don't use a 4' cheater bar with a 3/8" ratchet and extension (pics!!!)
#1 | ||
just as the title says....
while i was putting on the lift, i couldn't get the main spring eye bolt out, so we got a 4' cheater bar and extension and tried to break the bolt loose.... well the extension snapped and flew across the garage and almost killed me..... ![]() ![]() the bolt was stuck so badly i had to get a giang monkey wrench, strap it up to the bolt, then use a floor jack to rotate it to break the bolt.... ugh
-Shayan A.K.A: Sean Quote:
#2 |
Junior Member
If it wasn't for 4' cheater bars on 12" extensions on 3/8ths sockets, nothing would ever get done in my garage. Never had one fly though. I usually end up doing all the flying, with the occasional cartwheel. Me and my brother are the case against lifetime guarantees.
#3 |
I've done that. I also twisted the head off a grade 8 bolt that way with a long breaker bar!
#4 |
not a cheater bar a persuasion tool
[URL=http://photobucket.com/albums/v90/nukethefishes/]Jeep[/URL] |
#5 | |
Poland and PPV!!!!
Had a similar experience with a 36mm socket, a 3/8 to 1/2 adapter and a 3ft bar. Almost lost an eye and my knuckles.
-Craig- 95 Rio Grande 07 Ram 1500 SIRA4x4 Club Quote:
#6 |
I have found that 1/2" drive sockets are well worth the money, nothing life threatning but I havehad stuff go flying before as well
#7 |
Sounds like an average day in our shop, the broken tools are starting to out number the good ones
5 % of people make things happen 65% of people let things happen 30% of people say "what happened?" |
#8 |
I woulda said, "Screw it."
Time to break out the sawzall.
Last Jeep: 98 Sport TJ Red Jeep 1st Jeep: '86 CJ-7 (I miss her) BigYellaJeep Latest Vette: '68 Corvette Convertible Blue Vette |
#9 |
i wear foil underwear too
i've never had it happen, not even on the willys.
a good (overnight) soak in penetrol, a bit of heat (sometimes), and the proper tool with the proper technique seems to get it done. lj
ಠ_ಠ |
#10 |
i watched my uncle twist the threaded shank of a 2" receiver ball off once with a 24" breaker bar....that is a lot of stainless steel to twist around.. leverage is amazing
Gone but not Forgotten: 1990 Islander O.D. Green Currently no Jeep, but I'm in the market |
#11 |
impact gun
87 YJ sbc,th350,33's, rusting away in some junkyard 91 YJ 4" ,33's, most likely rusting away somewhere 97 TJ 4",33's,full skids, driven daily 07 JK Rubi,2.5",35's, wheeled hard, traded in 07 JK Unlimited Rubi,2",35's,RiverRaider skids & cowl snorkel |
#12 |
Last time a bolt gave me trouble, I used a defensmans lacrosse stick (6 feet). Broke through a few stripped lugnuts like butter.
-Shawn |
#13 |
I have about a 4 foot long piece of steal tubing thats thick as hell and weighs about 15lbs. Yeah.... that and my impact are my best friends
#14 |
Yellow Jeep Club Member #3333 Fortune favors the bold. |
#15 |
Ive BLOWN UP the head on 1" cap screw at work. The screw was stuck in a mold base so we put about 10' of pipe on it with 2 or 3 guys on the end of it pushing
'97 XJ (here comes the typical list) 3" rustys full pack, Rock Krawler tracbar, 31x10.5 Kumho kl71, CIK, dynomax super turbo muffler, IPF h4 conversions, silverstar bulbs, hella 530 fogs, olympic 4x4 rock front bumper, tcase drop, bush hacker flares, OEM tow hook brackets with GM hooks |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
