~Duramax/Allison in a Jeep?~ - JeepForum.com
post #1 of 20 Old 03-19-2010, 02:48 PM Thread Starter
RikRotorhead
Has anyone ever even considered this?
I may have access to a perfectly good twin turbo Duramax and six speed Allison with a t-case soon.
The Allison is pretty big. I don't think it would fit between the frame rails on a Wrangler, or would it?
The Duramax is a 6.3L, so is that the same size block as the Chevy 350 or there-about?
Dana 60's would have to be used for all that horsepower being delivered.
I have a friend that swapped the same power train into his H1 Humvee. It stops for nothing (except narrow passages )
Just putting this out here for discussion to see if it's worth doing.
I have a 1950 Willys Wagon I could maybe throw it into?
Zombies hate fast food.
RJC#512
RikRotorhead is offline
post #2 of 20 Old 03-19-2010, 02:51 PM
corndogduff
The deck height is WAY too high for a modern jeep and the Allison would take up almost all the space between the rails, the Willy's would only be worse.
Duff.
(broken)98 ZJ 5.9
UT Jeepcrew #13
NIGHTCREW
corndogduff is offline
post #3 of 20 Old 03-19-2010, 03:09 PM
jbolty
jbolty's Avatar
I have a 1961 Chevy that could benefit from that.
jbolty is offline
post #4 of 20 Old 03-19-2010, 07:47 PM
Alex74012
duramax is a 6.6l
that dd rubi on 37's
Alex74012 is offline
post #5 of 20 Old 03-19-2010, 07:51 PM
little_Jeep
The additional weight would be a killer........
little_Jeep is offline
post #6 of 20 Old 03-19-2010, 07:53 PM
SeaWulf
1983 CJ7
^^all of the above
you could run a full size jeep frame with a wrangler tub and clip, I've seen a few people do that
SeaWulf is offline
post #7 of 20 Old 03-20-2010, 07:27 AM
GotJeeps
I had a hard enough time shoehorning a Mopar big block into a 51 Willys pickup. I can't ever imagine a Duramax. It would be awesome though. Check out the build in my sig.
-(O|||||||O)-
GotJeeps is offline
post #8 of 20 Old 03-20-2010, 09:11 AM
cmotsvt
A cummins b3.3t BARELY fits due to the height. A full sized diesel V8 would be way too much motor.
cmotsvt is offline
post #9 of 20 Old 03-20-2010, 09:17 AM
jerryjeeper
Probably NOT a good idea. First, it isn't going to fit well, Second, excessice front end weight, and finally, all that torque will shred the frame and chassis.
jerryjeeper is offline
post #10 of 20 Old 03-20-2010, 09:22 AM
cmotsvt
Third Im guessing some serious wiring.
Fourth Driveline length.
cmotsvt is offline
post #11 of 20 Old 03-20-2010, 09:50 AM
kg4kzv
1995 XJ Cherokee
Maybe on of the bigger old Jeep trucks.
Chris.
95 Cherokee SE 4.0, 5-Spd, 8.25;
6.5" Rusty's Lift, Atlas II Rims, 35x12.5x15 Wild Country,Rusty's Tube Bumper, Wilderness Rack
Rock Sliders, K&N Panel Air filter, PSC steering box,
I-ROK reinforcement kit, ORO U-TURN steering kit,Conversion Headlights/Silverstars And too much $$$
kg4kzv is offline
post #12 of 20 Old 03-20-2010, 10:47 AM
cmotsvt
Chris.
Yep, thats alot more feasable, Id guess youd still have some reinforcing to do. Really if I were to do a diesel in anything it would be of the 2 wire hookup sort.
cmotsvt is offline
post #13 of 20 Old 03-20-2010, 04:21 PM Thread Starter
RikRotorhead
Well I hate to see that huge power plant go to waste.
Maybe I should buy an old Chevy van and make a mid engine rock crawler.
I have no idea what to do with the power plant if I can't use it in my Willys Wagon.
I'm sure the computer system is pretty complicated too.
Maybe just sell the power train and get a nice Cummins 3b for my YJ or the Willys.
RJC#512
post #14 of 20 Old 03-20-2010, 04:43 PM
corndogduff
Measure it. It MIGHT shoehorn in the Willy's if you arent afraid of some fabbing....
Duff.
(broken)98 ZJ 5.9
UT Jeepcrew #13
NIGHTCREW
post #15 of 20 Old 01-25-2012, 02:59 PM
oshkarmeyer
1977 CJ7
What ever happened with this Duramax/Jeep idea? I have both a CJ7 and drive a Duramax daily and I have pondered the same idea for a LONG time.
If you search for "Powerstroke Jeep" on Youtube you will find many videos of a CJ7 with a full Powerstroke drivetrain in it and that thing is BADA$$ man.
I'd love to hear if you went ahead with the project. I plan on getting another CJ7 and doing the Duramax swap myself. If a Powerstroke will fit then I would imagine a Duramax is possible as well.
oshkarmeyer is offline
Duramax Diesel (Kaboom) 1BadJeepX06 General Discussion 64 02-24-2012 03:26 AM
Allison the duster Greengc4x4 General Discussion 29 02-01-2010 10:59 PM
silverado +duramax deisel tcox General Discussion 10 09-02-2008 12:22 PM
Flat towing with silverado 2500hd duramax Mainiack Trailers & Towing 5 04-03-2007 09:50 AM
Chevy 2001 Duramax ext cab 118k mi LT $17k - is this a good price? SomerJeep Trailers & Towing 1 12-04-2006 10:52 AM
