Custom PC Build - Page 74 - JeepForum.com
post #1096 of 1105 Old 04-30-2009, 12:30 PM
--chris--
--chris--'s Avatar
Jay, any updates on the business plan?
I got some helpers if you have not already hired people. Dont skimp on your site, appearing to be a large professional, well run business is a whole hell of a lot easier to do online than it is with a 'brick & mortar' business so use that to your advantage as much as possible.
--chris-- is offline
post #1097 of 1105 Old 05-23-2009, 06:40 PM
NewdRiver_
Finally have some time to work on this.
My current mess...
NewdRiver_ is offline
post #1098 of 1105 Old 05-23-2009, 11:20 PM
ErikJordan
Pimp Hand
ErikJordan's Avatar
i have some parts for sale, if there is ant interest, shoot me a pm.
P5K64 WS
Specifications:
CPU:
Socket 775 for Intel Core2 processors / Pentium D / Pentium 4 / Celeron CPU
Support Intel 65nm, Core 2 Extreme/Core 2 Duo
Support Intel next gerneration Multi-core CPU
Intel EM64T / EIST / Hyper-Threading Technology
Support Intelr next generation 45nm Multi-core CPU
* Please update the latest BIOS to support Intel 45nm CPU
Chipset:
North Bridge: Intel MCH P35
South Bridge: Intel ICH9R
Front Side Bus: 1333/1066/800 MHz
Memory:
4 x DIMM, max. 8GB, DDR3 1333/1066/800, non-ECC un-buffered memory
Dual channel architecture
Expansion Slots:
4 x PCI-E x 16 slots
2 x PCI 2.2
Storage:
Intel ICH9R controller: 6 x SATA 150/300 (RAID 0,1,10,5)
Ext SATA controller:
2 x eSATA 150/300
1 x ATA
Audio:
RealTek ALC888, 8 channels Azalia Audio codecs
Multi-Streaming
Jack Sensing and Enumeration
Jack Retasking
S/PDIF Out interface
LAN: Marvell 88E8052/88E8001 Dual Gb LAN
USB 2.0: 12 x USB 2.0/1.1 ports
BIOS:
16Mb flash ROM, AMI BIOS, Green, PnP, DMI v2.0, Wfm2.0, ACPI v2.0a, SMBIOS v 2.3, EZ flash2, CrashFree BIOS3
Manageability:
WOL by PME, WOR by PME, PXE, AI NET, Chassis Intrusion
BIOS flash utility under DOS
Support Disc:
AI Booster
ASUS PC Probe II
Symantec NIS 2006
Adobe Acrobat Reader ver 7.0
Microsoft Direct X ver 9.0C
Form Factor: ATX Form Factor, 12"x 9.6"(30.5cm x 24.5cm)
O/S Compatibility: Windows Vista/XP
KINGSTON value ram KVR1333D3N9K2/4G 4gb kit (2gb x 2) match pair 1333mhz cl9 240-pin ddr3 dimm
OCZ DDR3 PC3-10666 Gold Edition
1333MHz DDR3
CL 9-9-9-26
(CAS-TRCD-TRP-TRAS)
Available in 1GB and 2GB dual channel kits
Unbuffered
Gold Layered Z3 XTC Heatspreader*
Lifetime Warranty
1.7 Volts
240 Pin DIMM
Special Features
1.9V EVP**
Part Numbers
1GB Module PN - OCZ3G13331G
2GB (2x1024MB) D/C Kit PN – OCZ3G13332GK
Model
Brand Intel
Processors Type Desktop
Series Core 2 Quad
Model BX80569Q9550
CPU Socket Type
CPU Socket Type LGA 775
Tech Spec
Core Yorkfield
Multi-Core Quad-Core
Name Core 2 Quad Q9550
Operating Frequency 2.83GHz
FSB 1333MHz
L2 Cache 12MB
Manufacturing Tech 45 nm
64 bit Support Yes
Virtualization Technology Support Yes
Multimedia Instruction MMX, SSE, SSE2, SSE3, SSE4, EM64T
Voltage 0.85V – 1.3625V
Thermal Power 95W
Cooling Device Heatsink and Fan included
Manufacturer Warranty
Parts 3 years limited
Labor 3 years limited
___________________________________________
What is all of this talk of Savvily designed products?
ErikJordan is offline
post #1099 of 1105 Old 01-23-2010, 05:54 PM
table
table's Avatar
2015 JK Wrangler
Thread from the dead!!!
So that Seagate 500GB HD that I purchased has the now-infamous 7200.11 firmware bug - BSY error. Yay!
This issue was going around at my time of purchase (Jan 09). Had I done some searching, I would have gone with a different HD. I'm surprised it lasted this long.
Found some hopeful ways to get it back to life, via a Nokia CA-42 cable. Gonna try that trick as soon as it comes in the mail.
Luckily I back up. All I'm out is a few iTunes songs and some test photos. Seagate does cover this problem, however I still don't trust my data going off in the mail.
2015 Anvil JKU | Sahara | Manual | 3.73
RIP: 2000 WJ | Initiated Destruct Sequence One | Code: 11A
table is offline
post #1100 of 1105 Old 01-23-2010, 06:36 PM Thread Starter
bman9089
bman9089's Avatar
I had the EXACT same problem awhile back.
http://www.jeepforum.com/forum/f7/ha...advice-925008/
I sent the drive off to California and got it back within a week. No problems and no cost from my end. I would recommend it. I just popped it back in and booted up without any issues as if it never failed to begin with.
"The American Republic will endure, until politicians realize they can bribe the people with their own money." -- Alexis de Tocqueville
“Sometimes I wonder whether the world is being run by smart people who are putting us on or by imbeciles who really mean it” -- Mark Twain
Romans 12:5 | 1 Peter 3:15 | Matthew 9:37-38
bman9089 is offline
post #1101 of 1105 Old 01-23-2010, 06:45 PM
NewdRiver_
I recall buying the same hard drive as both of you. No problems with it so far, but it is no longer my primary drive. Booting from RAID 0'd OCZ Vertex 30GB SSDs now.
I will keep my eye open for problems though. What happens when it goes kaput? Any warning signs?
post #1102 of 1105 Old 01-23-2010, 06:47 PM
table
table's Avatar
2015 JK Wrangler
I saw/heard no signs. Just didn't start up a few days ago. Spins, but not recognized. If you've got one of these HDs, I would download the newest firmware ASAP.
table is offline
post #1103 of 1105 Old 01-23-2010, 09:58 PM Thread Starter
bman9089
bman9089's Avatar
If you can do a firmware update, do it now. It's a matter of time otherwise, and it shows no warning signs. I turned mine off, booted it up, and windows froze and bam - it bricked itself. It's a ticking time bomb waiting to happen. Luckily if it does happen it's a free and easy fix, but you'll be out of a drive for about a week if you need to send it off to Seagate.
bman9089 is offline
post #1104 of 1105 Old 01-24-2010, 02:23 AM
PhilipJ
PhilipJ's Avatar
I couldn't even initialize and format my 1.5TB's before doing the firmware update.
PhilipJ is offline
post #1105 of 1105 Old 01-26-2010, 01:54 PM
table
table's Avatar
2015 JK Wrangler
Performed the cell phone cable trick and issued commands via HyperTerminal. (LOL). Installed new firmware and back to normal. Took the time to do some much needed cleaning and dust removal.
table is offline
TheGillz Custom Trailer Build TheGillz Trailers & Towing 49 08-06-2009 05:56 AM
Custom RV questions. -Zona- General Discussion 6 06-04-2009 09:47 AM
custom sigs bigern26 General Discussion 6 09-02-2008 12:18 AM
Custom made H1 Jeep25 General Discussion 15 02-18-2008 10:19 AM
Expedition Landcruiser driven from Germany to Oman - very cool custom build Oman Jeep General Discussion 3 04-06-2006 04:43 PM
