Corn Snake care advise needed - - humidity control
#1 | |
I picked up my first snake yesterday. A little 2 month old Corn snake. I've got his cage all setup as per various instructions. Even got him to eat his first dead baby mouse this afternoon
. He seems to like being held (not holding him for 48 hours after he's eaten) and he is alert and seems to be in good health.The one thing I'm having a tough time with is keeping the humidity in the cage regulated. He's in a 10 gallon tank, with bark substrate. I have a heating lamp and pad under one end (lamp during the day, pad at night) Since I live in a high desert our ambient humidity here is around 35% I can keep the tank around 50% during the day with the water bowl, and a wet washcloth on top of his hiding log. At night, I cover more of the top and the humidity seems to go up to about 75 - 80% which is more ideal. Is this going to bother him too much? I've got the heat pretty well maintained. At the cool end of the tank it's a consistent 80* during the day, and 70* at night. I leave the lamp on in the day, and it gets close to 100* on the warm side, but he goes in and out of the heat if he's warm or cold. How can I keep the humidity regulated, or is it ok with the fluctuations?
No more Jeep. www.reno4x4.com |
#2 |
when i used newspaper substrate for my python i had a hard time keeping the humidity consistant (bounced from 50-70 throughout the day). I switched to bed-a-beast from petsmart (4.99 a brick, 1 brick does my 40 gallon breeder), and now my humidity is very consistant. 70-72 in the day and 62-64 in the night. If you don't want to switch substrate then try getting a water bottle and misting the back wall of the cage every 12 hours. it worked for me before i switched substrates. I don't like my humidity to fluctuate more than 10%, and that is based off of absolutely nothing, it is just how i prefer it to be. this is my first snake and I have only had him for a month but so far he seems to be happy and healthy.
1999 Cherokee Classic 4.0 aw4 242 30 8.25 3 inch coils, 3.5 inch RE leafs, HnT, 31 inch A/T's, 6.75 components, 1.25 tweeters, 600w 2 channel, 2x 12 inch subwoofers, 1800w mono, 6.5 3 ways Stroker build/8.8 swap in the works |
#3 |
Cigar storage is all about humidity and temperature regulation...I would say, when in doubt look for an analogous system.
'91 XJ Laredo Rustys 3" Coils Frankenleef rears||DT3000 shocks||JKS Quicker DQ Optima Red Top||Mixin' match 31x10.5x15|| Rusty's HD Trac Bar |
#4 |
Cigar humidors are usually somewhat sealed as to not let air flow in and out. With a live animal, you typically need to provide fresh air. That being said, I live in FL and the humidity here is usually pretty high. I have 2 pythons in a 40 gallon breeder. Just keep a large water bowl in there. If the humidity drops too low, the snake will just go for a swim to better hydrate its skin.
96 XJ 4.0L/AX15/NP231/AUSSIE'D D30/C8.25/4.5" RE LIFT/33'S/BUMPERS, SLIDERS, ETC... "I pitty the fool who lists D30's and 31's, then tries to talk **** on PBB": Originally Posted by Durt_Diver:
Those pics might be a little too flexy for this thread. You don't happen to have any pics of your friends xj on a curb by chance? |
#5 |
A humidor would not be recommended. When I had mine I used lizard litter and it worked great. Keep in mind that I' was in central IL. But as chance stated, the bed a beast or something like it would work best for you in your situation.
'07STI '12 WK2 Overland |
#6 |
Run a humidifier in the room he's in, or get an ultrasonic piped into the cage to fog him periodically.
Never underestimate the power of stupid. |
#7 |
Bizzare Guitar in Reno won't sell Taylor Guitars because they use a very thin soundboard on the spruce models, and they had problems with them cracking in the non-humidity controlled portions of the showroom. Dude in there told me the average humidity in Reno was in the single digits...7 or 8 percent. I think your 35% estimate might be high.
![]() You could use a humidifier in the room the tank is in also. Rather than just humidifying the tank, humidify the whole room.
RHD '98 XJ RE 3.5", Bushwaker Flat Flares, OR-Fab bumpers, PowerTrax locker, Sliders, Maxxis Bighorn 32's |
#8 | |
#9 |
Also, his cage is in the living room which is open and connected to the kitchen and dining room. It would take alot of humidifier-ing to get it to stay correct. Plus it'd feel like I was walking around in a jungle
#10 |
You could also give the tank less airflow to increase humidity. Just don't cut off airflow.
#11 | |
Taylor
01 Cherokee 4.5 in. lift w/31s |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
