deck restorer as bed liner - Page 2 - JeepForum.com
post #16 of 17 Old 01-14-2014, 01:30 AM Thread Starter
Indy
Indy's Avatar
My phone needs therapy
I'm the only gay eskimo.
Indy is online now
post #17 of 17 Old 02-22-2014, 10:48 PM Thread Starter
Indy
Indy's Avatar
And the in use testing has started
Scotch scuff pad followed by some simple green and some time at the car wash.
Then 1st coat using the grey. It dries a few shades darker, and my camera lightens things a bit.
Dried, color wise its somewhere between the back and the bed.
Using the restore roller, plenty of texture.
2nd coat, i went with a really dark green when dry. Its setting now and ill be leaving it alone for a bit. Temps are low and being water based dry time will be extended a bit.
It looks really good, time will tell how it holds up. I ended up using about 3/4 a gallon on the 1st coat. 2nd went on a bit thicker and i used all but an inch or so. So 2 gallons would have done it with plenty left over. So if things work well, $50 for a colored bedliner vs $100 for black vs $1500+ for a spray in.
Or worst case and im out $50 on my $200 truck.
Indy is online now
