Has anyone made tire chains? - JeepForum.com
post #1 of 12 Old 11-23-2009, 05:37 AM Thread Starter
ArrizX
Just curious.
I am building an old Nissan truck with dual transfercases, 38s and tons. 38s are well used, but still have tread. However for a trail only rig and for the wicked ice sheets we get on trails here, I talked to my friends about literally making permanent chains for the tires.
I don't know how, but all I have thought of doing is just welding all the links solid. I cant afford chains or tires anytime soon so this is really the next best thing.
What do we think about this?
ArrizX is offline
post #2 of 12 Old 11-23-2009, 10:52 PM Thread Starter
ArrizX
upppppppppppppp
ArrizX is offline
post #3 of 12 Old 11-23-2009, 11:25 PM
Hoobly_Goob
If it's not going on the road, I know some people that ride motorcycles on ice put studs in the tires.
"You're out of your mind."
"That's between me and my mind."
Hoobly_Goob is offline
post #4 of 12 Old 11-23-2009, 11:55 PM
Comanche_
you can make them just buy heavy chain, and if you make them, you can design the best patten.
Originally Posted by Z0NAJEEP View Post
With more stupid comments? Two retards don't make a right.
Comanche_ is offline
post #5 of 12 Old 11-24-2009, 12:02 AM Thread Starter
ArrizX
Kinda what I figured.
Anyone have tips?
ArrizX is offline
post #6 of 12 Old 11-24-2009, 02:46 AM
CMARJEEP
CMARJEEP's Avatar
I would not weld the links together. They would probably just break apart again anyway. If you are going to make your own though you want to make them as tight to the tire as possible with no play whatsoever. Maybe fab up some kind of tensioner. Like an upgraded version of those big "rubberbands" they use on regular store bought chains.
CMARJEEP is offline
post #7 of 12 Old 11-24-2009, 08:12 AM
Divinitous
Disgruntled Jeepforum'er
Divinitous's Avatar
I would suggest doing studs. Maybe a 1/4 nut/bolt with fender washers on the inside and a smaller washer on the outside. Chop the bolt off at the nut and carry some tire patches/air source in case you lose one and get a flat.
I'm sure you'll be able to turn on a dime. I used to do this on my mountain bike during the winter. It was pretty cool to be able to haul *** across a frozen lake.
http://www.wrxtuners.com/forums/f53/...s-death-22365/
I had a friend whos front tires fell into the ice and couldnt get the grip to back out. The tires worked their way down to below the ice line. It took three winches and a good amount of time to get him free. The results were a ripped off bumper, bent frame, and a few angry Paragon employees that were kept late.
-Ryan
Google Voice (or the number Grape calls when drunk): 845-476-8182
Originally Posted by Enzo Ferrari
"The Jeep is Americas only real sports car!"
Originally Posted by MrBlaine
"Jeeps do not make jeepers, jeepers make Jeeps."
Divinitous is offline
post #8 of 12 Old 11-24-2009, 08:12 AM
PDX_XJ
PDX_XJ's Avatar
Why? You've got a tensioner already! Air down, put the tires on, air back up. (Just kidding, I know how diameter works)
I saw some home-made chains last year. They were done with those screw-open chain links, rather than welds:
He kept his tight with those black molded rubber bungee cords, but you could also use any chain tightener.
  • Armor's Axiom: Virtue is the failure to achieve vice.
  • The sooner you fall behind, the more time you have to catch up.
PDX_XJ is offline
post #9 of 12 Old 11-24-2009, 10:32 AM Thread Starter
ArrizX
studded tires of death - Subaru WRX Forum: WRX Forums
Those spikes are freaking nuts!
Thats a great idea!
Although, they look fragile just getting the truck on and off a trailer.
I think I want something more removeable, but thats intense and would work great with tubes.
ArrizX is offline
post #10 of 12 Old 11-24-2009, 10:59 AM
Chris
Guy with jeep
Chris's Avatar
I made a set for some 38's I had on a Dodge truck and used those screw chain links and the only issue I had was a couple of them came uncrewed and fell off but other than that they worked great and I beat the living heck out of them. I cheated thow I started with a smaller set of chains and just added to them but even from scratch they are easy to do but do get expensive with all the parts.
Chris is offline
post #11 of 12 Old 11-23-2013, 06:23 PM
Mykul
Has anyone actually done this (bolts through the tread)? I'm thinking of doing this or something similar with chains bolted across the tread, with my SRA's after I'm done with them.
Mykul is offline
post #12 of 12 Old 11-25-2013, 10:08 AM
tymbom
Why try and reinvent the wheel? Get some semi truck tire chains. I had a set for my truck when I had 40s on it. They were about the right diameter, so you would only have shorten the ends a little...
Jonathan Baty 1954 M38a1 with 400sbc, T18, Dana 20, Dana 30, Dana 44 and 37in Coopers. 1986 M1008 w/37in Toyos and stuff
1984 M1008 parts truck, 1983 Chevy Crew Cab, 1973 Ferd Bronco, 2004 Cadillac CTS-V, 1948 CJ-2a sorta
tymbom is offline
Tire Chains? Otahyoni General Discussion 3 01-08-2010 07:41 PM
tire chains/cables for the bad days JeepTransformer General Discussion 3 10-12-2009 01:34 PM
Where can I have a vinyl sticker design i made..made? HeavyMetal General Discussion 6 04-13-2005 08:03 AM
Picts of my tire carrier and bumper- Jim79cj7 made from scratch CETROV General Discussion 3 01-08-2003 09:17 AM
Chains? Atropine General Discussion 2 12-09-2001 08:34 PM
