Door Handles on full doors - JeepForum.com
post #1 of 7 Old 04-22-2002, 07:48 AM Thread Starter
SnowMan
Does anyone know how to get those outer door handles out of the full doors. My old ones crapped out and got some new ones ( used) to drop in just don't know how. Any ideas would be appreciated. Also has anyone had there full doors repainted, and if so what was the cost. I'm lookin to get mine done but don't want o get taken for a ride.
Is that you John Wayne, is this me!
SnowMan is offline
post #2 of 7 Old 04-22-2002, 01:09 PM
GothicJeep
GothicJeep's Avatar
check out 4wd.com (4wd hardware). They have tons of replacement parts for everything!
Goth...
JeepGeek Offroad Member v4.0
'Blue Zombie' (My 2002 TJ SE)
30x9.5 Hi-Tec Muds, Olympic Dave's Rack, and a BUTTLOAD of tow hooks...
My blog!
GothicJeep is offline
post #3 of 7 Old 04-22-2002, 02:32 PM
RCHavok797
RCHavok797's Avatar
There are 2 metal clips holding them in place shaped like a saw. I had to replace mine a few years ago because all of the chrome chipped off them. I replaced them with black ones because all of my other hardware is black. You have to remove the inside door panel to get at the clips.
2005 LJ Impact Orange 4.0L Automatic (Tigger) - new ride
1991 YJ Sahara 4.0L Automatic
1978 Dodge Lil Red Express - work in progress
RCHavok797 is offline
post #4 of 7 Old 04-23-2002, 05:14 AM Thread Starter
SnowMan
THanks RCHavok797, just a couple more questions
How do those saw like clips work. What tool did you use and how? When you say take the inner door of, do you mean the vinyl skin covering the metal? If this works I'll buy ya a beer.
SnowMan is offline
post #5 of 7 Old 04-23-2002, 05:57 AM
RCHavok797
RCHavok797's Avatar
The clips are smaller at one end and just push up tight against the handle to lock it into place. There is one on each side. Yeah I mean the vinyl peice covering the inside part of the door so you can access the handle. You should be able to pull the clips down with a pair of pliers. I believe there is a small hole in the bottom of the clips that you could put something in to make pulling them out easier like a pair of pliers with bent tips. It is kind of a pain only because it's hard to see what you are doing. The hole that you have to work through is below the handle. Use plenty of light.
post #6 of 7 Old 04-24-2002, 04:40 AM Thread Starter
SnowMan
RCHavok797,
I got'em out They worked just like you said but instaed of those clips slidding down, mine slide up and hit the window sill. A little force and they came cleanly out. Look like I owe ya a beer, if your ever up in canada, you can try some canadian brew. Thanks Again
SnowMan is offline
post #7 of 7 Old 04-25-2002, 06:11 AM
RCHavok797
RCHavok797's Avatar
I'm glad it worked out for you.
should I keep the full steel doors or the half doors or both???? asjeep General Discussion 20 09-09-2013 04:00 PM
Half doors or full doors? jeeptillidie General Discussion 44 03-30-2007 04:42 PM
are all TJ full doors and hardtops exactly the same? Bot General Discussion 6 03-16-2007 11:35 PM
how much are my full doors worth? snellav General Discussion 10 02-16-2007 05:21 PM
Painted the flairs & door handles ...lots of pics. BIG_KID General Discussion 4 01-06-2007 06:25 PM
