F250 won't start - JeepForum.com
post #1 of 9 Old 01-25-2010, 07:29 PM Thread Starter
Otahyoni
Otahyoni's Avatar
1986
F250 won't start
I know this is JF but i have a problem. My F250 lost all power in the cab. Only thing that works is the brake lights and my manual glow plug relay. I know that batteries are fully charged.
Any ideas?
~Chris
And all of the diodes may have committed suicide, leaving you with a fun whirly thing under the hood that produces nothing.
Otahyoni is offline
post #2 of 9 Old 01-25-2010, 07:49 PM
cmotsvt
Id start by poking around the fuse box with a multitester. Id guess it may be melty. Theres also some sort of connector that mounts on the front side of the fuse box and passes through the firewall.
also visit:
www.fordf150.net
or
www.fullsizebronco.com (97 or older 3/4T truck would be same as bronco m/l)
cmotsvt is offline
post #3 of 9 Old 01-25-2010, 07:50 PM
battelax
When you say batteries I am assuming your working on a diesel? I remember one time with a 6.0 Powerstroke I had the same symptoms but it was some fuse that went causing the issue. If it is a diesel go to www.powerstroke.org
Edit: Glow plug relay gives it away. I would go to the the powerstroke and do a quick search see what you can come up with.
battelax is offline
post #4 of 9 Old 01-25-2010, 07:54 PM Thread Starter
Otahyoni
Otahyoni's Avatar
1986
I guess i should add that it's an 86 F250 with the N/A 6.9L diesel.
~Chris
Otahyoni is offline
post #5 of 9 Old 01-25-2010, 07:59 PM
cmotsvt
Id visit fullsizebronco then. Mechanically they will be very close.
Id bet on a toasted bulkhead connector/fuse panel.
cmotsvt is offline
post #6 of 9 Old 01-25-2010, 08:02 PM Thread Starter
Otahyoni
Otahyoni's Avatar
1986
I asked on thedieselstop.com, but there is a lot more traffic here.
~Chris
Otahyoni is offline
post #7 of 9 Old 01-25-2010, 10:09 PM
Grape Ape
Web Wanker
Grape Ape's Avatar
Check out Ford Truck Enthusiasts Forums If they can't help then you will have to just junk it. The people there are as god with Ford trucks as the folks here are with jeeps.
EVERYBODY is pro-gun, some just don't know it. When an anti-gun person is in trouble, the first thing they do is call 911 and demand that they send somebody with a gun!
We've idiot proofed the world... now its full of idiots. - Spiritof76
You will truly be the same today as you will be five years from now, except for two things, the people you meet and the books you read. Charles E. Jones
I think I'll add some memorable quotes. blah blah blah..... FPKites
Trying to understand some people, is like trying to pick up a turd by the clean side.
Grape Ape is offline
post #8 of 9 Old 01-25-2010, 11:43 PM
Marn
Station Wagoneer
Marn's Avatar
1973 FSJ Wagoneer
My guess is that its because it's a 4 letter word starting with F...bahaha
-Andrew
Illegitimi Non Carborundum
The Beast Build Thread:
Marn is offline
post #9 of 9 Old 01-26-2010, 02:09 AM
carnuck
1984 J-Series Truck
Ford circled the problem (ex-Ford tech) I'd say fusible link.
"Usually found in a Jeep near Reiter, WA"
FOR SALE STUFF
'81 Eagle wagon with upgrades $2500
'87 Comanche shortbox 4.0/AW4/NP242 on 33" tires $3500
carnuck is offline
74 f250 tow rig? TJmudpuppy Trailers & Towing 5 03-03-2009 06:21 AM
gas mpg on f250 with v10 freedomhunter General Discussion 28 09-09-2008 07:16 PM
f250 engine oteps Trailers & Towing 0 11-09-2007 03:31 PM
f250 parts pasadena Trailers & Towing 0 08-25-2007 05:35 PM
Anyone seen that SWAT-setup F250? lordmatt General Discussion 4 12-06-2004 11:35 PM
