Cement truck on my driveway - JeepForum.com
post #1 of 21 Old 06-23-2005, 02:01 PM Thread Starter
Quentin
I'm wondering how much weight my asphalt driveway can support. I believe a cement truck weighs about 55,000 pounds loaded. Any ideas if I'm not sure how thick the driveway is? I need a lot of cement in an area that is accessible only through my driveway.
Can it handle it?
Quentin is offline
post #2 of 21 Old 06-23-2005, 02:04 PM
LT1CJ7
LT1CJ7's Avatar
1983 CJ7
Sounds like you need to hire a pump guy, Or chance paying for a new cement driveway after you screw it up with a loaded cement truck.
LT1CJ7 is offline
post #3 of 21 Old 06-23-2005, 02:05 PM
meat12
meat12's Avatar
Alot of variables there; what is the base like under your blacktop driveway, how thick is the blacktop, age of the blacktop. How long is your driveway? Can you put plywood or planks down. Otherwise depending on how far you are from the batching plant have them bring it in two trucks.
91XJ- NP231, 31x10.5 MTR's, 15x8 soft 8's, BB, K&N intake, Cherry bomb exaust, CB, Stereo mods, fog lights, custom Aluminum body work to cover rust.
Rember: If they dont find you handsome, at least they will find you handy!
meat12 is offline
post #4 of 21 Old 06-23-2005, 02:06 PM Thread Starter
Quentin
My driveway is currently asphalt and I'm not planning on changing that...especially not to concrete.
Quentin is offline
post #5 of 21 Old 06-23-2005, 02:08 PM Thread Starter
Quentin
Wish had all of these answers. Driveway is about 20 years old. I believe there is a thick course of class 5 down under the driveway. Thickness of blacktop? not sure. Driveway is very long...about 300 feet.
Quentin is offline
post #6 of 21 Old 06-23-2005, 02:11 PM
meat12
meat12's Avatar
Well that means wheeling it is out. Is it in good shape and wide enough so that the truck will not be to close to the edges. If so, I would say pour it early in the morning before it gets a chance to heat up, keep it away from the edges, maybe some plywood where he is going to dump from. Again depending on yardage, and distance have them bring it in two trucks.
meat12 is offline
post #7 of 21 Old 06-23-2005, 02:15 PM Thread Starter
Quentin
If the driver can keep her down the middle he'd have about 3 feet on each side. It's in good shape other than a few full length splits from side to side that have been sealed up over the years.
Quentin is offline
post #8 of 21 Old 06-23-2005, 02:23 PM
meat12
meat12's Avatar
Ah, you should be ok, it has been dry enough and it sounds like your driveway can take it. What are you pouring?
meat12 is offline
post #9 of 21 Old 06-23-2005, 02:25 PM Thread Starter
Quentin
I'll be pouring footings and a floating slab for two separate garage structures. I've got about 3 acres of land that is domed and accessible only by my driveway. Very private.
Quentin is offline
post #10 of 21 Old 06-23-2005, 02:48 PM
james985
i could pull that cement truck with my jeep and some straps
98 tj
ar23's with 31's
4.10 gears
red jeep club member #283
james985 is offline
post #11 of 21 Old 06-23-2005, 03:01 PM
rowdy1
rowdy1's Avatar
Re:Cement Truck
You could maybe have Robert Stephens standing by with VEX to winch that sucker outta there
rowdy1 02 GC Laredo
rowdy1 is offline
post #12 of 21 Old 06-23-2005, 03:01 PM
Chuck2543
Well if you're concerned with the weight of a truck, and the cost of a pump, they do make an attachment for a Bobcat skid steer loader. Check with your local rental shop and ask for a large capacity skid steer (if bobcat, an S300 would be perfect) and see if they have an attachement called a "Mud Bucket" from Loegering. It's basically a concrete hopper with a small chute on the front, made to be an alternative for wheeling concrete everywhere.
Why am I pitching this to you? My father invented the thing.
1990 Jeep Wrangler YJ
2.5L "four-banger"
4" suspension lift
33" BFG A/T
Reman NP231
Custom Fab Front and rear bumpers.
Chuck2543 is offline
post #13 of 21 Old 06-23-2005, 03:21 PM
Alec
Oh no! ....you didnt
97 Green Sahara -
Powertrain envy sufferer - Softop tinkerer
Alec is offline
post #14 of 21 Old 06-23-2005, 03:27 PM
Chuck2543
Probably carry the concete in his huge coyboy boots and hat.
2.5L "four-banger"
4" suspension lift
33" BFG A/T
Reman NP231
post #15 of 21 Old 06-23-2005, 03:33 PM
Billy Ray
You may have already considered this, but can the truck hop the curb and drive over the lawn/dirt by the driveway?
BR
Billy Ray is offline
basement cement floor paint/water sealer. slafferty General Discussion 7 11-15-2009 04:51 PM
Why is there a board laid into the cement in my garage floor? TheMightyGoat General Discussion 32 07-19-2009 09:43 PM
Any fence contractors or cement guys on here? zbrucec General Discussion 27 10-27-2008 03:02 PM
What to clean oil stain on cement with? H8CMENT General Discussion 22 09-09-2005 02:38 PM
One of each in my driveway. jaybyrd General Discussion 1 02-01-2005 03:16 PM
