fm no longer working, just am - JeepForum.com
Go Back JeepForum.com > General > General Discussion > fm no longer working, just am
Ruffstuff 10 year saleBDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRough Country Lift Kits and Parts!
Unread 12-21-2001, 12:12 PM   #1
jimv81z
96 grand cherokee, factory am,fm,casette radio - fm does not work anymore, just static, but am still working. Any ideas on what the cause could be? Is it something I can fix or do I need a new radio?
Thanks
jimv81z is offline   Reply With Quote Quick reply to this message
Unread 12-21-2001, 02:55 PM   #2
horatio102
Sounds like the radio is toast. My folks' old '89 Grand (caravan) lost about 1/2 of the volume from one side of the car, so I threw an aftermarket deck in w/speakers. I have no clue what happened to that deck. I know I pulled the speakers out and I've still got them, but the double-din deck is nowhere to be found.
You can try pulling the antenna wire out and putting it back in, possibly it just lost connection, but other than that I've got no ideas.
horatio102 is offline   Reply With Quote Quick reply to this message
Unread 12-21-2001, 09:12 PM   #3
KG4PAM
sounds like maybe it's the anttena cable, as horatio said. my dad's 86 f-250 had the same problem and i tried everything i could to fix it. i even put in an old deck i had lyin around, but that didn't work either. not sure about the ZJ, but on my dad's truck the problem was that the antenna cable had came loose. i took the 4 screws out that held the antenna to the hood, and there was no cable attached. looked in the hole, and there was the cable with a banana plug on the end. fished it out, plugged the cable into the antenna base, and reattached the assembly and the radio worked fine. as i said, i'm not sure about the ZJ, but it's bound to have a similar arrangement. just check that the antenna is connected at both ends. if they are, i would use an ohmmeter or continuity checker to see if the cable could be shorted or broken. your am radio should work fine, because there is a seperate ferrite antenna inside the radio that is unaffected by whether the aerial is plugged up. hope this helps! jairus
'81 CJ-7 Got it when I was 16!
'06 Hummer H3, boulder gray, Adventure Package(electric rear locker and 70:1 crawl ratio BONE STOCK)
'71 Kaiser-Jeep M35A2 Deuce and a Half cargo truck, with winch. <for sale>
KG4PAM is offline   Reply With Quote Quick reply to this message
Unread 12-29-2001, 11:42 AM   #4
DeathCrush
yea, most likely its the antenna that just came unpluged, thatll happen if the connector isnt crimped too well, if then antenna IS connected then it sounds like youre going to have to by another receiver. my sugesstion is get a Pyramid, their website is www.pyramidcaraudio.com they have full DIN sized radios that will work fine...
2001 XJ Cherokee, 4.0L
NV3550 5-spd. transmission
3" Lift
31x10.5" Hifly All Terrain tires
DeathCrush is offline   Reply With Quote Quick reply to this message
