Demand for a searchable image database? - JeepForum.com
post #1 of 8 Old 05-09-2012, 09:47 AM Thread Starter
econstantin
Hi all, I'm new to the Jeep community and think it's awesome how much support and sharing goes on between people. While I'm still learning a lot about building a rig, I build websites/systems for a living. I have this idea and am wondering if you think it be a good idea and worth doing.
I notice a lot of people request photos of a particular rig setup (i.e. TJ w/4" SL on 33s) -- often there are some good photos in thread, however it's not always evident what to search for across treads, and photos are usually interspersed with other comments.
What if you could do a search based on for model, lift types, wheel sizes, etc. and get the results in the form of a photo gallery of matching rigs?
I think it'd be relatively straightforward to build a basic website to allow this, a possibly even an iPhone app to allow people to quickly & easily take a photo, tag it with appropriate rig-info and upload it directly.
Anyways, would like to hear your thoughts / feed back on this idea.
econstantin is offline
post #2 of 8 Old 05-14-2012, 06:48 PM Thread Starter
econstantin
If it wasn't clear from my original post, I'd be happy to build out the site/app -- I'd just need some community input/feedback.
post #3 of 8 Old 05-14-2012, 06:53 PM
WhiteOut
WhiteOut's Avatar
There is already a pic request forum and threads in every model forum for lift height/ tire combos.
WhiteOut is offline
post #4 of 8 Old 05-14-2012, 11:34 PM Thread Starter
econstantin
Yeah, I'm aware of that -- this would simply make it easy to find all pics matching whatever criteria (instead of lots of clicking/scrolling around)
post #5 of 8 Old 05-14-2012, 11:41 PM
Indy
Indy's Avatar
Garbage in, garbage out. Most folks aren't going to supply the correct data, in the correct order, spelled correctly, to make a good searchable database. Not a bad idea, but pretty massive undertaking really unless ai has made a massive leap forward since the last time I programmed an array.
I'm the only gay eskimo.
Indy is offline
post #6 of 8 Old 05-15-2012, 12:01 AM Thread Starter
econstantin
Good point, and taken. I envisaged using drop-downs to minimize the data-entry & possible typos; there would indeed be some work involved to get comprehensive drop-down lists, but much of it could be automated without too much difficulty...
post #7 of 8 Old 05-15-2012, 12:59 AM
Indy
Indy's Avatar
If there was only a limited number of options actually available it would be doable, but even store bought the drop down would be pretty long. Add In a lot of fab and the results get pretty slim. You could go flat generic, model cj5/cj7/yj etc, then lift by 1/2" increments same with tire size, but you would end up discounting long vs short, a bunch of things like elipticals, spoa vs spua, etc
At the end of the day, it's not a complex search to program, but the number of variables would yield poor results unless you had thousands of entries since a bunch of what was actually being looked for would never make it to the results page. It's a good idea and easier than most problems I used to code for but it would be hard to implement.
You would end up with a lot of what I asked for but not what I meant, and people on the Internet are lazy. They as a whole would rather be spoon fed by asking an easy to search question than taking 5 seconds to search so it would likely rarely be used.
Indy is offline
post #8 of 8 Old 05-15-2012, 12:17 PM Thread Starter
econstantin
Yes, it would start with limited search options to constrain the problem. In looking at the various pic request threads, it seems that around 60% of requests are for model + tire-size + lift, which suggests that there would be some utility to being able to filter by even these basic criteria.
I agree that people don't want to deal with things that are complicated, I also think that people can be motivated to select a couple search criteria if the perceived benefit is there (think used-car search sites, they have lots of options to search against). Indeed, the key to success would be a very quick and easy user interface/experience.
It sounds like overall you think this would be a good idea if designed/implemented properly (which, I agree, is not without certain challenges)....
Anyone else think yay or nay?
