HELP! Jeep high centered in mud 2 miles into forest! - Page 3 - JeepForum.com
post #31 of 84 Old 06-04-2012, 05:21 PM
muddr1
X2 on the winch and snatch block, maybe try 2 snatch blocks, Itll be slow going but should do the trick, might have to anchor the winch vehicle to a tree..
If we knew what we were doing it woulnt be called research
Albert Einstein
There are no rules here, were trying to accomplish something.
Thomas Edison Keep Calm,Chive On
muddr1 is offline
post #32 of 84 Old 06-04-2012, 05:42 PM
Foundrydude
High lift jack and wood/something under the tires. Once it's perched, hook up a line and have another truck give a WOT tug to assist in your mud-drag style exit from the hole. They are messy to clean up afterward but pallets work fairly well.
It would be best to include plan B and C in your preparations, which may include a winch or even a large comealong and enough chain to reach a large tree. Previously mentioned high lift will double as a winch. A couple shovels would be a plus.
Maybe even pack for plan D, camping overnight.
good luck.
Foundrydude is offline
post #33 of 84 Old 06-04-2012, 05:52 PM
Max-Q
1983 CJ7
I'd go buy a good 10,000 lb winch some straps, D rings and two snatch blocks and get to work.
1997 Jeep TJ
1983 Jeep CJ7
2011 JK Unlimited Rubicon
Max-Q is offline
post #34 of 84 Old 06-04-2012, 06:59 PM
mopar408
1974 CJ5
he could get it out for you:
Sorry to all you Jeep Forum old-timers but I just couldn't resist...........
If it's good TO you, it's gotta be good FOR you....
mopar408 is offline
post #35 of 84 Old 06-04-2012, 09:02 PM
roadhog304
1973 CJ5
Not Vex. Come on man did you have to go there? seriously?
roadhog304 is offline
post #36 of 84 Old 06-04-2012, 09:05 PM
jeepwhore
good luck.
Biggest problem there is this **** is so soft as soon as the tow rig starts feeling resistance it'll sink to the axles as well.
Muskeg is a no win situation.
Most times I've seen guys buried in 'skeg it's in something like this:
No trees close enough and even if there are, it's a rarity to find one big enough that will actually hold a truck back. Lots of black spruce and jack pine pecker poles. Those *******es are lucky that tower was there or that chevy would still be there. But again, stock vehicle + muskeg = FAIL!!!
I'm hoping the OP isn't as big a retard as the guys in the video.....no wonder we canadians get stereotyped. Not sure why he insists on holding a can of budlight in the shot.....
'84 CJ-17: 17" stretch, locked Toy axles, 5.5" lift, FI, AX15, D300 w/twin sticks, boatsides & junk.
jeepwhore is offline
post #37 of 84 Old 06-04-2012, 09:23 PM
BassMasterCHS
1993 XJ Cherokee
I assumed the beer was for celebration haha.
3 Inch lift, 30" BFG AT's, Walmart lights up front.
BassMasterCHS is offline
post #38 of 84 Old 06-04-2012, 09:33 PM
kg4kzv
1995 XJ Cherokee
I have seen people dig a big hole wrap some rope or cable around a big log toss it in the hole and bury it then using it as an anchor to winch from. Seemed to work real good as long as you get it down deep enough.
Chris
95 Cherokee SE 4.0, 5-Spd, 8.25;
6.5" Rusty's Lift, Atlas II Rims, 35x12.5x15 Wild Country,Rusty's Tube Bumper, Wilderness Rack
Rock Sliders, K&N Panel Air filter, PSC steering box,
I-ROK reinforcement kit, ORO U-TURN steering kit,Conversion Headlights/Silverstars And too much $$$
kg4kzv is offline
post #39 of 84 Old 06-04-2012, 09:37 PM
BassMasterCHS
1993 XJ Cherokee
Somewhere on here I've seen a guide from the military on how to recover stuck vehicles...
post #40 of 84 Old 06-04-2012, 09:45 PM
jeepwhore
Chris
In this **** you would need to dig down anywhere from 4' and beyond.
Think of a 12" mat of swamp grass floating on a bottomless lake of muddy slimey, watery, jello. Once you break through it's pure loon **** underneath. Pieces of equipment (excavator, dozer etc.) have sunk clear out of sight before hitting bottom. There's just no substance to it so even doing like you suggest there is no "meat" to hold the log back.
When there is nothing to hook to it typically takes a few rigs chained together on a spot that hasn't been driven on yet. And without a alot of horsepower, a lift and some big tires progress usually comes 5 feet at a time.
post #41 of 84 Old 06-04-2012, 09:56 PM
Red93yj
2011 JK Wrangler
pics please any ways jack it up and throw some logs under it. you may be able to jack it up just enough to get it un high centered but where the tires are still on the ground and have another rig give you a tug. with high lift jacks so they just fall.
Red93yj is offline
post #42 of 84 Old 06-04-2012, 09:57 PM
BassMasterCHS
1993 XJ Cherokee
Swamp grass... On top of a watery pit...
post #43 of 84 Old 06-04-2012, 10:25 PM
kg4kzv
1995 XJ Cherokee
Been there done that burned the ___ t-shirt!!!!
I once lived next to a swamp in SC. We had just gotten the lot and after a big rainfall we went out to plan how to put everything on the property. I had a 2wd Ramcharger and found out how bad this place was going to be to get in and out of till a driveway could be put in.
The Ram got stuck fast being 2wd and me trying to drive slow but the worse was yet to come. We watched as the truck sit there not running sink until you could not open the doors!!!!
Neighbor came over with his big tractor and it sunk as he was trying to get around me to hook up to the front.
Then we called a guy with a 4wd dully rollback. He backed up on the pavement then turned it lose. That thing danced over the mud like one of those mudpit drag buggies till he hit a little higher ground.
He hooked up his wench to my Ram and started winching but it just pulled his wrecker back. Then he tilled the deck back and into the ground. It still pulled his wrecker back around 8ft the rollback deck acting like a bulldozer. Then finely the dodge was getting pulled to the higher ground.( I still think it was stretched 3") Only one problem we then needed to get back to the road.
We could not risk turning around. So the wrecker driver told me to stand on it in reverse try to miss the big hole and the stuck tractor. I did and it was scary but I had enough speed to carry it through.
Then it was his turn and I have never seen so much mud flying high into the sky as I did that day. His wrecker slipped over into the hole we just pulled my truck out of. He never stopped completely just slowed him way down.
The neighbor's tractor could not be pulled out and had to sit there for a week till things dried out then it took 2 days to dig it free!!!
Mud can suck literally so why is it so addictive to play in!!!!!
kg4kzv is offline
post #44 of 84 Old 06-04-2012, 11:13 PM
dandug001
There was a "Dirty Jobs" episode where they got a hummer stuck and ran ropes back and forth using pulleys and were able to pull it out with just a bunch of army guys.
dandug001 is offline
post #45 of 84 Old 06-04-2012, 11:49 PM Thread Starter
pbuchanan
Not taking a bone stock rubicon into the muskeg with no other rigs with winches would have done the trick too!
Yep hindsight is 20/20 that's for sure!
pbuchanan is offline
high lift , mud , mudding , stuck , wrangler
High Centered Gr8_Outdoorsman General Discussion 14 04-03-2012 12:51 AM
Obama Limo gets High Centered in Ireland jerryjeeper Politics, Religion & Controversy 13 05-24-2011 01:55 PM
$8000 for a 1997 Jeep 4.0 w/ 100k Miles-Why So High!!! 01TJfuntime General Discussion 38 11-30-2007 09:13 AM
High Centered! swamp_rat General Discussion 5 09-28-2003 07:54 PM
4.0, High Miles? bt24drexel General Discussion 6 12-02-2001 07:22 PM
