Future Dirt Bike carrying Rack!!! - JeepForum.com
post #1 of 30 Old 12-06-2012, 04:46 PM Thread Starter
Digger838
Ok so I've been looking into the scrambler tops for my jeep the regular cab ones made by Gr8ttops
(the have a website gr8tops ).
I race dirt bikes and I don't want to pull a small utility trailer everywhere.
I looked at the "home made" forum and all i found was a few trailer hitch racks, they don't impress me at all ( too weak )
so I have thrown out a few drawings with my buddy that has a bike and a jeep and is also tired of pulling a trailer.( he already has the scrambler top)
I will try to get a nice hand drawing up or a C.A.D drawing
I will describe what I want to build.
( if you see this without pictures I hope you understand, I will have detailed drawings as soon as I get my CAD programs back, I will do a rough computer paint drawing if I can.)
it will need the scrambler top, custom roll bar from front -back ( running up the side of the windshield housing, over the roof, and to the back corner of the "box" now that it has a regular cab roof on it)
have a ramp in the back connected to bogey wheels inside the roll bar( role bar using 4" diameter 1/4" aluminum tubing with a channel cut into the inside part of both side tubes of the roll bar, using one on each side to make a cross bar to mount between the roll bars and to attach the top of the ramp, and then remove the tailgate or make a mounting bracket that locks the ramp in the bed ( I have a few ideas floating around for this. )
also have a few ideas for storage with this system.
Let me know what you think of the idea and if I should even pursue it to an actual project.
Digger838 is offline
post #2 of 30 Old 12-06-2012, 06:04 PM
That1guy
That1guy's Avatar
2007 WK
Whats wrong with the hitch carrier?
I'm forever grateful to Speedycat and RnEmOvr for their generosity
That1guy is offline
post #3 of 30 Old 12-06-2012, 06:41 PM Thread Starter
Digger838
here is a picture i did on paint to give you an idea
post #4 of 30 Old 12-06-2012, 06:43 PM Thread Starter
Digger838
I dont want all that weight on my rear end it gets a little squirrely.
post #5 of 30 Old 12-06-2012, 07:34 PM
PurpleTJ
I feel like your idea will do the same. Seems rather top heavy. How are you going to get it up there?
Edit: I've read good reviews on the hitch carrier, FWIW.
Purple Jeep Club member #8
PurpleTJ is offline
post #6 of 30 Old 12-06-2012, 07:50 PM
4wheelrampage
Drop down tailgate?
Originally Posted by ApolloXIII
Tasting a drop isnt going to kill you.
And what doesnt kill you makes you stronger.
Therefore, tasting a drop of antifreeze actually makes you stronger :)
Mac users : control+option+command+8
4wheelrampage is offline
post #7 of 30 Old 12-06-2012, 09:15 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
The hitch carrier is unrealistic for the Yj unless there are several frame supports that you can weld on. The stock rear crossmember cannot hold that kind of weight without something bending or breaking. The MS Paint idea isn't as farfetched as I thought to be honest. If you can maintain the integrity of the roll cage and add a foot or two to the cargo area via a drop down tailgate plus extension plate then you may have a solution. I must say that having a trailer is the very best option overall.
Luck Favours The Prepared
Anticanman is offline
post #8 of 30 Old 12-06-2012, 09:26 PM
dooboy2112
How are you going to load unload the bike by yourself?
2000 Grand Cherokee Limited
2000 Wranger Sport SOLD
1979 Wagoneer SOLD
dooboy2112 is offline
post #9 of 30 Old 12-06-2012, 09:31 PM
4wheelrampage
Ramp, or better yet air bag suspension!
post #10 of 30 Old 12-06-2012, 10:32 PM
Hurley91
What about building something like the hitch mounted rack, but incorporate it into a custom rear bumper? Make it so that there are two mounts for the rack ( one on each side of the bumper ), and then make a support for the bottom using the hitch?
Sent from my iPhone down by the Bay.
Hurley91 is offline
post #11 of 30 Old 12-07-2012, 03:13 AM
ArrizX
Whats your bike weigh? 250? Less? What 20/30lbs in metal?
You think under 300lbs it gets squirrelly? Really?
ArrizX is offline
post #12 of 30 Old 12-07-2012, 05:04 AM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
I would pay good money to watch you load that.
I built a dirt bike rack out of an old front bumper off an early Bronco way back in the day. It used two short pieces of elliptical springs to bolt it to the back of my CJ.
I carried a dirt bike on it for many years with no ill effects.
jeepdaddy2000 is offline
post #13 of 30 Old 12-07-2012, 06:19 AM
hoaxci5
1995 XJ Cherokee
Unknown - 1995 XJ - 4.5 RC lift, drop brackets, 33" MT's, SYE, Custom Bumpers/Rockrails
Rambo - 2007 XK Limited 5.7 - OME HD - Monroe Load Levelers (F150) - Flashpaq - RRO SuperSliders - 4XGuard all over - SOLD
hoaxci5 is offline
post #14 of 30 Old 12-07-2012, 06:51 AM
prjohnson
Maybe the TJ is different, but I've never had a problem hauling my RM on a hitch carrier. Before I had that, I considered adding a drop down tailgate, removing my spare tire & the back seat. Then tie down the front of the bike in the back of the jeep & letting the rear sit on a cargo carrier I had. I came to my senses & realized that I could buy a hitch hauler for 100 bucks on Craigslist. Now when I remove my backseat, I can load it full of all my gear.
I've seen a picture on here somewhere where someone took out the passenger & rear seat & stuffed a bike in a jeep.
prjohnson is offline
post #15 of 30 Old 12-07-2012, 06:55 AM
hoaxci5
1995 XJ Cherokee
http://www.crewbed.com/
hoaxci5 is offline
custom , dirt bike , wrangler
