Ford 5.4L-won't warm up - JeepForum.com
Go Back JeepForum.com > General > General Discussion > Ford 5.4L-won't warm up
Free shipping on Rugged Ridge XHD bumpersBaseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft KiIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 12-18-2014, 04:38 PM   #1
Marauder_Pilot
Marauder_Pilot's Avatar
So, I bought a Ford E350 5.4L with a 4WD conversion to build an overland camper with. It's been sitting for 3-4 years, so first order of business was draining all the gas, oil and coolant and replacing them with fresh fluids.
Afterwards, it runs, idles and drives just fine, but the engine doesn't seem to heat up at all. The temperature gauge is always pegged just a hair off the bottom, and there's barely any heat coming out of the heater. There's a CEL, but it's noting a bad injector, nothing related to the cooling system.
I've never run into anything like this before, anyone know where I should start?
"Buying a Jeep for on-road handling is like downloading porn to savor the cinematography."
-TTAC
| ARB/Old Man Emu | Northridge 4x4 Canada | Warn | Modern Classic Enterprises | American Expeditionary Vehicles | GenRight | Poison Spyder | OR-FAB | Metalcloak | East CoastGear Supply | JKS | M.O.R.E. |
2000 Jeep Wrangler TJ Sport-OME HD Lift, ProComp bumper, 32" BFG TA K/Os
2010 Kawasaki KLR650-Stock
2005 Ford E350-Clydesdale 4WD Conversaion
Marauder_Pilot is online now   Reply With Quote Quick reply to this message
Unread 12-18-2014, 05:20 PM   #2
Indy
Stuck thermostat.
I'm the only gay eskimo.
Indy is offline   Reply With Quote Quick reply to this message
Unread 12-18-2014, 10:36 PM   #3
Cause
WHAT !!!!
Cause's Avatar
Is there even a T-stat in it?
1. Stupidity should be more painful!
2. Don't believe everything you think!
3. Your post is as worthless as you!
Cause is offline   Reply With Quote Quick reply to this message
Unread 12-18-2014, 11:00 PM   #4
Indy
My first taco did the exact same thing, went to check the tstat and found it to have been removed. Put a stat in and immediate overheat, cracked head that was pumping exhaust into the coolant system, hidden by the missing thermostat. 1st place to look.
Unread 12-19-2014, 05:08 AM   #5
The_War_Wagon
2007 XK Commander
Originally Posted by Indy View Post
Stuck thermostat.
This.
Even when you fix it, keep in mind that Ford's are notoriously slow to heat. My dad used to let his '64 Mercury warm up in the driveway for 15 minutes, before going anywhere in the winter... in NC!
I've owned;
- '68 Mercury Monterey
- '79 Ford Bronco
- '89 Country Squire Wagon
- '93 Mustang GT (purchased NEW!)
- '95 Mercury Gran Marquis
Different eras, different engines, and they were ALL slow to heat up! My '92 Ramcharger has a stuck blend door (a/c blows great, heat DOESN'T) and it still gets warmer, faster, than those 5 above COMBINED!!!
So when you fix it, and it's STILL slow to heat, than it's working JUST fine.
'07 Commander, Rocky Mountain Edition, 67k miles, & looking for advice!!!
The_War_Wagon is offline   Reply With Quote Quick reply to this message
Unread 12-19-2014, 09:49 AM   #6
Marauder_Pilot
Don't worry, I know how long an E-Series takes to warm up-I drive them every day for work too (Electrician). But after driving 20 minutes down the highway and it hasn't moved, that's a pretty good sign it's a problem.
I'll pull the thermostat today and see what's happening there.
-TTAC
Unread 12-19-2014, 11:20 AM   #7
Indy
By the time I hit pavement in my tacoma I have a warm engine and good heat. My mustang, I'm 1/2 way to work and the needle hasn't budged yet
Unread 12-21-2014, 03:57 PM   #8
Scrmngchicken
Thermostat needs replacing.
Scrmngchicken is offline   Reply With Quote Quick reply to this message
Unread 12-21-2014, 07:29 PM   #9
Cause
WHAT !!!!
Cause's Avatar
Do you know how to test it when you have it out?
If you put in a new one... ALWAYS test it before installing it!
Hint--- pan of water on the stove and a thermometer---
Unread 12-24-2014, 06:36 AM   #10
Rfield
Pressure test the radiator cap, if it doesn't hold pressure the coolant will not circulate correctly.
Rfield is offline   Reply With Quote Quick reply to this message
Unread 12-24-2014, 08:42 AM   #11
Scrmngchicken
My 5.8 did that. Turned out one of the block plugs is leaking. The only way to get at it is to pull the engine out. I may end up doing that.
The 5.4s tend to be really tight systems. The T-stats are finicky though. My Expedition did what his E350 did. Stone cold while driving around. But mine started to creep up only at fast food drive throughs.
Changing one is easy. Pull the radiator hose off. There's two bolts that fasten the housing down. One accessory bolt needs removed also. Once the bolts are out, you'll have to get a big screwdriver and insert the handle into the housing and rock it back and forth. These things are lightly pressed in. WD40 should help. After walking it off, the stat is exposed.
When buying one, buy the o-ring seal! New stats don't come with one, and the old ones are almost always damaged coming off. Clean everything around it! The seat will catch a lot of junk. Clean everything off.
When the stat is installed, put the housing on, and run the bolts down. I use a bit of antiseize compound because on Fords, bolts that are anywhere near the cooling system tend to get a bit, flaky. Use the bolts to drive the housing back down.
The T-stats are like $6 and the o-ring is somewhere around $2. The time frame for the job is less than 30 minutes.
