Connecting computer to a TV? - JeepForum.com
post #1 of 16 Old 01-05-2010, 05:17 PM Thread Starter
_TIM_
Hey guys i was hoping someone might be able to help me out with this. I recently got a new 32in Samsung Tv for my Bday and found out it can be used as a monitor for my Macbook pro, the only problem is I have no idea how to connect the two. I went out and got a cable that connects from the tv to the laptop and switched the source on the tv to PC, but nothing happens when I connect it. Is there some kind of button I have to hit to switch the screen to the tv? Also, will I have to change the resolution on the laptop to acomidate for the larger screen? Any and all advice is appreciated.
-Tim
1998 tj|chili pepper red|
_TIM_ is offline
post #2 of 16 Old 01-05-2010, 05:26 PM
Otahyoni
Otahyoni's Avatar
1986
My laptop has a S-Video out, so thats how i connect my TV. And i have to change the resolution on the TV to match the screen size, but i dont have to change the laptop.
~Chris
And all of the diodes may have committed suicide, leaving you with a fun whirly thing under the hood that produces nothing.
Otahyoni is offline
post #3 of 16 Old 01-05-2010, 05:30 PM
EarpWJ
I dont know on a mac, but on most/all PC laptops theres a function button to switch display output on the lap top, like check your keyboard, there might be some button with two overlapping squares.
EarpWJ is offline
post #4 of 16 Old 01-05-2010, 05:31 PM
jb4
one the tv which of the following do you have?
VGA port (blue connector)
DVI port (white connector)
HDMI port (small black connector)
then which macbook pro do you have? if its one that has a display port then you need
Mini DisplayPort to DVI Adapter - Apple Store (U.S.)
which is an apple display port to DVI adapter - you can then hook it up to the DVI port directly or the HDMI port with a DVI->HDMI adapter
HDMI Cable, Home Theater Accessories, HDMI Products, Cables, Adapters, Video/Audio Switch, Networking, USB, Firewire, Printer Toner, and more!
if you only have a VGA port (unlikely) here is the apple display port to VGA adapter
Mini DisplayPort to VGA Adapter - Apple Store (U.S.)
honestly S-Video isn't worth the time or hassle any more because the quality is such crap and 99.99% of HD TV's have a DVI/HDMI port and most have a VGA port
edit:
On my macbook when you connect the cable with the TV on it will automatically work - so what port are you hooking up to and just for giggles - whats the model number of the Samsung TV - I've seen some sets that have DVI ports but will not accept input from computers (stupid, I know)
jb4 is offline
post #5 of 16 Old 01-05-2010, 05:37 PM
waterboarder
waterboarder's Avatar
Need more info. Go to the Displays control panel on the Mac. See if it is detecting the TV at all. If it is, play with the resolution settings. Also, make sure you have the TV set to the right input. The connector you are connecting to should be labeled something like "video 1", "video 2", etc. Make sure the TV is set to whatever it is. Report back.
You're assuming he has a TV with a DVI port. That may very well be the case, but he doesn't say in the OP.
Same comment above.
Not everyone has an HD TV or a TV with a DVI/HDMI port, or even a VGA port. We don't. But the S-Video connection to the laptop works great when streaming movies from Netflix.
waterboarder is offline
post #6 of 16 Old 01-05-2010, 05:39 PM
Pvt_Joker
You most likely have to go to display settings and change your output.
Pvt_Joker is offline
post #7 of 16 Old 01-05-2010, 05:41 PM Thread Starter
_TIM_
Wow thanks for the quick responces guys, looks like I have to look at some things when i get home from work tonight I will be sure to report back.
_TIM_ is offline
post #8 of 16 Old 01-05-2010, 05:43 PM
jb4
Originally Posted by waterboarder View Post
Need more info. Go to the Displays control panel on the Mac. See if it is detecting the TV at all. Also, make sure you have the TV set to the right input. The connector you are connecting to should be labeled something like "video 1", "video 2", etc. Make sure the TV is set to whatever it is. Report back.
Same comment above.
he said its a brand new Samsung 32" tv - they dont make a single 32" CRT set so I'm safely going to say he has one of the three ports I mentioned.
jb4 is offline
post #9 of 16 Old 01-05-2010, 05:45 PM
waterboarder
Well, if you happen to know Samsung doesn't make CRT TVs, then there you go.
post #10 of 16 Old 01-05-2010, 05:47 PM
jb4
I said they did not make a 32" CRT
http://www.samsung.com/ae/consumer/t...getype=subtype
even their "slim fit" quasi CRT's dont come in 32"
jb4 is offline
post #11 of 16 Old 01-05-2010, 05:48 PM
waterboarder
Do you happen to know which cable you used to hook up to the TV? Did you use any little "pigtail" adaptor from Apple? That's generally the most pain-free route. We use the s-video pigtail for my wife's laptop and it works great. They make similar adapters for other kinds of TVs. Note that simply making a physical connection often isn't good enough, because the video card in the computer may not put out a TV-compatible signal (this is particularly true with VGA connections). Even though you may physically be able to connect it, doesn't mean it will work without an adapter.
post #12 of 16 Old 01-05-2010, 05:49 PM
waterboarder
OK, well, if you happen to know Samsung doesn't make 32" CRT TVs, then there you go.
post #13 of 16 Old 01-05-2010, 05:50 PM Thread Starter
_TIM_
I believe I have a vga out from the tv and the "pigtail" that was mentioned from the mac to another vga input on the end of the "pigtail"
_TIM_ is offline
post #14 of 16 Old 01-05-2010, 05:52 PM
waterboarder
OK, in that case, you want to make sure the TV is using the correct "video input" as I noted above (and since you set it to PC, it may be), and check to ensure the Mac detects the tv as an additional display, and set the resolution to something that works with the TV. Most likely, if you set the tv to "PC" input and fiddle with the Displays control panel on the Mac, you'll get an image of some kind on the TV.
post #15 of 16 Old 01-05-2010, 10:14 PM Thread Starter
_TIM_
Sp I got home and plugged the computer in and wouldn't ya know, it worked. I played around with the resolution a bit and it looks great. Thanks for all the help guys
_TIM_ is offline
Help connecting to Xbox Live jccJeep General Discussion 3 12-25-2009 07:32 PM
I need help connecting my GPS to my laptop tacweapon General Discussion 5 09-06-2009 09:06 PM
connecting 2 computers? RnEmOvr General Discussion 7 05-20-2009 05:18 AM
Connecting PC to internet AlTheKillerr General Discussion 21 11-04-2008 07:58 PM
connecting two nylon straps Mindvirus Trailers & Towing 4 10-12-2007 04:07 PM
