Chevy Truck wont start. Need help. - Page 2 - JeepForum.com
post #16 of 32 Old 12-22-2012, 11:14 AM
turtlerace
Best taken in small doses
turtlerace's Avatar
1979 J-Series Truck
Originally Posted by xtremzj View Post
If he jumped the starter it would bypass all of that.
Depends on where he jumped to.
Miss Amy's sensibilities and the language filter prevent me from telling you what I really think about you.
turtlerace is offline
post #17 of 32 Old 12-22-2012, 11:29 AM
xtremzj
Lol I understand that. When you "jump" something you are skipping over all the stuff to see what works. Sorta like jumping over the stuff. Hence the phrase "jump".
Just hook the jumpers to the batterty then positive and negative to starter. It's really not that hard to understand/do. If the the starter dosent turn over then you have something hooked up wrong, the battery is dead or the starter is crap.
Jesus....It's like explaining this to intern at work.
98 ZJ 5.5in hybrid long arm/35"TSLs/4.7 Golen Stroker/Kevin's front bumper/TrailReady rear/hp30/d44/4.56/oba/dual battery/rocklights/milemarker9k.Way to much to list.
QuirkWorks Sponsored #44 subaru rally car
CHRYSLER CERTIFIED MASTER TECH. PM IF YOU HAVE QUESTIONS.
xtremzj is offline
post #18 of 32 Old 12-22-2012, 11:54 AM Thread Starter
Tylerzap
Well i hooked the + and - to the battery. And then i put the other - where the - battery cable is grounded. Then i hooked the + to the starter on the small post
opposite if the signal wire.
I got a click but no turning over. Charging battery right now.
My 98 XJ "Zap" Build Thread
1988 Jeep Comanche 4x4 Longbed - POS
Tylerzap is offline
post #19 of 32 Old 12-22-2012, 12:45 PM Thread Starter
Tylerzap
So, heres the breakdown of what is happening:
Lights come on
Fan comes on
Nothing happens when key is turned
Fan died when key is turned
Brand new starter
Hooked up correctly
Battery is old but even when being jumped there is no click or anything.
When i hooked up jumpers and i hooked battery up it clicked but didnt start
Im now charging battery.
I know this is Jeepforum but would rather not join another forum. Plus this is the most helpful forum ive ever been on.
Tylerzap is offline
post #20 of 32 Old 12-22-2012, 02:59 PM
Truck633
GO ONE MORE!!
Truck633's Avatar
Look at the plug right into the starter, my 75 K10 did exactly this, where the 12 volt feed wire into the solenoid on the starter had broken, had 12 volts to the wire, it just wasn't making it across the break.
99 percent sure you have the same issue
____________________________________________
You don't need a parachute to skydive... You need a parachute to skydive TWICE!!!
Up here - we go by results, when you preached, people slept. When he flew, people prayed.
Originally Posted by vindicated View Post
It's like dads new mistress. You hate her until you see her boobs.
Originally Posted by ionakana View Post
I bet the new bike riding monkey will pedal a lot faster!
Truck633 is offline
post #21 of 32 Old 12-22-2012, 03:41 PM Thread Starter
Tylerzap
Thank you!! Could you go more in depth on what exacly you are talking about? Im not quite sure what wire you are talking about.
Tylerzap is offline
post #22 of 32 Old 12-22-2012, 04:04 PM
bravobravo
its possible you got a bad starter
^ it made more sense in my head
removed for stirring the pot
bravobravo is offline
post #23 of 32 Old 12-22-2012, 04:06 PM Thread Starter
Tylerzap
It started about 4 months ago with a starter that had been on for 8 months. The starter had been on for a year and so day before yesterday i got a free warranty replacement. So i know the starter is good.
Tylerzap is offline
post #24 of 32 Old 12-22-2012, 04:10 PM
Truck633
GO ONE MORE!!
Truck633's Avatar
trace the "S" wire back with a test light from here... Have a buddy crank it while you poke! My break was right at the terminal!
Truck633 is offline
post #25 of 32 Old 12-22-2012, 04:19 PM Thread Starter
Tylerzap
Thank you! Ok so just test the signal wire all the way up? Will do. But there are 2 problems. This may make me seem stupid.
Ok, the wire runs through a metal tube with some other wires. Do i just test on
either side or pull it out?
And how do i test it, since the wires have the plastic/insulation on it? Just cut a small bit off or???
I feel dumb because i can rebuild a 350 but am not very good with electical stuff.
Tylerzap is offline
post #26 of 32 Old 12-22-2012, 04:47 PM
bravobravo
if it has plastic insulation you could poke through it with a test light but id rather test the ends so moisture doesnt get in the wires and cause more issues later on
post #27 of 32 Old 12-22-2012, 04:52 PM Thread Starter
Tylerzap
So i just use a volt meter right? And how many should it have?
Tylerzap is offline
post #28 of 32 Old 12-22-2012, 07:33 PM Thread Starter
Tylerzap
Ahh i just understood what you ment. I will do that early tomarrow and report back. If it doesnt work i would assume it would have to be the signal wire?
Tylerzap is offline
post #29 of 32 Old 12-23-2012, 10:33 AM
GotJeeps
Ok I'll give you a step by step.
1. Be sure the shift lever is in the park position.
2. Attempt to start engine. If engine doesn't start proceed to step 3. If engine starts skip to step 11.
3. Make sure the battery is charged.
4. Check that the connections on both ends of the battery cables are tight and clean.
5. Attempt to start engine. If it doesn't start proceed to step 6. If engine starts skip to step 11.
6. Check for 12v on the "S" terminal on the starter solenoid while someone else turns the ignition key to the start position. FYI the wire in the original harness should be purple. If 12v is present then you have a issue with your starter. If 12v is not present continue to step 7.
7. Check for 12v at the neutral safety switch while the key is turned to the start position. The switch is located on top of the column down next to the firewall. The top two terminals are for reverse lights. The other set breaks the start circuit when the shifter is not in the park or neutral position. In your case originally there would be a purple wire and a yellow wire on the terminals. When the key is turned to the start position there should be 12v on both the yellow and purple wires. If there is voltage on the yellow wire but not the purple then replace the neutral safety switch. If there is not 12v on either terminal the problem is probably the ignition switch. If you have voltage on both terminals proceed to step 8.
8. Check the connector where the purple wire comes through the firewall. With the key in the start position there should be 12v on both sides of the connector on the purple wire. If not unplug connector and check for corrosion and clean if needed. Be sure the connector plugged together fully and that the terminals fully engaged into the connector housing. Proceed to step 9.
9. Attempt to start engine. If engine doesn't start proceed to step 10. If engine starts skip to step 11.
10. ????? and proceed to step 11.
11. profit
-(O|||||||O)-
GotJeeps is offline
post #30 of 32 Old 12-23-2012, 11:29 AM Thread Starter
Tylerzap
I just jumped the starter and it wouldnt crank but turned over. I poured gas in the carb and turned the key and it fired right up. Youve never seen a fat guy run so fast through the yard screaming and doing flips and stuff. I let it run for a while and then cut it off. Turned the key again and it fired right up. I tried 1 more time and i just got a click. No lights. Moved battery terminals and i heard the buzzer. Clicked again when i tried to start it. I will track down that problem later. Just happy i got it to run and drive some.
Tylerzap is offline
