Dielectric Grease debate - JeepForum.com
post #1 of 23 Old 06-06-2015, 03:14 AM Thread Starter
jeepnoob2000
There does not seem to be a consensus on whether to apply dielectric grease to spark plug terminals or not.
I for one have been changing my spark plugs and lathered up the plugs pretty good including the terminal, as was recommended. Now I'm finding out that may not be right. I haven't started the jeep yet. Should I remove the plugs again and clean them off? (plus the inside of the coils will be slathered) :
jeepnoob2000 is offline
post #2 of 23 Old 06-06-2015, 04:18 AM
mike_dippert
mike_dippert's Avatar
It's fine. Spark plugs are probably the singke most common application of dielectric grease. The grease creates a weather seal so the metal contacts don't corrode. It also helps slide the rubber boot over the ceramic part of the plug, and helps prevent them from sticking together after 30k miles or more.
mike_dippert is offline
post #3 of 23 Old 06-06-2015, 06:50 AM Thread Starter
jeepnoob2000
I've heard that the dielectric grease on the spark plug terminal will create resistance and possibly cause overheating or misfiring ? I've only replaced half the spark plugs so far, should I keep lathering the terminals with dielectric grease or no?
post #4 of 23 Old 06-06-2015, 07:04 AM
festerw
festerw's Avatar
Never seen overheating or misfires caused by dielectric grease. I think or would take a very specific set of circumstances for either of those to happen.
Hers - 2011 Dodge Durango Crew
Mine - 2003 Jeep Wrangler X
1998 Jeep Cherokee Classic
festerw is offline
post #5 of 23 Old 06-06-2015, 07:11 AM
mike_dippert
Keep going. You really only need it around the boot.
*If* it were to cause a problem, it would be because it is interfering with the metal-metal contact between the plug and wire. That would likely result in a misfire, and a related check engine light. The fit is tight enough to squeeze out the grease from the contact area 99% of the the time.
post #6 of 23 Old 06-06-2015, 07:18 AM Thread Starter
jeepnoob2000
well the point is that dielectric grease is supposed to be a nonconductor or electric insulator, so having a thin layer between the terminal and coil contact would create extra resistance, in theory. I'm a bit of a perfectionist and tend to err towards "better safe than sorry"... just don't want to hurt my car with spark plug electrical resistances! On the other hand, if it is well-known to not be a problem then I would just disregard it.
post #7 of 23 Old 06-06-2015, 07:21 AM Thread Starter
jeepnoob2000
yea the metal-to-metal contact is what I'm concerned about, and I put dielectric grease all over it. It appears to just be a spring inside the ignition coil that contacts the spark plug terminal
post #8 of 23 Old 06-06-2015, 07:36 AM
ravenworks
Just use it as you have been and move on,no harm done.
We use it on everything and I mean everything in heavy equipment.
Semper-Fi "81-84"
I.U.O.E. - 18
ravenworks is offline
post #9 of 23 Old 06-06-2015, 02:13 PM
CoriolisSTORM
WHAT?!
CoriolisSTORM's Avatar
2010 JK Wrangler
Back before I learned anything about electricity (well a lot about it anyway), I had problems with my dashboard like most TJs caused by a bad connection to the pins. I went to the local auto parts store and asked for something that was electrically conductive to put in each pin to solve my issue. Well, the idiot gave me dielectric grease... That worked... well, not at all...
1998 TJ Wrangler SE - Stone White, 2.5Ls of screaming lifter clacking power, AX5, 31" BFGoodrich All Terrain T/A KOs
2010 Wrangler Unlimited Sahara - Deep Water Blue, 3.8Ls of oil consuming fury, NSG-370, BFGoodrich Rugged Terrain T/A 265/70/R18s
CoriolisSTORM is offline
post #10 of 23 Old 06-07-2015, 07:13 PM
y2k-fxst
1964 CJ6
Used it on every plug I've changed in the last 30 years with no ill effects. Actually they send a packet with every set of plug wires I ever bought. I use the heck out out of dielectric grease on trailer wiring connectors.
I own a Harley and a JEEP, still some people can't figure out why I'm broke!
y2k-fxst is offline
post #11 of 23 Old 06-07-2015, 07:23 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
The proper application of dielectric grease is for it to seal the wire connector, or repel water from a spark plug boot, but not get on the actual metal to metal electrical contacts. 99.999 % of time, it really doesn't matter.
CJ7-Tim is offline
post #12 of 23 Old 06-09-2015, 05:02 AM Thread Starter
jeepnoob2000
Well, half of the spark plugs have dielectric grease on the terminals and half of them don't, so far running smoothly!
So is there an 'opposite' to dielectric grease that would actually HELP conductivity on the terminals?
post #13 of 23 Old 06-09-2015, 05:09 AM
vadslram
the only way Dielectric grease would make it misfire is if the connections are loose anyway. If the connector is tight there will be metal to metal contact and the grease does not interfere. Plus by keeping moisture and oxygen away from the connection you will prevent corrosion that does cause misfires.
I use dielectric on my outboards, snow mobile, tractor, lawn equipment, and Jeep, been doing it since I first heard about it decades ago and I have never had a problem with misfires caused by the stuff.
vadslram is offline
post #14 of 23 Old 06-09-2015, 06:42 AM Thread Starter
jeepnoob2000
yea but do you actually put it on metal-to-metal contacts? or just near/around them?
post #15 of 23 Old 06-09-2015, 07:43 AM
mike_dippert
Conductive grease/paste does exist.
Don't use it unless you know you're suppose to. It can cause shorts, fires, or electrocution if used improperly.
