" on 33s -
His: 2009 Expedition
His: 1978 F250 Custom -
Hers: 2000 TJ
Hers: 2010 Jetta
Originally Posted by Matt
"You can't recycle tartar sauce."
ChrisHager is offline
post #56 of 84 Old 06-05-2012, 03:02 PM
dwbrown
2014 JK Wrangler
Lesson:
USAF
dwbrown is offline
post #57 of 84 Old 06-07-2012, 08:44 AM
Bigraab72
Well, any news yet? Did you get it to budge?
Bigraab72 is offline
post #58 of 84 Old 06-07-2012, 12:38 PM
jeepwhore
If you're still marooned PM me your #. My cousin said he'll get it out of there for $200. If you're still stuck that sounds like a good deal to me!
He's on night shift tonight but then he's off for 5 days so he could do it this weekend.
:-D
post #59 of 84 Old 06-07-2012, 12:51 PM
Jeff88
I heard Vex was on his way, but he is in China, so it will take a little while.
Jeff88 is offline
post #60 of 84 Old 06-07-2012, 12:53 PM
Imped
Imped's Avatar
Damnit.
Well then, mud sucks.
OlllllllO
IndyORV
Imped is online now
high lift , mud , mudding , stuck , wrangler
High Centered Gr8_Outdoorsman General Discussion 14 04-03-2012 12:51 AM
Obama Limo gets High Centered in Ireland jerryjeeper Politics, Religion & Controversy 13 05-24-2011 01:55 PM
$8000 for a 1997 Jeep 4.0 w/ 100k Miles-Why So High!!! 01TJfuntime General Discussion 38 11-30-2007 09:13 AM
High Centered! swamp_rat General Discussion 5 09-28-2003 07:54 PM
4.0, High Miles? bt24drexel General Discussion 6 12-02-2001 07:22 PM
