#1 | |
Jeep Addict
Computer Problem
Does anyone know how to access system restore on windows XP right as the computer starts up? My moms computer has some type of problem that causes some strange spyware program to run right after the computer loads and if you try to do anything (ie. access the start menu) it shuts down and reboots. So I thought if I could access system restore right when I turn the comp on and do not let it get fully loaded, I may be able to restore it to a previous date? ANy ideas?
'93 YJ (Under Construction) Previous Jeeps: '83 CJ7 '92 YJ '00 XJ '99 TJ '05 TJ Rubicon |
#2 |
Try starting windows in safe mode to see if that makes a difference. To do that, start tapping the F8 key right after the bios screen. you should then be presented with a list of options. navigate to the "safe mode" option and press enter. what safe mode does is to boot windows with only the minimum files it needs to run. from there you should be able to go through the start menu to the system restore menu.
hope this helps. |
#3 |
Inconceivable!
If that doesn't work you can always boot from the Windows CD and fix it in the recovery console, but that's a lot more fiddly.
Due to lack of interest, tomorrow has been canceled
#4 | |
+1 with system restore...If it's in the registry then system restore probably has it in the snapshot as well.. |
#5 |
If you haven't created restore points regularly then it won't be easy.
F8 before the windows start but after bios run will give you the option to start in safe mode. |
#6 |
Jeep Addict
Hey guys thanks for all of the advice. I got the computer running in safe mode, but the system restore does not seem to work. When I try to use it it basically says thats its unavailable. Also, the biggest problem is that the computer just keep restarting itself after runnin for a few minutes. So I never have enough time to try and really get the restore open or do anything else. Anyone know what is causing it to shut down repeatedly?
#7 | |
Jeep Addict
#8 |
Maybe she has a boot sector virus since the BIOS can not find the master boot record. Since she did not make an image of her HD I think she needs to do a clean install after doing a format of the C: drive
#9 | ||
google4
right click on 'my computer' -> properties -> advanced -> settings under "startup and recovery" -> uncheck "automatically restart" under system failure Quote:
what does the event viewer say under system and applications? start -> run -> eventvwr look for red circles with 'x' through them or yellow triangles with ! in them how old is the computer? did you build it yourself? seems like it could possibly be a failing power supply, in safe mode you're loading a very basic set of drivers so you're not going to be pulling a lot of power.... |
#10 |
Jeep Addict
Nothing new installed lately, and as far as I know she has not updated anything unless it was some automatic update.
The computer is at least 6 years old I think, its an HP. It runs fine in Safe Mode, these problems occur in regular start up. I will check out the event viewer and see what it says.
#11 |
Check the date stamp in the BIOS. If it is some date like OCT 14 1999 as opposed to a current date then the CMOS battery is dying and may need replacement.
#12 | |
google4
and we're not talking about a power grid issue we're talking about either a driver or psu fault, both of which will be logged in the eventviewer and will be seen by the hard lock.... |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
