car speaker gurus - JeepForum.com
post #1 of 10 Old 04-06-2004, 06:52 PM Thread Starter
Cap'n
Cap'n's Avatar
car speaker gurus
Heres the delima. I have a 77 carpice class and it has am radio and one very small speaker mounted right in the middle of the dash board. I would like to have a more elaborate setup. How hard would it be to put four speakers, one in each corner and maby a woofer in the back? How much do you think this is going to cost if I do it myself? what if I take it to a shop?
cap'n
Cap'n is offline
post #2 of 10 Old 04-06-2004, 07:01 PM
97sahara
not hard at all. decent head--150-200; front and rear speakers (6x9s, 5.24's) under 50/ set. wiring would be easy--- its two wires to each speaker from the head, 12v constant and alt. to the head, antenna, etc. not a bad job.
97sahara is offline
post #3 of 10 Old 04-06-2004, 07:43 PM Thread Starter
Cap'n
Cap'n's Avatar
Thanks, now I kinda have a ballpark of what it will cost.
I'm pretty new to this so could you try to explain this to me. I know with woofers people put in amplifiers.what do these do?(If i'm right then they amplify the voltage and make the speakers produce a louder sound) are these needed one with the ohter speakers? thanks
cap'n
Cap'n is offline
post #4 of 10 Old 04-06-2004, 08:35 PM
97sahara
Amplifiers boost wattage, not voltage---quality, not volume per se (ppl get that mixed up); most head units have a set (under 4.5V preouts for external amplifiers). If you just want decent sound, a standard (I prefer Alpine, myself) head unit will have enough power for 2 soundstages-- front and rear. I'd go with an Alpine 98 series head, boston acoustic 5.25" up front, and Boston 6x9" in back. If you want to add a subwoofer, 150-200watts from a mono alpine amp and kicker or alpine R sub (10" or 12") should be sufficient. I see no need to get a sub unless your crazy about sound. An apline 9813 head will give you 60 watts per channel, and ill tell you, thats plenty for good listening; it also reads mp3 cds. PM me with any more Q's-- I can make a wiring diagram and find you stuff if ya want. Where you located? I do installs....anywho. Good luck
97sahara is offline
post #5 of 10 Old 04-07-2004, 08:33 PM Thread Starter
Cap'n
Cap'n's Avatar
Thanks for the help. So yo saying just one speaker in front and one in back? I figured i'd need more, because most cars have about 7 or so speakers. It would be helpful if you could show me some sites (preferably the same site) where I can find these speakers at. thanks
cap'n
Cap'n is offline
post #6 of 10 Old 04-08-2004, 01:22 AM
kairo
kairo's Avatar
You need to worry more about the front soundstage then the back. An effective audio setup makes it feel like the band is right in front of you. Subwoofers are placed in the rear (and often fired rear) because the lower freq. waves will echo more effectively then higher frequency. If money isn't a concern, then by all means create dynamic front and rear stages. If you aren't too heavy into loud music though, 6" speakers powered by a quality head unit will be just fine. One last thing, do the install yourself! It's very simple to do and will save you a ton of money vs. a shop. Most of those guys are only there to make their paycheck at places like audio express and car-toys. If you want a quality precision install done, you're gonna have to go to a reputable shop....and that's gonna cost you. Feel free to post any questions you may have. I'm sure many people have done audio installs. I did a writeup on my install in my '91 explorer. I'd be glad to help you figure out any questions you have. Good luck!
Was: 1979 CJ-5, 1982 CJ-7, 1995 XJ, 1991 YJ, 2006 KJ, 1979 F-150
Is: 2011 Ram 1500 Hemi & '02 TJ on 35's
kairo is offline
post #7 of 10 Old 04-08-2004, 01:25 AM
kairo
kairo's Avatar
cap'n
www.crutchfield.com
www.pioneerelectronics.com (my favorite head units)
www.explorerforum.com (they have an EXTENSIVE audio forum, one of the best I've seen)
www.bestbuy.com (reasonable prices on mid-range equipment. Look for their specials)
If you want really cheap stuff, check out the ebay seller, "sell2all" I've bought a bunch of stuff from them for friends on a budget, and while its not the best quality, I've never had a problem with products or service.
kairo is offline
post #8 of 10 Old 04-08-2004, 06:11 AM
97sahara
When I talk about a soudnstage and speaker sizes, its generally 2 speakers per, unless you get a component set with a tweeter and midrange seperate.
for your car, id go, like i said with two (2) 5.25" up front, and (2) 6x9" in the back.
97sahara is offline
post #9 of 10 Old 04-08-2004, 01:29 PM
bonehead99
bonehead99's Avatar
Not trying to start a war but amps do put out voltage. The input is DC but about is AC, hook a voltmeter to the speaker out on a amp and you'll read ac voltage. I think if you take ac volts squared divided by ohms it gives you the true output watts. Also look at rms rating and not peak power. RMS is the power that a amp or deck is capable of continously. I like Infinity for highs, but whatever you get go with a 2-way or 3-way speaker. checkout my webpage it has pics of my setup
94 YJ 4.0 HO 3sp Auto, 3" RC Lift, 1" Shackles, 3" BL, 31x10.50, Pacesetter Armor-Coated Header, Homemade Air Intake w/ K&N
bonehead99 is offline
post #10 of 10 Old 04-08-2004, 04:46 PM
97sahara
ya, no doubt, but the power and quality you get from your amp to the speaker is from increased wattage. Increased output voltage is to carry better signal to the processor (amp)
I think we're on the same page.
97sahara is offline
Internet Connection Gurus (or semi-gurus even) HeavyMetal General Discussion 11 09-25-2007 08:24 PM
Any Dsl Gurus Here? 175MM BULLDOG General Discussion 18 03-12-2006 06:49 AM
need help from pc gurus K-Pax General Discussion 29 01-04-2005 10:28 PM
Car speaker gurus (again) Cap'n General Discussion 2 05-02-2004 07:12 PM
