Custom exhaust fan - JeepForum.com
post #1 of 3 Old 05-13-2013, 02:16 PM Thread Starter
zander21510
Custom exhaust fan
So I bought my parents a new microwave (old one was 23 years old, no turntable, burned half of everything with other half frozen), that I had to fit in the old trim kit. It's a close fit, but there's about a 2 inch gap + about 2 or 3 inches of trim kit.
I tested the microwave for ventilation by running it for 10 minutes to cook my lunch. Steam was coming out the cracks on the bottom and I could feel the high heat sticking my hand into the gap on top, so I figured the best solution would be to build a custom grille with some 60mm fans to help pull the hot air out. I need it to do this:
-Fans turn on only after a certain temperature is reached at the microwave exhaust.
-Microwave remains plugged in 24/7.
My thoughts on equipment:
-Temperature sensor switch that provides power to fans after a set temperature is reached
-System uses standard electrical outlet
What kind of equipment would I need to achieve this?
zander21510 is offline
post #2 of 3 Old 05-13-2013, 03:59 PM
festerw
festerw's Avatar
Instead of temp sensor how about a smart power strip that would just turn the fans on when the microwave is running?
Something like this
http://www.amazon.com/gp/aw/d/B000P1...pi=SL500_SY125
Hers - 2011 Dodge Durango Crew
Mine - 2003 Jeep Wrangler X
1998 Jeep Cherokee Classic
festerw is online now
post #3 of 3 Old 05-13-2013, 05:56 PM
That1guy
That1guy's Avatar
2007 WK
You need this. http://www.amazon.com/All-purpose-Te.../dp/B00862G3TQ Wire it up into a plug in and when it hits a certain temperature it will kick on a circuit.
Watch video
I'm forever grateful to Speedycat and RnEmOvr for their generosity
That1guy is offline
