Check Engine Light - JeepForum.com
post #1 of 9 Old 10-15-2012, 04:25 PM Thread Starter
JeepinGirl24
Check Engine Light
How do I reset a check engine light on a 2005 jeep wrangler? I replaced the ambient air sensor temperature (per the diagnostic check) and the check engine light is still on. Should I reset it? Any help would be appreciated!!
JeepinGirl24 is offline
post #2 of 9 Old 10-15-2012, 04:41 PM
vwbuge
disconnect negative battery terminal...wait 5 minutes...reconnect.
2002 Grand Cherokee Limited
4.7 HO
2" BB Rusty's shocks
245/70-17
vwbuge is offline
post #3 of 9 Old 10-15-2012, 06:46 PM Thread Starter
JeepinGirl24
I tried that but the engine light is still on. Not sure what to do. If you have any other suggestions I'm open to hearing them. Thanks for your help!!
post #4 of 9 Old 10-15-2012, 07:10 PM
Hurley91
You need a OBDII scanner to reset it.
Hurley91 is offline
post #5 of 9 Old 10-15-2012, 07:16 PM
AmbuGrl
AmbuGrl's Avatar
If the light is on there is a problem. you can go to a local auto store and they can scan it or you can borrow the scanner and pull the codes.
but, you may have better luck in the TJ forum...
http://www.jeepforum.com/forum/f9/
- HM1(SW/AW)Ret USN Dec 23,1992 to Dec 31, 2012
I drive an XJ, and all of my power windows work :)
2000 Pontiac WS6 - DD
DD (Mine) Sold - 98 XJ Moss Green
(His) - 92 YJ December 2013 YJOTM
Sold - 95 ZJ
Sold - 97 XJ Red
Sold - 98 XJ
USN Jeep Club Hull #36
NAXJA #3700
Originally Posted by RacerX View Post
WTF is Clockspring??? my Jeep has digital clock
AmbuGrl is offline
post #6 of 9 Old 10-15-2012, 07:33 PM Thread Starter
JeepinGirl24
I originally went to an automotive store and they did a diagnostic check and it came back telling me the ambient temp sensor needed to be checked or replaced so that's what I did. But the engine light remains on.... At a loss.
post #7 of 9 Old 10-15-2012, 07:46 PM
sreno0207
2011 KK Liberty
It will reset after a drive cycle, you should of reset it with the scanner. You can also check them yourself, use the search I know this has been covered b4.
sreno0207 is offline
post #8 of 9 Old 10-22-2012, 07:27 PM
laybackman
Bikini Bridge Inspector
laybackman's Avatar
2010 JK Wrangler
Pull + batery cable end off of the + battery post. Ground it out for 30 seconds. That drains the power in the capacitors in the brain that holds the learned memory. Now re-connect the + battery cable to the + post on the battery. Fire it up and take it for a ride. You are now running on factory presets. Your brain will now gather information over the next 50 full cycle starts to compare to each time you drive.
Do you know what was good about the good old days? I wasn't good, And I wasn't old!
Senators and Congressman should wear uniforms like NASCAR drivers so we could identify their corporate sponsors....
laybackman is offline
post #9 of 9 Old 10-22-2012, 07:55 PM
Freestyle713
1994 ZJ
You can also disconnect both terminals and connect them together for like 5 minutes to reset it. But I tried that after I replaced my TPS and it didn't work, then again I'm OBD1. Just wait it out. My CEL eventually went out about a week later.
94 Grand Cherokee 5.2 33in. Federal Couragia M/T's on Procomp Steelies, np231 swap, IRO Hack n Tap SYE, Carolina Driveshaft, 4.5 in. lift, RE front upper/rear lower ca's, RC front lowers, Ironman rear uppers, IRO 4.5 coils in rear, 3.5 and 2" bb (no isolators) in front, Bilstein 5100's, Clayton/JKS adj. track bars, KOR rad support and SS, Magnaflow/Flowmaster exhaust, clear corners, custom light bar w/ Hella 500's
Originally Posted by elcorvino View Post
Yea... It's kind of like the fat chick who lives around the corner. You aren't trying to get caught with her, but you know she'd be a good time.
Originally Posted by ScottD16 View Post
I had a dream my entire family was attacked by a giant polar bear. The crazy part was he attacked us with a giant spoon. Best dream ever.
Freestyle713 is offline
