Quantcast Excel Help.. - JeepForum.com
Go Back JeepForum.com > General > General Discussion > Excel Help..
JKS products - Free shipping! Lowest prices!East Coast Gear Supply- Quality Diff PartsJeep CJ, YJ, and TJ build your own bumper packages.
Old 03-05-2007, 10:51 AM   #1
GaytorHater703
Excel Help..
i created a spreadsheet for work and it has a column in in for dates....now instead of showing the dates it shows some numbers that dont look like a date....but if you click on the box it shows the correct date in the address bar but when you click off of it it goes back to the screwy numbers...example 39040 corresponds to november 19th, 2006.....even if i highlight the cell and try to change the format to a different date type it still puts the wierd numbers....anyone ever seen this or know how to correct it?????????
GaytorHater703 is offline   Reply With Quote
Old 03-05-2007, 10:53 AM   #2
Indy
Highlight the cells, right click, format cells, date.
Never underestimate the power of stupid.
Indy is offline   Reply With Quote
Old 03-05-2007, 10:55 AM   #3
LandRover
Before you do that, put in December 21, 2012 and see if your computer blows up.
RHD '98 XJ
RE 3.5", Bushwaker Flat Flares,
OR-Fab bumpers, PowerTrax locker,
Sliders, Maxxis Bighorn 32's
LandRover is offline   Reply With Quote
Old 03-05-2007, 10:59 AM   #4
Grewe02
Cant edit my user title
Grewe02's Avatar
1980 CJ5
Before you do that... save it.
Andy, KD8EIA
| USN Jeep Hull # 66 | ΜOΛΩΝ ΛΑΒΕ |
| My Jeep's Thread | My Photobucket | San Diego Jeepers!! | VBARC | Military Jeepers |
"Don't take life too seriously, You'll never make it out alive."
"A government big enough to give you everything you want
is a government big enough to take from you everything you have"
- Gerald R. Ford in an address to a joint session of Congress on August 12, 1974
Grewe02 is offline   Reply With Quote
Old 03-05-2007, 11:04 AM   #5
Fett
Mechanically Declined
Fett's Avatar
You can either go to a command prompt and type FORMAT C:
or
press your colon until help arrives.
Can you give a litte more info: how did you enter the dates originally (what format mm/dd/yy, etc). Did you enter the dates then try to format the cells or the other way round?
99 TJ Sport I64L Manual 31x10.5 RE 3.5" Super Flex 1"BL 3.73 gears w/LockRite in front. Warrior Safari Rack.
"When you honestly believe you can compensate for lack of skill by doubling your efforts, there's no end to what you can't do". www.despair.com
|_
|T|
Fett is offline   Reply With Quote
Old 03-05-2007, 11:05 AM   #6
Indy
Or you might have the cell too small for the data in it. If you shrink a cell it will show something other than what's actually entered.
Old 03-05-2007, 11:09 AM   #7
Rocky529
Jeep
Rocky529's Avatar
2004 Jeep Wrangler Sport - 5 speed
Silver Metallic finish with black dual tops - Dana 44 Rear
2.25" Suspension Lift with Old Man Emu Shocks
Performance Accessories 1" Body Lift
Daystar 1" Motor Mount Lift
Spidertrax 1.25" Wheel Spacers - 32"x11.5" MT/R Tires
Rocky529 is offline   Reply With Quote
Old 03-05-2007, 11:13 AM   #8
GaytorHater703
thanks for the help....i figured it out....i had to go to tools...options....view tab...and click the formulas box at the bottom off.....it was thinking the dates were formulas....
Glock Forum
