Future Dirt Bike carrying Rack!!! - Page 2 - JeepForum.com
post #16 of 30 Old 12-07-2012, 07:56 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
^^^ that^^^
Luck Favours The Prepared
Anticanman is offline
post #17 of 30 Old 12-07-2012, 08:31 AM
prjohnson
That crewbed seems pretty cool. It looks like it's mounted fairly well to the tailgate, but I wonder if it causes stress on the hinges.
prjohnson is online now
post #18 of 30 Old 12-07-2012, 08:36 AM
hoaxci5
1995 XJ Cherokee
I talked to one of the reps at SEMA 2011 and he made it sound like because of the support beams underneath that the tailgate took pretty much zero weight and was really just closing in the box. But they didn't have a jeep there to display it, just the device itself so I can't verify.
Unknown - 1995 XJ - 4.5 RC lift, drop brackets, 33" MT's, SYE, Custom Bumpers/Rockrails
Rambo - 2007 XK Limited 5.7 - OME HD - Monroe Load Levelers (F150) - Flashpaq - RRO SuperSliders - 4XGuard all over - SOLD
hoaxci5 is offline
post #19 of 30 Old 12-07-2012, 08:40 AM
prjohnson
Do you know if the part where it mounts underneath folds up also? It looks like it hangs down very low where those bars attach. I could just imagine those getting all bent up on the first trail ride.
post #20 of 30 Old 12-07-2012, 08:44 AM
hoaxci5
1995 XJ Cherokee
It could be completely folded and stored with the stock tailgate closed.
hoaxci5 is offline
post #21 of 30 Old 12-07-2012, 09:19 AM
chriskeenan
i vote for small trailer, if its under certain size and weight the trailer doesn't even have to be tagged and registered, or have lights for that matter. I'd imagine its would be a huge PITA to get a bike up on to the jeep like that.
chriskeenan is offline
post #22 of 30 Old 12-07-2012, 09:43 AM
FLATFENDER54
FLATFENDER54's Avatar
Exactly..........forget all this nonsense. You need a small trailer. We know it, you know it....hell everybody knows it. Plus you are just gonna kill yourself trying to get a motorcycle up on top like that
01 TJ Sahara 4"short arm/rear gas&tire
carrier bumper/front winch bumper winch/detroitEz
1954 WILLYS CJ3B (under construction)
FLATFENDER54 is offline
post #23 of 30 Old 12-07-2012, 10:13 AM
4wheelrampage
Couldn't you get that crewbed thing, but mount that on a hinge or two or three to have it tilt?
Originally Posted by ApolloXIII
Tasting a drop isnt going to kill you.
And what doesnt kill you makes you stronger.
Therefore, tasting a drop of antifreeze actually makes you stronger :)
Mac users : control+option+command+8
4wheelrampage is offline
post #24 of 30 Old 12-07-2012, 10:31 AM Thread Starter
Digger838
Urge roll bar will have a channel inside them and a cross bar connecting the two side roll bars the " loading ramp" will be attached to that and be able dot slide from the top to the bottom to move the ramp. And ancker ponts to strap the bike down will also be on this cross bar. I will prolly use electric one or two electric hoists or a grab bar on the bottom of the loading ramp so that it will lift to the back of the bed and have a locking mechanism to lock the bottom of the ramp.
Digger838 is offline
post #25 of 30 Old 12-07-2012, 10:41 AM
BamaJeepman21
Originally Posted by Digger838 View Post
here is a picture i did on paint to give you an idea
Yeaaaaa after a long day at the track I'm almost too tired to push my bike on the trailer much less on top of a lifted Jeep.
It's a good idea in theory. I just don't think it'll work in reality.
-Jack
BamaJeepman21 is offline
post #26 of 30 Old 12-07-2012, 10:50 AM Thread Starter
Digger838
Ok we'll what if it had pneumatic cylenders that push it up ??
post #27 of 30 Old 12-07-2012, 10:54 AM
Hurley91
It seems like a lot of work just to avoid using a trailer.
Sent from my iPhone down by the Bay.
Hurley91 is offline
post #28 of 30 Old 12-07-2012, 10:56 AM
chriskeenan
Go to mcmaster-carr's site and look through the cylinder selections, if you can find one with enough stroke and power it could work, but then you need the power system for the pneumatics. Its going to get expensive fast.
http://www.mcmaster.com/#
The cable winch idea could work and still be fairly cheap, but then so would a trailer.
http://www.harborfreight.com/automot...res-42708.html
post #29 of 30 Old 12-07-2012, 11:58 AM
prjohnson
Well, you could just ride it up on top of the jeep....
Just make sure you video it when you're doing it.
post #30 of 30 Old 12-07-2012, 08:29 PM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
This question tell me this thread isn't about input, but validation. After all the negative input and plethora of good alternate ideas and advice, you are still trying to make it work.
Build it the way you want. go for it. Either it works or it doesn't. If it does, post it so we can all stand chagrined.
jeepdaddy2000 is offline
custom , dirt bike , wrangler
