Bump Stops- Rust Problems?! - JeepForum.com
Go Back JeepForum.com > General > General Discussion > Bump Stops- Rust Problems?!
Rough Country Deals at JeepHut.comIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineJeep JK Wrangler 3" Suspension Lift Kits $439.99 deli
Unread 07-07-2001, 06:13 PM   #1
JeepinGirlinFl
When I was putting in my leaf kit, I noticed some wear and tear on the underside of my frame. I have an 87 Wrangler and noticed what I think is called bump stops to be worn. Looks like they are there to prevent the tire from hitting the frame - located right near the shocks. They are about 1 inch wide by 3 inches long - metal piece with rubber on top. Anyone know where I can get another 4 to replace the rusted out ones I have. Thanks!!
87 Wrangler
4.2L I6
2.5 Skyjacker Lift, chrome grill, steel step bumperettes, new bestop trailmax front seats, K&N, Por15'd frame, Por15'd cab with por15 topcoat....whatever is nasty is being removed and restored!
JeepinGirlinFl is offline   Reply With Quote
Unread 07-08-2001, 04:27 PM   #2
damonejeep
Finding the bumpstops are not a problem. Plenty of the jeep parts catalogs have polyurathane bumpstops you can purchase to replace your old and worn out ones.
Your dealership will have them but they are much more expensive and rubber. The after market are better and less expensive.
Good luck.
Andrew
94 4.0L YJ, 31x10.5 ProComp MT's, 3.5" BDS, lockers and 4:56 gears to come!
damonejeep is offline   Reply With Quote
