Garage - JeepForum.com
post #1 of 12 Old 01-29-2013, 02:50 PM Thread Starter
ChrisHager
Administrator
ChrisHager's Avatar
Anyone else have the occasional humidity issues with their garage? Sometimes the floor sweats in my garage to the point it looks like someone hosed it down. Clearly, vapor barrier wasn't used when the concrete was poured. I was more surprised last night to see my ceiling sweating quite a bit as well. I'm sure it's because it went from freezing and almost no humidity to 60°F and steady rain these last few days. Anyway, anyone else experience this from time to time?
Notice the shiny ceiling...
And another wet spot... I wondered if this one had something to do with the fuel/oil nearby.
~Chris
His: 2004 WJ - OME HD 'Kolak' Lift -
His: 1979 J-10 - 3" on 33s -
His: 2009 Expedition
His: 1978 F250 Custom -
Hers: 2000 TJ
Hers: 2010 Jetta
Originally Posted by Matt
"You can't recycle tartar sauce."
Originally Posted by steve_80 View Post
Weird, I didn't realize you could use vomit as coolant.
ChrisHager is offline
post #2 of 12 Old 01-29-2013, 03:09 PM
curbcrawler
1946 CJ2A
Mine does this when I heat it. My tools get a little surface rust on them. frustrating.
Democracy is two wolves and a lamb voting on what to have for lunch. Liberty is a well-armed lamb contesting the vote. - Benjamin Franklin
-commit2013-
curbcrawler is offline
post #3 of 12 Old 01-29-2013, 03:10 PM
relgnarw
Yeah, this time of year everything sweats in my garage. I have an unfinished unattached garage and was hoping that insulation would stop that from happening.
"I had wobster at Wed Wobster" - Austin age 5
My onboard air build.
relgnarw is offline
post #4 of 12 Old 01-29-2013, 03:23 PM
Balvar24
1979 CJ7
Images in the first picture appear to be from an unheated garage. My guess is the garage was maintained at a temperature below 60F. When the outdoors warmed up, it did so quicker than the garage. Dewpoint took over and stuff starts to sweat.
Curious. Please elaborate.
"Work hard, rock hard, eat hard, sleep hard, grow big, wear glasses if you need 'em."
Balvar24 is offline
post #5 of 12 Old 01-29-2013, 03:46 PM
coonash
coonash's Avatar
I only get the moist concrete. When I put a new AC/Heat in the house I included the garage. It knocks the humidity down in the summer
Originally Posted by 5-90
This is an online forum, and the written word is the primary method of communication. If you make an effort to communicate clearly, people will be willing to communicate in return. If you don't make an effort, I don't see why I should - write like an idiot, and I'm going to think you're an idiot, that's just how things work.
USN Jeep Club Number 41
coonash is offline
post #6 of 12 Old 01-29-2013, 03:52 PM Thread Starter
ChrisHager
Administrator
ChrisHager's Avatar
I believe you're on the money. The garage holds a decent temperature but it is not typically heated.
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
post #7 of 12 Old 01-29-2013, 03:54 PM
AKABOB
Incredibly Handsome
AKABOB's Avatar
Does your clothes dryer exhaust into your garage?
Originally Posted by John Popper;
Sitting in clover looking for the fifth leaf. Something soon will come my way.
AKABOB is offline
post #8 of 12 Old 01-29-2013, 03:58 PM Thread Starter
ChrisHager
Administrator
ChrisHager's Avatar
No it exhausts outside. I've never had the ceiling sweat before but I account this occurrence to the rapid change in temperature and humidity we've recently experienced.
The garage is attached to the house and is insulated only in the attic. The walls aren't insulated.
The floor has become moist multiple times but I tend to notice it most if I open up the doors and let air flow through. I believe the pattern is, if the air temperature doesn't match the floor, it sweats, which makes sense. It hasn't become an issue being that I've only seen it happen a handful of times. It's more of an annoyance than anything, especially since it removes the possibility of coating the floor.
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
post #9 of 12 Old 01-29-2013, 03:59 PM
Balvar24
1979 CJ7
Concrete has a relatively high thermal mass. It takes a while to cool/heat up. Rapid changes in weather will out pace it everytime.
I keep my Jeep parked in the basement. If I pull out on a muggy morning, the whole darn thing gets covered in condensate. I have to wipe the inside of the windsheild in order to drive.
Balvar24 is offline
post #10 of 12 Old 01-29-2013, 06:40 PM
BeachinXJ
Resident McGeek
BeachinXJ's Avatar
Ever try running a dehumidifier in there?
- Chopped / Locked
- Daily Driver
2003 Dodge Ram 2500 CTD - 6-speed, 4" MBRP Turbo Back Exhaust
Rule #1 - No talking about the weather!
BeachinXJ is offline
post #11 of 12 Old 01-29-2013, 06:44 PM Thread Starter
ChrisHager
Administrator
ChrisHager's Avatar
It's usually not bad. I think I'm partially to blame for opening up the doors on a nice day considering it has been so cold. I think a dehumidifier would beg me to unplug it in these few scenarios.
~Chris
Hers: 2000 TJ
Hers: 2010 Jetta
post #12 of 12 Old 01-29-2013, 07:11 PM
roadhog304
1973 CJ5
My garage was the same way yesterday mine is attached and uninsulated and not heated most of the time. Talk about prime rusting conditions. I am glad that is does not happen very often.
1973 Jeep CJ5 Amc powered resto-mod
1976 Jeep CJ7 GM powered future 1 ton crawler
roadhog304 is offline
