Quantcast Garbage Disposal Stuck? - JeepForum.com
Go Back JeepForum.com > General > General Discussion > Garbage Disposal Stuck?
Old 09-30-2009, 06:39 PM   #1
XJK
The Guru of Nothing
XJK's Avatar
Alright so my disposal is seized up not sure why but I know it works because I can hear the motor trying to turn when I flick the switch. I have heard of some sort of tool to get it un stuck. Anybody out there with suggestions?
XJK is offline   Reply With Quote
Old 09-30-2009, 06:53 PM   #2
backgroundnoise
use a bigger hammer. If it doesn't fix it then it'll need to be replaced
backgroundnoise is offline   Reply With Quote
Old 09-30-2009, 07:03 PM   #3
Grape Ape
I'm tired
Grape Ape's Avatar
Stick your hand down in there and while trying to spin it by hand turn the switch on. That should do it.
Disclaimer, don't do what I just said it could cause them to void the warranty of your disposal.
The Final Salute
EVERYBODY is pro-gun, some just don't know it. When an anti-gun person is in trouble, the first thing they do is call 911 and demand that they send somebody with a gun!
We've idiot proofed the world... now its full of idiots. - Spiritof76
You will truly be the same today as you will be five years from now, except for two things...
...the people you meet and the books you read. Charles E. Jones
Grape Ape is offline   Reply With Quote
Old 09-30-2009, 07:03 PM   #4
EagerJeeper
Look under the disposal. The motor shaft should be accessible. Insert a hex wrench in the end of the shaft and turn to clear the obstruction. They usually come with the hex wrench. If not it's probably about a 3/8" hex wrench.
Join The NRA!
Vegetables are for when you run out of meat!
I find it odd that my spell checker always highlights Obama as a mistake!
EagerJeeper is offline   Reply With Quote
Old 09-30-2009, 07:07 PM   #5
bigred33
could have some crap stuck in the blades. We had a shot glass go down and get crushed a little bit ago, bits were sticking the blades...it sucks but you can stick your hand down there and see if the blades have anything jammed.
bigred33 is offline   Reply With Quote
Old 09-30-2009, 07:08 PM   #6
XJK
The Guru of Nothing
XJK's Avatar
Grape I just used your method and it worked flawlessly.
Old 09-30-2009, 07:10 PM   #7
coonash
coonash's Avatar
1994 ZJ
probably jammed. Get a big *** flat tip scewdriver, stick it on one of the blades and tap it with a hammer. Worked for me
Originally Posted by 5-90
This is an online forum, and the written word is the primary method of communication. If you make an effort to communicate clearly, people will be willing to communicate in return. If you don't make an effort, I don't see why I should - write like an idiot, and I'm going to think you're an idiot, that's just how things work.
USN Jeep Club Number 41
coonash is offline   Reply With Quote
Old 09-30-2009, 08:38 PM   #8
scramblered
If you can't find the wrench for it I would suggest using a broom handle to try to force the issue. Good luck.
scramblered is offline   Reply With Quote
Old 09-30-2009, 08:54 PM   #9
4XGore
2 chicks at the same time
4XGore's Avatar
1980 CJ7
Grape has the best way to do it but if you want to waste some time you could always disconnect the disposal unit from the bottom of the sink then take the top part of the unit off then look inside and remove whatever is jamming the blades. If nothing is jamming the blades then you might as well go get a new disposal unit since you already have the old one off. Now if you are really mechanically inclined.......follow Grapes advise.
4XGore is offline   Reply With Quote
Old 09-30-2009, 09:09 PM   #10
sandman
put the handle part of a plunger in there and rotate the blade.
1993 Jeep ZJ. 4.0
sandman is offline   Reply With Quote
Old 09-30-2009, 11:51 PM   #11
XJK
The Guru of Nothing
XJK's Avatar
Thanks all I found a wrench that would fit it and I got it free and clear, works good as new.
Old 09-30-2009, 11:58 PM   #12
sandman
good to hear
1993 Jeep ZJ. 4.0
Old 10-01-2009, 07:16 AM   #13
Grape Ape
I'm tired
Grape Ape's Avatar
Are you sure. The motor may be spinning now but the blades may not. They could be jammed up still and all the wrench did was shear the pin off allowing the shaft to spin freely. Now is when you need to put your hand down in there and turn it on to make sure the blades are spinning as they should. Make sure you run water while your hand is down in there checking for blade spin. You need to hold the blades firmly before turning them on. A friction fit on the shaft can cause the blades to move when not loaded with food etc... So hold the blades solidly when you turn it on so you can make sure the shear pin is still holding strongly.
The Final Salute
Old 10-01-2009, 07:41 AM   #14
_Kyle_
Hmmmm....
_Kyle_'s Avatar
Call Maintenance.
-Kyle
1996 Grand Cherokee
RIP Troy (bigbluezj94)
1996 ZJ FOR SALE
_Kyle_ is offline   Reply With Quote
Old 10-01-2009, 07:53 AM   #15
Turner
Lol I see a thread in the future. OK MY FINGERS ARE CUT OFF WHAT DO I NEED TO DO?
--Turner--
2006 Jeep TJ
1982 Toyota Pickup 20r/22r Hybrid, 5.29s, Lockrite frt/spool rear, Longfields, Hysteer, discs, armor, dents, smiles.
1970 Ford Bronco302, dana 30, 9", 3 on the tree, show stopper.
Turner is offline   Reply With Quote
Glock Forum
