Fix-A-Flat,Lawn Mowers, and tire pressure. - JeepForum.com
post #1 of 7 Old 03-24-2007, 03:57 PM Thread Starter
metalgod
My Dad's riding mower tires were all low on pressure. I was over at his place today helping him to get it ready for the season. He said he had some Fix-A-Flat and told me to put it in the tires. I dont use the stuff so I read the instructions and went at it. It says to put all that the tire will hold until the Fix-A-Flat stops flowing into the tire. So after doing all four tires I thought it seemed like the tires were bulging so I checked the pressure. I couldn't believe it over 55PSI! On a tire that calls for 14psi. Is this normal for Fix-A-Flat and could this be dangerous? It doesnt sound good to me. I told my dad about it but he did seem to care and drove it around for a while like it says to do. I havent checked the pressure since then I dont want the damn thing to blow up in my face. Is there any danger here? What should I do?
metalgod is offline
post #2 of 7 Old 03-24-2007, 04:04 PM
RCHavok797
RCHavok797's Avatar
Lower the pressure to the recommended psi. If the fix a flat is going to find the leak it would have done so by now.
2005 LJ Impact Orange 4.0L Automatic (Tigger) - new ride
1991 YJ Sahara 4.0L Automatic
1978 Dodge Lil Red Express - work in progress
RCHavok797 is offline
post #3 of 7 Old 03-24-2007, 04:13 PM
cmotsvt
Funny thing is that there was no leak, at least not one that needed fixed. Just about any riding lawnmower/ATV/gator tire that I have ever seen has needed air after a few months.
cmotsvt is offline
post #4 of 7 Old 03-24-2007, 04:14 PM Thread Starter
metalgod
what would be the best way to release all of that pressure?
cmotsvt: your right, there was no leak but my dads the type of guy that you do what he says just to keep from hearing him b!tch.
metalgod is offline
post #5 of 7 Old 03-24-2007, 04:16 PM
cmotsvt
A railroad spike?
cmotsvt is offline
post #6 of 7 Old 03-24-2007, 04:17 PM
pyro9862
Originally Posted by cmotsvt
A railroad spike?
Someone is a
It says right on the can if the tire is overpressurized to
1. Shoot with .460 round
2. Place said tire in your home and set fire to it
The directions are written for car tires. In most car tires a can like that won't get you anywhere near the recommended tire pressure. Best way to let the pressure out is just grab something skinny and push the valve stem in. It should only take thirty seconds or so for a little lawn tractor tire to bleed off that pressure.
pyro9862 is offline
post #7 of 7 Old 03-24-2007, 05:00 PM Thread Starter
metalgod
Thanks for the help, that took care of it.
metalgod is offline
Let's talk Lawn Mowers kairo General Discussion 27 07-08-2009 07:34 PM
Flat tire Rule303 General Discussion 35 04-10-2007 10:27 AM
Flat tire fixes LOCKED UP General Discussion 27 09-19-2006 02:33 PM
Why do Lawn Mowers have headlights? PDX_XJ General Discussion 13 09-14-2005 08:54 PM
