Had a thought...yes it hurts sometimes... - JeepForum.com
post #1 of 8 Old 01-07-2010, 01:41 PM Thread Starter
Contra
i have an extra compressor in my garage at home, (as i use my large belt compressor for home use)
it is a 110volt 15 amp 1.5hp, 2.5 gallon
i was thinking about putting it in my jeep for OBA, but I wanted to hard wire it and not have to use an inverter, can i re-wire the compressor to make it DC some how?
it is fairly new and if i can seperate the tank it would be a great addition...
Ever Gone Geocaching?
Contra is offline
post #2 of 8 Old 01-07-2010, 02:53 PM
93jeepyj
You would have to find a dc motor and controls for it but its not impossible.
93jeepyj is offline
post #3 of 8 Old 01-07-2010, 03:12 PM
Indy
Indy's Avatar
Going back to electrical, and it's a long way back so forgive me if I do the math wrong. But at full load the AC compressor is going to use 1650 Watts of power. To do the same with a 12v system you need to be able to provide continuous 137.5 amps. That's a lot
Indy is offline
post #4 of 8 Old 01-07-2010, 03:30 PM Thread Starter
Contra
i might be wrong, but it is a 15 amp motor and that means roughtly 1800 watts right?
where do you get 137.5 amps?
i guess i will do things the easy was and get a pre built, i just wanted to use what i had
Contra is offline
post #5 of 8 Old 01-07-2010, 05:12 PM
Otahyoni
Otahyoni's Avatar
1986
Watts Law is where he got the 137.5 amps. Watts Law states P(watts)=V(volts) x I(amps).
So P= 110v x 15 amps = 1650 watts
To go to 12v you'd take P divided by V = I
So 1650/12 = I(amps) = 137.5 amps
Now there's more than you really wanted to know...
EDIT: Hey! I actually used something i learned in school!
~Chris
And all of the diodes may have committed suicide, leaving you with a fun whirly thing under the hood that produces nothing.
Otahyoni is offline
post #6 of 8 Old 01-08-2010, 02:23 AM
Indy
Indy's Avatar
Yeppers, 110v can do the same job with a lot less amperage than 12v can. You could still use the tank and get a different compressor, but I think you would be wasting an otherwise usable compressor considering you can get a 7g tank for less than $20.
Sell the compressor, use the money to buy your 12v setup.
Indy is offline
post #7 of 8 Old 01-08-2010, 10:21 AM
Mickey_D
Contra, does your Jeep have A/C? If so, does it still work?
If it has A/C and it doesn't work, why not convert to OBA?
If it doesn't have A/C why not grab the bracket and compressor from the wrecking yard and put OBA in. You can use the tank, safety valve, gauge and pressure switch from the 110V compressor. All you need is the hoses, oiler, dryer and a couple 3 way manifolds.
1997 ZJ 5.2 Orvis, Baby!
1953 Willys M100 trailer Tagalong
________________
[_][][][][][][][][_]
#4
Mickey_D is offline
post #8 of 8 Old 01-08-2010, 05:30 PM
Otahyoni
Otahyoni's Avatar
1986
Does anyone know the output on an a/c compressor? I'd bet it's really high (good thing)... I had a spare a/c compressor that had a separate oil sump so it could run for a long time without burning up...
~Chris
Otahyoni is offline
my eye hurts tail_chaser General Discussion 18 07-30-2007 06:08 PM
This One Hurts Kevin_G General Discussion 9 06-13-2007 07:46 AM
This One Hurts Kevin_G General Discussion 15 06-12-2007 10:07 AM
I want one so bad it hurts balloo93 General Discussion 19 08-25-2006 10:18 PM
My leg hurts Tinker General Discussion 20 03-02-2005 03:12 PM
