Grinding bits - JeepForum.com
post #1 of 2 Old 09-06-2001, 12:58 PM Thread Starter
OhYeah
Grinding bits
Hey there, I hear a lot of you guys and gals talk about grinding bits. Do you use these on your drill or a dremel tool or what? I need to get something to grind off a bolt head and I do not have a dremel tool. Do they sell strong grinding bits for use on your electric drill?
Thanks,
91 YJ, 4 banger, 3" Rough Country, 3" body lift, 31X10.5 BFG KO's on 15X10 bajas, K&N, restrictor removed.
O_O_O_O
o-I_ ___ _ I-o
(O IIIII O)
[_ O__O _ ]
{{}}}--o-{{{}}
OoOoOoooOOOoOOO
(oO0O(oOo)0o0O0o()o
OhYeah is offline
post #2 of 2 Old 09-07-2001, 11:40 PM
NaeKid
JF Administrator, eh?
NaeKid's Avatar
Many different ways to do the grinding .. depends on how much metal you are required to remove and how much time you have to spend doing it.
I personally have a pair of Dremels (amazing little tool), a 3" grinder, a 7" cutting wheel ... and looking for a 14" cut-off saw and a cutting torch.
Another cool tool to have is a sawzall .. it will "Saw All" .. kinda expensive, but well worth the money you spend. Most guys that have a sawzall will use it to cut frames, bodies, nuts, bolts .. and all kinds of other metal things.
What are you planning on doing with your metal cutting ability?
Hello, my name is Vance and I am a Jeepaholic.
Its better to be naked with your friends, than to be clothed with your enemies
Silver
, zombie ready as the daily-driver
NaeKid is offline
Who would be open this late that carries torx bits wmeyer116 General Discussion 4 06-12-2009 09:49 PM
drill bits fdkss03 General Discussion 8 08-30-2008 09:28 AM
What does everyone use for torx bits? rustywrangler General Discussion 14 01-12-2007 06:54 PM
Interesting bits from news jzmtl General Discussion 3 12-05-2006 09:43 AM
Social Security ... a few tid bits...! Timmy.o.tool General Discussion 4 02-14-2005 12:32 PM
