Chevy Guys - JeepForum.com
post #1 of 10 Old 05-27-2014, 09:16 PM Thread Starter
TedderX_
Chevy Guys
I don't know much about it so I've come asking for help.
My neighbor needs help working on his truck. It's a Chevy Silverado 1993 and he needs to replace an "in-tank fuel pump".
What things should I know? Or is it as simple as dropping the tank and replacing the pump?
Thanks fellas.
-Tedder
TedderX_ is offline
post #2 of 10 Old 05-27-2014, 10:09 PM
jnicewan
It might be easier to pull the bed, it doesn't have to come all the way off, just tilted up on drivers side. Loosen right side bed bolts, remove left side bolts and filler neck, check and/or unplug wiring at the back for lights and trailer. Remove items from bed and tailgate to reduce weight and lift bed up with some help, have wood blocks or something to wedge bed up in place.
Pulling the bed can be easier since you don't have to deal with laying on you back, dealing with a long skinny tank of fuel. Plus the fuel line connections can be a PITA from the bottom. I've done them both ways and would only consider dropping the tank with a lift and trans jack for the tank.
jnicewan is offline
post #3 of 10 Old 05-27-2014, 10:54 PM
Hurley91
Just lift the box off. You can use a engine hoist. Or just lift it up with someone else. Make things much easier.
Hurley91 is offline
post #4 of 10 Old 05-27-2014, 11:25 PM Thread Starter
TedderX_
Is it possible with two people?
I don't know how heavy a bed is.
-Tedder
TedderX_ is offline
post #5 of 10 Old 05-28-2014, 10:21 PM
jnicewan
Yes, 2 people can lift one side and then put something underneath to support it up. Generally I like to have 3-4 people for small truck beds and 4-5 for full size when pulling the bed off to take it somewhere
jnicewan is offline
post #6 of 10 Old 05-29-2014, 05:55 AM
Pierre_r
1989 XJ Cherokee
If vehicles do rust where you live removing the bed can be harder then you think.
Chevys from 88 and up uses rivetnuts in the bed and if there is any rust on the bolt the rivetnuts is going to get loose and then they just spins inside the beams under the bed.
When i had to remove the bed from my 82 c20 me and my dad just lifted it up and walked away with it (8ft bed) they are not that heavy.
When we put it back on we were 3, 2 holding up the bed and the third person inside the truck backing it up under the bed.
Jeep Cherokee XJ 4.0 -89
Jeep Cherokee XJ 4.0 -90 (partsjeep)
Jeep Grand Cherokee 5.2 -93
Chevrolet Silverado 2500 6.5TD -94
Chevrolet C20 6.2 -82
Pierre_r is offline
post #7 of 10 Old 05-29-2014, 04:38 PM
Kraxen
I had a 94 Sierra gt that i had to replace the fuel lines on. The truck was beautiful. And i tried lifting the bed and had no luck getting the bolts out. I ended up cutting the tank straps and replaced them with new.
You could cut a section of the bed out to gain access. And if he has a plastic bedliner, just cover it up and call it a day.
92 YJ
95 YJ
Kraxen is offline
post #8 of 10 Old 06-03-2014, 12:00 AM Thread Starter
TedderX_
Thanks for your help guys. We did this today.
We lifted the bed completely. Everything was pretty straight forward. And it fired right up.
Only issue we ran into is initially breaking the bolts. Rust and crud due to the age. But a little PB Blaster did the trick. Also, his receiver was in the way of one of the access holes in the frame, so we had to remove it. And to do that we had to remove the spare.
Otherwise everything went great.
-Tedder
TedderX_ is offline
post #9 of 10 Old 06-03-2014, 01:35 PM
prjohnson
Hey, I saw you & your dad a few months back around Total Wine off Barrett!
prjohnson is offline
post #10 of 10 Old 06-03-2014, 08:44 PM Thread Starter
TedderX_
We were there for the REI.
-Tedder
TedderX_ is offline
