Computer guys: Acer Aspire harddrive ?? - JeepForum.com
post #1 of 5 Old 01-07-2010, 10:51 PM Thread Starter
cheepjeep96
1990 XJ Cherokee
My friends Acer Aspire one recently took a dump on him, the motherboard (where the power supply plugs into) has completely fried itself. Well, he was wondering if I had a way to recover his date. Upon inspection of the harddrive, it looks like the SAME sata / sata power has my desktops. Can I just plug it into my desktop and recover the date off that way?
Sorry if this is the wrong section.
Thanks!
Originally Posted by chance_p
i have come to the conclusion that snow kills braincells
Originally Posted by Indy
If you only have the 1 clutch however, I'd suggest keeping it if you expect to move by anything other than 1. gravity or 2. transcontinental drift. Both are time tested to work, but you might not get exactly where you want to go.
Originally Posted by cheapfix View Post
Scanner? You don't even have doors... :p
cheepjeep96 is offline
post #2 of 5 Old 01-07-2010, 10:59 PM
perfectcircle
recover his date or his data? If the first one, i don't think you want computer guys giving you relationship advice
I wouldn't think it'd be the same connection (2.5" drives i thought were always their own connection) but if it is in fact the same, plug it in and have at it. Can't hurt it that way. If it's not, find a buddy with a laptop and plug it in there and see if it boots up OR order a 2.5" to 3.5" adapter such as:
Notebook Hard Drive to Desktop Adapter (2.5" to 3.5") N/A
and plug it in that way.
If you're going to run it along side your normal hard drive you'll have to make sure the jumper settings are right or set it up as cable select. It may even give you the option to choose during bootup, i'm not sure.
perfectcircle is offline
post #3 of 5 Old 01-07-2010, 11:02 PM Thread Starter
cheepjeep96
1990 XJ Cherokee
Data my friend.
anyways. It appears to have the same Sata connection has my desktop, I just don't know if their is a voltage difference between Laptop harddrives and desktop harddrives
post #4 of 5 Old 01-07-2010, 11:38 PM
perfectcircle
hmm. Idk. My 3.5" drive says
5VDC 0.64A
12VDC 0.24A
and my 2.5" drive:
5VDC 1A
if that helps any..
post #5 of 5 Old 01-07-2010, 11:57 PM Thread Starter
cheepjeep96
1990 XJ Cherokee
Ah. Well, I plugged it in anyways, Works just fine Thanks.
Hey Computer Guys: I have a program that I want to put on another computer... XJMuscle98 General Discussion 9 09-17-2009 09:07 AM
Computer guys.. need some help cheepjeep96 General Discussion 2 09-03-2007 02:52 PM
Question on computer harddrive space jzmtl General Discussion 12 02-18-2007 07:20 AM
For you computer guys! RIOGRANDE General Discussion 4 02-03-2004 01:55 PM
