Quantcast Christmas tree stands... Grr - JeepForum.com
Go Back JeepForum.com > General > General Discussion > Christmas tree stands... Grr
Old 12-04-2004, 10:57 PM   #1
whitefiesta
Is it just me or is this just the biggest pain in the butt.
Today we went out and got a tree a great big fat 8 footer. i got it in the stand perfectlyand brought it inside without a problem it even stood straight when we cut the rope off it. once the lights were completly on the tree it started to lean.
Now we cant get the tree to sit right in the stand. I Hate X mas Tree Stands
whitefiesta is offline   Reply With Quote
Old 12-04-2004, 11:00 PM   #2
K-Pax
K-Pax's Avatar
do you have the stand with the bolts you turn against the trunk of the tree? if so, they may not be evenly tightened causing the tree to lean toward the bolt that has the shortest length against the trunk. but i'm not sure what your stand looks like or the components.
Graphic Design student at NWACC (Northwest Arkansas Community College).
Kevin's rig:
94 Grand Cherokee Laredo
I-6 4.0L, Quadra-Trac on demand
2" budget lift
pro-comp steelies
kevin's radiator support bar
JKS quick discos
e-mail me
K-Pax is offline   Reply With Quote
Old 12-04-2004, 11:02 PM   #3
War Eagle
BRAAAAIIIIIIIIIIIIIINS!!!
War Eagle's Avatar
I helped a friend pick out a tree today. She was really excited about having a tree, but those little stands are a pain in the ***.
Originally Posted by Keith
JF without War Eagle? That's like a beach without broken glass littered about. I shudder at the thought.
War Eagle is online now   Reply With Quote
Old 12-04-2004, 11:17 PM   #4
BeatAChevy289
Get a massive plactic one. It's like a huge green base of molded plastic that has a hole in the top for the trunk. They span about 1.5ft wide or so and they work good. Uses the same screw technique as the old metal models but holds up oh so much better. Later <><
1995 Firebird Formula, 6-speed, LT1 V8, t-tops, open exhaust. **In the For Sale section***
1966 Ford Mustang, Hi-Po 289 V8, 4:11's, I dare you to race me.
[URL=http://www.cardomain.com/id/blackyj95]Cardomain Site[/URL] (different from the other link)
BeatAChevy289 is offline   Reply With Quote
Old 12-04-2004, 11:18 PM   #5
Flyingbrass
I got the best metal stand that Lowe's had and that fixed my problems. It was $50. Just get a good one.
Flyingbrass is offline   Reply With Quote
Old 12-05-2004, 06:55 PM   #6
Shinner
Best tree stand ever is the one that just has a vertical rod. Drill a hole into the trunk, set the tree on the stand and it's perfect. You can even spin the tree around on the stand and find the best side to point out.
(course it helps if you find a tree farm or stand that does the tree drilling for you. they usually have a drill mounted in a frame that the tree stands on. They hold the tree straight and then drill which helps a load if the tree has a funky trunk).
His : 1992 YJ (Almighty 4 banger)
Hers: 2004 WJ Columbia Edition (4.7HO)
Black Jeep Society - Black Jeep Club V2.0 #37 - Merry Wacko Jeep Club #37 - Metalhead Jeep Club #37 - 2.5L Low Output Jeep Club #37
Shinner is offline   Reply With Quote
Old 12-05-2004, 07:47 PM   #7
Twisted
Did you make sure to hammer the stand on to the trunk so the spikes stick into it? Most people forget, or don't realize there are spikes on the bottom and thats what makes the tree stay up, not the 4 screws.
Some day I am going to design and produce the stand I have in my head. Could make me rich due to it's ease of installation and adjustments. Just haven't done it.
And on a side note I don't want to hear complaining about a single tree. We cut down another 300 this morning, bailed, and loaded onto a truck. All by noon.
[size=1][URL=http://www.twisted-productions.com][B]Twisted Productions[/B] [/URL] - My photography and web design
[U]My vehicles[/U]
97 Cherokee: 4.0, RE Lift, 33" Trxus MT's, Yukon 4.56's, and locked front and rear...
87 Mazda Extra cab p/u: 2.5" body drop and full air ride
99 Honda Civic SI: Electron Blue Pearl - [color=red]Sold[/color][/size]
Twisted is offline   Reply With Quote
Old 12-05-2004, 08:50 PM   #8
whitefiesta
cutting em down isnt the problem i used to do the same thing for work in the freezing cold so i hear ya on that one. but anyway i finally got in in perfectly with the help of my uncle today, It was definatly easier with another hand.
you guys have some great ideas to make my life alot easier next year
Thanks
Old 12-05-2004, 09:42 PM   #9
Tom95YJ
It's Only Rock Rash......
Tom95YJ's Avatar
Screw the Tree this year .................. Its a PITA !!!! having to keep 2 dogs away from it the damn dogs will go lift their leg and pee on it every time they walk past it But they do stayt away from my moms 4ft tall catus ........... Hmmmm that gives me an Idea
'98 TJ Built Sold
'95 YJ Built Sold
'99 XJ 3" on 31's Build Thread
Utah Jeep Crew Member #109
Tom95YJ is offline   Reply With Quote
Old 12-05-2004, 10:52 PM   #10
Blake
Redefining body roll
Blake's Avatar
I've been using the said gigantic plastic on with the huge base. Works great for me.
2005 G35 Sedan
Sport Package | Mostly Stock
1999.5 Ford F250
6.8l V10 l Auto l 4WD l 4" Spring Lift | 4.30 Gears | 35" Treadwright MT/R's
1987 Mercedes 300D Turbo
Stock | European Headlight Conversion!!1!
Blake is offline   Reply With Quote
Glock Forum
