Do I need a cable box for my tv? - JeepForum.com
post #1 of 19 Old 07-08-2013, 08:54 PM Thread Starter
AlTheKillerr
AlTheKillerr's Avatar
just got cable for the first time in 5 years or so (free upgrade) and I plugged the cable from the wall into my tv and I get nothing. Its a samsung LCD tv. Where the cable screws into the tv it says Ant In on it so Im thinking its not meant to be the cable in spot but there isnt anywhere else that I can screw that kind of cable in.
Photographer
AlTheKillerr is offline
post #2 of 19 Old 07-08-2013, 09:49 PM
jbolty
jbolty's Avatar
Unless the tv is from the 70s or older there should be a menu choice for ant or cable. If that fails dig up and old VCR and use that tuner.
jbolty is offline
post #3 of 19 Old 07-08-2013, 09:51 PM
Rubi Unlimited
Depends on if your cable company encrypts their entire line up, if so then yes even a brand new television would require a converter to decrypt the signal. Your television should have an antenna/cable option within the menus select cable and then run auto-program.
Cleverly disguised as responsible adult.
Rubi Unlimited is offline
post #4 of 19 Old 07-08-2013, 09:59 PM
jbolty
jbolty's Avatar
good point. I wonder how a normal tv reacts to digital cable?
jbolty is offline
post #5 of 19 Old 07-09-2013, 06:17 AM Thread Starter
AlTheKillerr
I ran the auto tune in the cable setting and got nothing :/
Ill dig out a vcr and go through that and see what happens. I did a little reading and it almost seems like I would have to have the vcr/cable box plugged into the cable outlet from the wall then either the green/red/yellow cables from that to the tv or an S-video cable.
Its just basic cable so local channels. I figured it would be as easy as plugging the tv in and its good to go. maybe the cable company didnt lift the restriction yet even though they said they were going to by sunday evening.
Photographer
post #6 of 19 Old 07-09-2013, 08:38 AM
Indy
Indy's Avatar
There are only a handfull of tv's that have built in tuners, a handfull more that have a spot to plug in a convertot card provided by a cable company. 99.999999% of tvs will need a box unless your cable company is running tech from the 80's.
I'm the only gay eskimo.
Indy is offline
post #7 of 19 Old 07-09-2013, 10:19 AM
YJames90
YJames90's Avatar
Ahh, the good old days of analog cheater boxes and free cable
My 2.5 to 4.3 swap thread
YJames90 is offline
post #8 of 19 Old 07-11-2013, 06:19 PM
r.71
2015 JK Wrangler
I know back in VA, Comcast scrambled all of their channels and requires a box even for basic channels. Here in TN Charter does not yet require a box
Randy
r.71 is offline
post #9 of 19 Old 07-12-2013, 04:45 PM Thread Starter
AlTheKillerr
got a VCR for free from my old man and I got the cable hooked into it, then to the TV. Ran auto program on the TV and it found channel 4 (which is the channel the VCR is set to) from there I went into the VCRs menu and ran auto program and it doesnt pick up any TV channels. So I either have to have a cable box or they never gave me my cable
This is dumb. It should just go from wall to TV and thats it. Why do I need another ****ing box sitting on my TV stand?
Photographer
post #10 of 19 Old 07-12-2013, 05:33 PM
2006_Sport
Pretty sure all tvs need a box now. Just cant run them into the wall
2006_Sport is offline
post #11 of 19 Old 07-12-2013, 09:44 PM
TSEJEEPERS
The cable company should give you a box.
Welcome to 2013.
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is offline
post #12 of 19 Old 07-12-2013, 09:49 PM
sjones26573
No box required for normal Time Warner. We have Digital Cable running off a box in the living room and regular cable on the flatscreen in my room with no box. A VCR will not work for digital cable.
The Offroad Club @ NC State; Founder
The Yellowtail Build
Jeep-Owner.com
sjones26573 is offline
post #13 of 19 Old 07-12-2013, 11:18 PM
chowner
2014 WK
Most likely yes. If Comcast yes for sure
chowner is offline
post #14 of 19 Old 07-13-2013, 01:13 AM
PhilipJ
PhilipJ's Avatar
Still need a box for cable HD channels...kind of pointless to have a flat screen these days for anything SD.
PhilipJ is offline
post #15 of 19 Old 07-13-2013, 10:44 AM
chowner
2014 WK
Not always the case.
chowner is offline
