Cherokee towing? - JeepForum.com
post #1 of 5 Old 12-10-2001, 09:41 AM Thread Starter
Matt Johnston
Cherokee towing?
Hello, I am a total newbie to the Jeep world, I come from the land of racecars (mostly rally, imports) The reason I am posting, is I am looking at a 98 Jeep Cherokee sport. The reason I am looking for a truck/suv is because I need something to drive daily, and most importantly tow my racecar. My racecar is about 1600lbs, and the trailer is a double axle, open, wood deck trailer with electric brakes. I am most interested in the cherokee because of my need to drive it daily, seems much more fun than a suburban or something. My question is, with a proper hitch, would the cherokee be able to handle that sort of load? I figured I would come to the source... Thanks in advance..
-matt
Matt Johnston is offline
post #2 of 5 Old 12-10-2001, 02:31 PM
horatio102
A '98 with 4.0L and tow package should be able to tow 5000lbs. I'm not sure if you need the Auto for that or not. Standard towing is 2000, max is 5000.
horatio102 is offline
post #3 of 5 Old 12-10-2001, 02:45 PM
Darko
I would HIGHLY reccomend the cherokee. It would be a exellent daily driver, and it should be able to tow 1600lbs no problem If you are interested in towing, a wrangler wouldn't be reccomended becuase of the short wheelbase they arent reccomended to tow much. If you end up buying that cherokee I wouldnt be surprised if you sell that racecar and put a lift on that cherokee..
Found a 85 CJ7 tub in good shape with
minimal rust. The resto continues....
Darko is offline
post #4 of 5 Old 12-28-2001, 07:43 PM
skimemphis
Yeah, definitely go with the Cherokee, and don't let your wife or anybody talk you out of 4WD - it's a definite advantage in numerous special situations you'll run into, well worth the extra money. Not only does it give extra pulling power when needed but the shift position 4WD-low is great for easing a valuable cargo over rough spots, like the washboard ruts on the access roads to some of the racetracks around here.
skimemphis is offline
post #5 of 5 Old 12-29-2001, 01:35 AM
horatio102
Yeah. Don't let anybody talk you out of 4wd. I towed a friend's motorcycle trailer to an event once and the "pit" area was in some muddy woods, courtesy of a little Washington rain. If I hadn't had 4wd on my Grand Cherokee, I would have been stuck due to the weight of the trailer (big wells-cargo with bikes and tools in it). I was able to pop in 4wd and crawl up the hill. If you're a rally racer, you might need it for recovering your car from the woods. (Been there, done that, with somebody else's car)
grand cherokee towing g-off70 Trailers & Towing 1 06-02-2009 05:57 PM
Cherokee CRD Towing MPG Wobbly Trailers & Towing 3 01-12-2009 07:19 PM
Towing with a '05 4.7L Grand Cherokee? tyfoon Trailers & Towing 2 04-05-2007 06:11 PM
cherokee towing a tj rfe1979 General Discussion 3 08-21-2003 05:56 AM
Towing w/ a '99 Cherokee 5-spd 99 cherokee General Discussion 8 04-15-2002 04:54 PM
