#1 | ||
Universal Cereal Bus
Computer Problem
My computer had been working great, then one morning i went to turn it on and it would power up for about 5 seconds and then it would power down. It goes through POST and then turns off and sometimes it even loads windows and works for a short time but it will eventually power down. i have tried switching the ram and only using one stick but that does not seem to be the problem, i am leaning towards a bad motherboard (even though the board is only a few months old) or power supply (maybe 1 year old). any help would be greatly appreciated
2001 Cherokee Limited My Build Thread: 6" IRO Long Arms and coils, JKS ACOS, OME 4" Leaf springs w/1.5" Teraflex shackles, RC Shackle Relocation Brackets, ~34" BFG KM2, RC Quick Discos, Fox 2.0 IPF Shocks, Rear Disk Brakes, 60mm Bored TB, Cobra Injectors, Rugged Ridge Header, 2.5" Exhaust with Borla Muffler |
#2 |
Guest
yep mostly like the board or power supply
#3 | ||
Could be anything, really. Video card, NIC card, Or even the hard drive. or maybe just bad settings in the bios, try resetting it.
#4 | |
i will try resetting the bios
#5 |
I would say PS also.
Even it it was a bad card or memory the computer would only reset not shut down. KC
My Cherokee "I say we dust-off and nuke the site from orbit... It's the only way to be sure!" |
#6 |
What kind of PC/Laptop is it? ACER machines will do this with memory errors, and will give no indication what so ever of what is wrong. Before you go to the expense of a motherboard and all the hassle it takes to make Winders work with one, try removing / replacing the memory. Do this one bank at a time if you have more than one memory bank populated.
What lies behind us and what lies before us are tiny matters compared to what lies within us. [URL="http://www.smoothrivers.com"]http://www.smoothrivers.com[/URL] |
#7 |
Inconceivable!
Is your speaker hooked up correctly? Most machines will give out beeps to indicate the problem.
1 long, 2 short = graphics card. 3 intermittent beeps = faulty memory That kind of thing? I think pepsi might be right though, probably a dodgy power supply.
Due to lack of interest, tomorrow has been canceled
#8 | |||
resetting the bios had no effect
![]() Quote:
i have already tried removing and replacing the ram Quote:
#9 | |
update: i tested all of the connections on the motherboard and upon moving the computer to an easier location to troubleshoot it, it works....crazy
#10 | |
Inconceivable!
#11 | ||
#12 |
Resident McGeek
Most likely its that ****ty Power Supply you are running. Those things are horrible and don't filter out noise on your power lines. Although my first thought from your problem symptoms was something overheating or filled with dust.
Keep an eye on it for now. If you have a multimeter test the power supply rails (All of them). Also - whoever posted the beep codes earlier - those varry by motherboard manufacturer.. so nice try, but always tell people to consult their manual for their specific trouble code sequences.
Kyle - I tag stuff® 2000 Jeep XJ - Chopped / Locked Join the XJ Owners Club | Download the iMarn® iPhone App!1997 Jeep XJ - Daily Driver 2003 Dodge Ram 2500 CTD - 6-speed, 4" MBRP Turbo Back Exhaust SIRA 4x4 Offroad Association
Rule #1 - No talking about the weather! Homepage | Jeepspace Group|Twitter!|Facebook |
#13 | |
Guest
x2 one thing not to go cheap on is psu |
#14 | |
I'll unpimp your auto...
I once had a POS computer that Westwood's C&C Red Alert and Star Wars: Rebellion would corrupt the video card driver on it every time I played them. It had an onboard ATI VT3 (props to any of you that know or remember that POS or suffered its use.) And a computer depends upon a solid DC output, so your power supply could very well be a problem. Either its on or off, no inbetweens with computers voltage. Had any brownouts or anything like that lately either? That killed one of my power supplies.
#15 | |
Inconceivable!
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
