Chevy Truck wont start. Need help. - JeepForum.com
post #1 of 32 Old 12-21-2012, 02:09 PM Thread Starter
Tylerzap
Sorry for posting in wrong area. Move if needed.
I have a 79' Chevy K20 with 350, TH400, and NP203.
Im asking here because i know alot of yall run chevy 350's ans i need help quick.
Ok, batterys charged, brand new starter, and the lights are coming on the dash. I know i have the started hooked up correctly. I checked and double checked.
But when i turn the key NOTHING happens.
Lights dont dim. Nothing happens. I tried jumping it. Nothing. It was doing this before i replaced starter too.
Please help me. I need to get this thing running soon.
My 98 XJ "Zap" Build Thread
1988 Jeep Comanche 4x4 Longbed - POS
Tylerzap is offline
post #2 of 32 Old 12-21-2012, 05:45 PM
bravobravo
did you replace the cables from the battery to the starter?
how about the ground cable is it contacting bare metal.
is your ifnition in good shape.
^ it made more sense in my head
removed for stirring the pot
bravobravo is offline
post #3 of 32 Old 12-21-2012, 05:50 PM
xtremzj
Sounds like a bad ground.
98 ZJ 5.5in hybrid long arm/35"TSLs/4.7 Golen Stroker/Kevin's front bumper/TrailReady rear/hp30/d44/4.56/oba/dual battery/rocklights/milemarker9k.Way to much to list.
QuirkWorks Sponsored #44 subaru rally car
CHRYSLER CERTIFIED MASTER TECH. PM IF YOU HAVE QUESTIONS.
xtremzj is offline
post #4 of 32 Old 12-21-2012, 08:58 PM
BLarkin
My guess goes to bad ground as well. More specifically, the engine ground. Make sure you got a good, solid ground from engine to chassis. Sometimes, I like to have two or three if I've got the space for it.
BLarkin is offline
post #5 of 32 Old 12-21-2012, 09:24 PM Thread Starter
Tylerzap
So yall think i should replace the battery cables? And how do i check the ignition?
Tylerzap is offline
post #6 of 32 Old 12-21-2012, 09:27 PM
turtlerace
Best taken in small doses
turtlerace's Avatar
1979 J-Series Truck
You can check the battery cables by bypassing them with a set of GOOD jumper cables. You can also use the jumper cables to test the engine ground.
Miss Amy's sensibilities and the language filter prevent me from telling you what I really think about you.
turtlerace is offline
post #7 of 32 Old 12-21-2012, 09:35 PM Thread Starter
Tylerzap
Well around thanksgiving i started messing with the starter and i moved the small signal wire on tbe starter. When i hooked the negative back up, without the key it, started turning over.
Just figured id add that in.
Tylerzap is offline
post #8 of 32 Old 12-21-2012, 09:52 PM Thread Starter
Tylerzap
Well ive been meaning to change out battery cables for a while so ill do that tomarrow.
The positive is corroded some where the terminal bolts on.
So anything else? Or is it narrowed down to cables and ignition? How do i check the ignition??
Any other grounds?
All the lights come on and they do not dim when i turn the key.
Tylerzap is offline
post #9 of 32 Old 12-22-2012, 09:08 AM Thread Starter
Tylerzap
Bump.
And thanks for the help so far!
Tylerzap is offline
post #10 of 32 Old 12-22-2012, 10:13 AM Thread Starter
Tylerzap
I just hooked up the starter to jumper cables. Nothing.
Tylerzap is offline
post #11 of 32 Old 12-22-2012, 10:49 AM
xtremzj
Needs a starter
xtremzj is offline
post #12 of 32 Old 12-22-2012, 11:08 AM Thread Starter
Tylerzap
Originally Posted by xtremzj View Post
Needs a starter
Nope. Starter is fine.
Tylerzap is offline
post #13 of 32 Old 12-22-2012, 11:11 AM
turtlerace
turtlerace's Avatar
1979 J-Series Truck
Does it have a started relay or solenoid?
post #14 of 32 Old 12-22-2012, 11:12 AM
xtremzj
Huh? You jumped the starter and it didn't work. It's eaither th battery, the jumper cables or the starter. Or you hooked em up wrong.
xtremzj is offline
post #15 of 32 Old 12-22-2012, 11:13 AM
xtremzj
If he jumped the starter it would bypass all of that.
xtremzj is offline
