****ed up my Jeep after the mechanic left it in gear.
#61 | |
tactical recon snow dog
Go buy a YJ and try parking it on even a slight hill with just the parking brake. Go ahead, I'll wait.
I don't think I even know a single person that parks any vehicle in neutral.
#62 |
Parking brake would NOT have done a thing,that starter develops alot more torque that parking brake can hold.
#63 |
all manual transmisions should be parked IN GEAR... not sure what planet you learned to drive on but the handle sicking out of you center consol is an emergency brake... NOT a parking brake... parking brakes are on automatics...it sucks your jeep was hurt by your own neglect... but !@#$% happens... even to good people! The only failure that could start a vehicle moving forward would be a shorted selinoid on the starter... not common... i would go as far as saying almost unherad of... as for the dodge burning up... one less pickup truck to get stuck on the trails in front of us! LOL!
#64 |
Wrong!!!!!!
#65 |
Instant Gator
Sorry Nonya, manual transmission vehicles are to be parked with the emergency brake engaged and the transmission in either 1st or reverse.
Miss Amy's sensibilities and the language filter prevent me from telling you what I really think about you. 2006 Liberty Sport CRD 1979 J10 LWB |
#66 | |
You come back...one year!
What's more likely to happen, a starter spontaneously engaging or a parking brake failing causing a car to roll? Not everyone parks along side a curb to be able to point your wheels. |
#67 |
Some vehicles have locks on them so that you can not shift out of first when the vehicle is parked. it makes it harder for people to steal it because you can not easily roll it. but apparently the people that designed that where morons
If I can get there I can wheel it! CentralMass4wd.com 1993 Ranger 2wd - dd 1999 wranger 2.5 - it gets used for something 1978 international scout - being built 1998 Cherokee sport 4.0 auto 1957 CJ5 - restoring back to stock http://www.jeepforum.com/forum/f8/restoring-57-cj5-stock-build-thread-553649/#post5168554 Bikes:2000 Ducati Monster 900: 2001 CBR 600 F4i: 1980 CB 900 my build http://www.jeepforum.com/forum/f9/my-build-thread-those-us-low-budgets-550786/ |
#68 |
"Parking a manual transmission car in gear is an old chestnut that originates from bygone times when cars were much heavier and parking brakes were marginal to say the least.
Parking the car in gear relies on the expectation that the gases compressed in the cylinders will stop the engine from rotating, but in fact only 1 cylinder will be on the compression stroke at any one time, added to this piston rings aren't a mechanical seal, they will always leak over any period of time, this can be measured by a leak down test." Simply put, your starter motor has to overcome the engine compression to start the car, there's no reason why a ton of car parked on a hill won't overcome the same compression. If the compression was that high, you would never be able to push start a manual tranny car. " So no, a single engine cylinder under compression shouldn't be relied upon to hold the car on an incline. Use the parking brake, that's what it's for. If the car won't hold with the parking brake on and a gear engaged, it's more indicative of parking brake rather than engine problems. |
#69 | ||
#70 |
Taken directly from my state's driver manual:
• Always set your parking brake when you park. Leave the vehicle in gear if it has a manual transmission or in “park” if it has an automatic transmission. |
#71 | |
![]() Quote:
1999 tj 4.5 inch lift 35X12.50s 1988 XJ 3.5 inch lift 31X10.50s camo paint |
#72 |
when I was driving and over the road truck you park them in neutral and set the air brakes
#73 | |
Instant Gator
I work for an LTL company and if I park my truck without the air brakes set and the transmission in gear I am FIRED! ![]()
#74 | |
green jeep club member #122 |
#75 | |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
