CLUTCH PROBLEM! HELP!!! - JeepForum.com
post #1 of 9 Old 03-03-2002, 09:56 AM Thread Starter
MusicMaverick
MusicMaverick's Avatar
2014 JK Wrangler
Ok, I got in my car last night, and noticed I had almost no give left in my clutch pedal, I lift the hood, and check the fluid, it was low. I filled it, and today it has lost some again. I looked at everything and it appears that the line running down from the master cylinder right before it goes underneath toward the tranny, there is a connection there changing from one line to a fatter ribbed line, and there is seepage there, my guess is that the line there is bad or connection, any other thoughts? please!!
Currently: '14 JKU
Past vehicles: '92 YJ, '97 TJ, '10 JK
MusicMaverick is offline
post #2 of 9 Old 03-03-2002, 10:40 AM Thread Starter
MusicMaverick
2014 JK Wrangler
Ok, I just looked it all over, I can't find a leak anywhere, but I'm losing fluid, whats up with that?
I followed the hose all the way down the the tranny, it has a small component that I can slide in and out of the bell housing to the tranny easily, what do I do?
Currently: '14 JKU
post #3 of 9 Old 03-03-2002, 08:40 PM
FLHT_FXRS_YJ
FLHT_FXRS_YJ's Avatar
Sounds like the slave cylinder is losing fluid. The slave is what moves the throw-out bearing in and out. If you have access to it, it's an easy fix. Just swap in a new one and bleed it out. If it's in the bellhousing and you can't get to it, then it's a real pain because you have to pull the tranny to get to it.
89' YJ - 4.2 - NV4500 - NP231w/sye - 1" Body Lift - 2 1/2" Rancho Suspension Lift - 31" Firestone MTR - AR Outlaw II - Tomken Bumpers F & R - Warn 8000 front - Warn 6000 rec. mount rear - FlowFit Seats - Tom Woods Rear & Custom 2" front driveshafts
FLHT_FXRS_YJ is offline
post #4 of 9 Old 03-03-2002, 08:54 PM
treedodger
What year is your jeep? Can you see the slave cyl outside the bellhousing or not? It's a little hydraulic piston on the end of the hose, it should have rubber boot on it to keep it shiny clean. Taping some newspapers down to your driveway and inspecting them in the morning for wet spots might help zero in on the location of the leaks. If the clutch master cly goes dry, you might need to bleed the system after filling the reservoir. Pray that you can find a slave cyl located outside the bellhousing.
treedodger is offline
post #5 of 9 Old 03-03-2002, 09:01 PM Thread Starter
MusicMaverick
2014 JK Wrangler
Its a 92' 2.5 YJ.........There is something that looks like a piston before it goes into the bellhousing, I can slide it in and out, I have no idea really.
Currently: '14 JKU
post #6 of 9 Old 03-04-2002, 07:35 PM
FLHT_FXRS_YJ
That would be the slave. When you push in the clutch the piston should push out, releasing the throw-out bearing.
post #7 of 9 Old 03-04-2002, 07:51 PM
JeeperJay
My '92 has a internal slave =( If you have one there will be a line going into the drivers side of the bell housing that has a rather large fitting that could look like a slave cylinder at a quick glance. To know for sure go the the passenger side of the tranny and look on the bell housing for another line coming out that has a bleeder screw at the end of it. If thats the case then you have the dredded internal slave cylinder. My guess is if you've got a '92 with a 4-banger and a AX-5 tranny, you've got the interal slave. Sorry for the bad news
1992 YJ, 2.5L 4-banger, 2" Lift, 31x10.5 BFG Mud Terrain, K&N Filter, Restrictor Removed, Hi-Lift, Custom bumpers, More to come...
JeeperJay is offline
post #8 of 9 Old 03-04-2002, 08:47 PM Thread Starter
MusicMaverick
2014 JK Wrangler
Yeah, I took it to the garage today. This is gonna suck. Labor on pulling the bell housing? thats gonna cost.
Currently: '14 JKU
post #9 of 9 Old 03-04-2002, 09:00 PM
JeeperJay
Ugg..yea that does suck. If your clutch has some miles on it you might as well have that done too while they're in there. I just replaced my tranny about a month ago and I should have replaced the slave while I was in there, I think its starting to act up. Its just a good idea to replace everything you can the first time, to save you from ripping it all apart again. Or paying somebody else to do it
new clutch, no warranty Haik General Discussion 13 05-16-2007 12:20 AM
Clutch problem? Serious while driving! HELP! arbby General Discussion 1 08-06-2006 02:15 PM
so about that clutch!!! MoMuddin General Discussion 4 08-03-2006 11:35 AM
I have (clutch) issues. river rat General Discussion 8 04-11-2005 02:20 AM
transmission or clutch problem toddsacksteder General Discussion 1 05-02-2002 06:19 AM
