Brake line fix using compression fittings. - JeepForum.com
post #1 of 16 Old 09-15-2007, 08:58 AM Thread Starter
glennv
glennv's Avatar
My brake line rusted and was leaking like hell. I went to buy a new line and a union to replace the broken section. The parts store gave me the correct line and a compression fitting to join the new and old sections. The freaking package says do not use on automotive brake systems. WTF. Why would they give this to me?
ANyway, I used it because I need to get the car home. Two questions. Should I replace the fitting with flares and unions and how tight should I have torqued the compression fitting down?
2002 Sport: I6, 4.56 gears, SYE, RE 3.5", 305 BFF MTs.5-spd,d30/d44.
2004 Grand: I6, wife's
1998 XJ: My daily driver. I6
"The Second Amendment is not about duck hunting, and I know I'm not going to make very many friends saying this, but it's about our right, all of our right to be able to protect ourselves from all of you guys up there." - Dr. Suzanna Gratia Hupp, appearing before Representative Charles Schumer's committee hearings on the assault weapons ban
glennv is offline
post #2 of 16 Old 09-15-2007, 09:29 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
replace it asap, probably good enough for an emergency "get it home and figure it out later" fix but if you need to stop quick the pressure likely could pop the line.
ratmonkey is offline
post #3 of 16 Old 09-15-2007, 09:40 AM
edzakory
Brake lines use a double flare. You can get the tool as a loaner from AutoZone. You will also need a tubing cutter. Replace asap.
edzakory is offline
post #4 of 16 Old 12-21-2010, 10:24 AM
tom88xj
Compression fittings would probably be okay...probably. First off, they have to be made of stronger material than the brake line. That means stainless steel not brass! Then they must be properly installed. That's the area which disqualifies them in most state safety inspections because too many auto mechanics MIGHT not tighten or assemble them correctly. It's not that they are total idiots it's just that they lack the knowledge to analyze mechanical devices. That's best left to those with engineering training.
Compression fitting fail catastrophically because the lines aren't inserted fully or the ferule rings aren't compressed to design specs. This results in insufficient area of the line available to support the applied shear stress and the line extrudes out of the fitting. On the other hand, a flare fitting dumps a tensile load across the entire cross-sectional area of the line. So, using a flare fitting, averts the possibility of sudden separation of the union. Even if it should loosen, it will leak down before total failure giving the operator fair notice via the dashboard warning lights. It's idiot proof...to a degree.
As to accident liability, that would be an issue only if the compression fitting was discovered to be a contributory factor. Having a well-working compression fitting found on a vehicle would not imply liability but would subject the owner to a safety violation.
tom88xj is offline
post #5 of 16 Old 12-21-2010, 10:52 AM
gmiller0737
Replace it with a flare type union (Metal line will need to be flared with a "Double Flare Tool")
gmiller0737 is offline
post #6 of 16 Old 12-21-2010, 10:58 AM
bobjp
I think this is a bad idea, and you should replace the entire brake line. If one part of the line was bad, there is a chance that there are other bad parts.
Also, I would not trust a compression fitting from a parts store; especially one that clearly has no faith in its own product. "Don't use on brakes"????? What other reason than for brake lines would a parts store sell a compression fitting? Maybe for a fuel line? That's just as bad of an idea.
Compression fittings are great in high pressure situations as long as they are quality made and rated for the job. The ones you have don't sound like they are.
Do as others have said by buying a complete brake line and renting the flaring tool.
97 TJ sport.
bobjp is offline
post #7 of 16 Old 12-21-2010, 11:06 AM
Indy
Indy's Avatar
x2, it's been a while since I lost control of an angle grinder and had to replace a brake line. But it sure seems like it would a lot easier to swap the line than try and patch it.
I'm the only gay eskimo.
Indy is offline
post #8 of 16 Old 12-21-2010, 11:16 AM
bradthebard
The issue is not the strength of the compression fitting. The issue is the line itself. Particularly on a cut line, the brake fluid will cause corrosion over time. The corrosion decreases the commpressive strength and physical diameter of the line. A compression fitting only retains its strength if the line it is on is absulutely stable. Once corrosion causes the line to weaken it will fail. Not if, when.
It will fail after it has been on there long enough for you to think it is working just fine and forget about it.
Change out the whole line.
2000greenTJ
1954 CJ3B
"...Indeed I have burned the candle at both ends, and it gave off such a glorious light..." - Christopher Hitchens
Originally Posted by bradthebard View Post
Theology is one hundred blind men searching a dark room for a black cat that isn't there.
Originally Posted by schitzangiggles View Post
Atheism is one hundred blind men in a dark room claiming there is no black cat because they can't see it.
bradthebard is offline
post #9 of 16 Old 12-21-2010, 11:17 AM
ecaps
This question usually opens up a can of worms. Most people say NO to compression fitting on brake lines. I would tend to agree if it a brass fitting, which is what most of the auto parts stores sell. You need to get a steel compression fitting for brake line.
I have used the stainless steel fittings on a few occassions where it was just to difficult to run a new line for one reason or another. Napa or a good auto parts store should carry them. Look for part 7305x3 (Eaton Weatherhead). I know of maintenance guys that use them in factories where the pressure is greater than in a vehicles braking system.
Boredom is the desire for desires.
Stays crunchy ......even in milk
ecaps is offline
post #10 of 16 Old 12-21-2010, 11:59 AM
DBLJ
DBLJ's Avatar
Arnt good compression fittings rated to more pressure then the line?
DBLJ is offline
post #11 of 16 Old 12-21-2010, 12:41 PM
MedicJK
2015 JK Wrangler
I think he has it figured out guys. It's been a few years...
Sienna Pearl Coat Club Member #24
/l ,[____],
l---L-OlllllllO-
()_)-()_)-o-)_)
MedicJK is offline
post #12 of 16 Old 12-21-2010, 12:43 PM
bradthebard
It isn't the fitting that is the problem. It is the eventual corrosion of the line causing the fitting to loosen. The fitting will be perfectly intact as it careens down the road hanging by the side of the brake line that did not corrode further, shrink a bit and then let go while you are descending a hill towards a bus full of orphaned infants and puppies.
2000greenTJ
1954 CJ3B
post #13 of 16 Old 12-21-2010, 12:43 PM
bradthebard
dammit.
I hate when that happens.
2000greenTJ
1954 CJ3B
post #14 of 16 Old 12-21-2010, 01:30 PM
kg4kzv
1995 XJ Cherokee
Thats the problem with Compression fittings on brake lines. If it blows off you won't be able to stop for like 4 years unless you run into something first!
Chris
95 Cherokee SE 4.0, 5-Spd, 8.25;
6.5" Rusty's Lift, Atlas II Rims, 35x12.5x15 Wild Country,Rusty's Tube Bumper, Wilderness Rack
Rock Sliders, K&N Panel Air filter, PSC steering box,
I-ROK reinforcement kit, ORO U-TURN steering kit,Conversion Headlights/Silverstars And too much $$$
kg4kzv is offline
post #15 of 16 Old 12-21-2010, 10:47 PM
tom88xj
But there will always be members looking for an answer to this issue. That's what archiving is all about.
tom88xj is offline
Brake line/fitting questions pstack3315 General Discussion 4 09-15-2009 10:52 AM
1998 yz400f has low compression 1990JEEPXJ Outdoor Recreation 12 05-08-2008 02:03 PM
Boat Trailer Brake Line Question LandRover General Discussion 11 05-08-2007 02:19 PM
compression fittings 90lerado General Discussion 7 07-02-2006 10:00 PM
check out this ebay brake line auction... got_4_lo General Discussion 3 03-03-2006 02:27 PM
