Brake line fix using compression fittings. - Page 2 - JeepForum.com
post #16 of 16 Old 10-23-2013, 06:58 PM
NYTrailrider
1988 MJ Comanche
Originally Posted by tom88xj View Post
But there will always be members looking for an answer to this issue. That's what archiving is all about.
As I am, right now. I popped a small hole in the send line back near the gas tank. It looks like the line had been rubbing on the tank edge, combined with rust, that presents a hole. But there is a nice clean section that I could cut into, and replace about 3 feet, ending in the proportioning valve. I would cut and flare the lines, and use one fitting to connect and then the male end into the proportioning valve. I believe it will hold until I can get them replaced. I do baby my MJ.
88 Comanche AX15/NP231 swap. Zone 4.5" lift Future-Dana 44s, lockers, 36" tires, 4BT swap
NYTrailrider is offline
Brake line/fitting questions pstack3315 General Discussion 4 09-15-2009 10:52 AM
1998 yz400f has low compression 1990JEEPXJ Outdoor Recreation 12 05-08-2008 02:03 PM
Boat Trailer Brake Line Question LandRover General Discussion 11 05-08-2007 02:19 PM
compression fittings 90lerado General Discussion 7 07-02-2006 10:00 PM
check out this ebay brake line auction... got_4_lo General Discussion 3 03-03-2006 02:27 PM
