Eastwood's road salt neutralizer - JeepForum.com
Go Back JeepForum.com > General > General Discussion > Eastwood's road salt neutralizer
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: Wranger BRIGHT License Plate LED! Just $3! Great valueFS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread 01-29-2013, 07:02 AM   #1
GreenliftedTJ97
just wondering on everyones opinion, in theory, would this be worth using or has anyone used in in the rust belt? worth the $30? active ingredient is the sames as whats in Lime-a-way, could you just use that at a lower cost?
ideas? http://www.eastwood.com/eastwood-roa...er-gallon.html
Green Jeep Club member # 456
New Jersey & you, broke together since 1787
GreenliftedTJ97 is offline   Reply With Quote Quick reply to this message
Unread 01-29-2013, 09:52 AM   #2
Djole
Sounds interesting. May be a good option to spray inside the frame. If it doesn't evaporate.
Djole is offline   Reply With Quote Quick reply to this message
Unread 01-29-2013, 11:24 AM   #3
festerw
Vinegar will do the same thing.
Fluid Film will work to protect the inside of the frame.
Hers - 2005 Jeep Grand Cherokee Laredo 3.7 4x4
Mine - 2003 Jeep Wrangler X
festerw is offline   Reply With Quote Quick reply to this message
