Quantcast Is it bad to put Lettuce in the garbage disposal? - JeepForum.com
jeeppartsdept.com
Get your jeep parts here. Full line Jeep dealer. HUGE DISCOUNTS!
Go Back JeepForum.com > General > General Discussion > Is it bad to put Lettuce in the garbage disposal?
GR8TOPS Introduces the Exogate HD Tire CarrierTruck-Lite's New LED Headlamp SeriesRUBICON EXPRESS Lift Kits and Accessories Available at Bas
Old 10-17-2006, 09:36 PM   #1
jkoffroadin
2009 JK Wrangler
My wife put a lot of lettuce down the garbage disposal and now the water keep backing up after running it for a while.
So, is it bad? I didn't think it was but I am thinking otherwise now.
She is sitting dirty....
jkoffroadin is offline   Reply With Quote
Old 10-17-2006, 09:42 PM   #2
woody-77
Vulcan FTW
woody-77's Avatar
2007 FSJ Cherokee
You should never put too much down a garbage disposal....it is made to handle small amounts of food which is rinsed off a dish.
If there is nothing in the disposal and the water is backing up you might have a clogged pipe....it is possible there may just be some lettuce left in the disposal itself. Look in there and see if anything is stuck in the drain hole or something is stuck in the blades that is making it not chop all of the left over food in the disposal.
Gone but not forgotten: '86 CJ7, '06 Wrangler X, '03 Rubicon, '97 Wrangler, '77 CJ5, '74 CJ5(RIP)...gone and forgotten: 07 JK Sahara Unlimited, '78 CJ5
Thread deleted by Jerry Bransford
Reason: This was beyond human decency... posting about someone's girlfriend is ****ed up.
woody-77 is offline   Reply With Quote
Old 10-17-2006, 09:44 PM   #3
mpd8488
How much is a lot? Like an entire head at once? That wasn't such a great idea, but it may just be a little stopped up, you will just have to pull off the drain line and clean it out. After you do that run some ice cubes through it because it will help clean out the inside and sharpen the blades. On second thought do this first, then clean it out.
1997 XJ Sport 4 door
4.0, AX15, NP231
Stock- no $
mpd8488 is offline   Reply With Quote
Old 10-17-2006, 09:51 PM   #4
Futhy
I tried feeding a garbage disposal a corn cob once. It didn't like that very much.
Futhy is offline   Reply With Quote
Old 10-17-2006, 10:35 PM   #5
jkoffroadin
2009 JK Wrangler
Well, she put almost an entire head of lettuce.. what was left over from tocas. I took off the pipes under he sink but there was nothing in there. The disposal is totally clean.
I am wanting to say that it is not a total clog because the water does eventually go down. I say eventually when it only takes maybe 10 minutes. All of the other drains in the house work fine.
Old 10-17-2006, 10:43 PM   #6
mpd8488
It must be something in the drain past the disposal then.
4.0, AX15, NP231
Stock- no $
Old 10-17-2006, 10:44 PM   #7
Dr. Marneaus
Hairy Armgina
Dr. Marneaus's Avatar
1973 FSJ Wagoneer
just boil some water. like, a pot full, then turn on the disposal and pour it down. always cleans ours out.
Andrew - Landscape architect in training. Not landscaper
If guns kill people, then pencils misspell words, cars make people drive drunk, and spoons made Rosie O' Donnell fat!
"One of the best ways to get yourself a reputation as a dangerous citizen these days is to go about repeating the very phrases which our founding fathers used in the great struggle for independence" - Charles Austin Beard
OOoooh, it's a killin' machine! It's got everything! Like a drivin' power, big fat tires, and everything!
- Deep Purple
The Beast Build Thread:Marns '73 Wagoneer Thread ----- Gone but not Forgotten:97 TJs Build Up.
Dr. Marneaus is offline   Reply With Quote
Old 10-17-2006, 11:38 PM   #8
rowdy1
Woody is absolutely right. The disposer is for small stuff,not cleaning out your fridge.
rowdy1 02 GC Laredo
rowdy1 is offline   Reply With Quote
Old 10-17-2006, 11:42 PM   #9
65thTJ
If Jeeps could fly...
65thTJ's Avatar
Drano or liquid plumber. I stock it by the gallon. I don't have a disposal, so when my friends throw food down the sink I get the Drano out...again...
65th Anniversary Jeep Green TJ 6-spd
All stock except for some sweet mastercraft grab handles on all 4-corners...
65thTJ is offline   Reply With Quote
Old 10-17-2006, 11:45 PM   #10
bombadillo
I don't use drano, I use straight bleach. I pour a whole bunch meaning a half gallon or more, and drop it down the drain, Then let it sit for an hour or so. AFter that, run a whole bunch of really hot water through it, and it cleans it out every time.
93 white wrangler, warn rock crawler bumper w/guard, custom rear bumper, warn lights, superlift 3.5" suspension lift, Lift shackles rear, (Soon to be front too) crappy shocks, 32x11.50 BFG MT's on eagle alloy 10 hole wheels, Swaybars and track bars removed. H4 conversion headlights, Hi-Lift ghetto mounted, Header from above ^^ and other goodies.
bombadillo is offline   Reply With Quote
Old 10-17-2006, 11:50 PM   #11
Awshux
Cynical Bastard
Awshux's Avatar
Originally Posted by 'Cause
Another thing not to try is larger bones, arm and legs are the toughest, almost immpossible!! Best to take them out to the Chipper and scaterover the garden...
That reminds me...I gotta go rent Fargo again!
You live and learn. At any rate, you live.
-Douglas Adams
Awshux is offline   Reply With Quote
Old 10-18-2006, 02:51 AM   #12
NEWtoTHEjeepLIF
You may want to teach your wife not to waste so much......
NEWtoTHEjeepLIF is offline   Reply With Quote
Old 10-18-2006, 06:30 AM   #13
Desperado2
Junior Member
Hmm...remind me never to come over to your house!
Desperado2 is offline   Reply With Quote
Old 10-18-2006, 07:21 AM   #14
Rule303
Some people seem to think a disposal is a garbage can. I can never get used to that as we always were on septic and didn't have one.
Rule303 is offline   Reply With Quote
Old 10-18-2006, 09:37 AM   #15
hoosier724
It's ok but you should have put it in in small amounts an by the way since Halloween is coming up soon never put the punkin guts in the garbage disposal, trust me on this one, what a mess!
'03 TJ Sport,Light Tan Metallic,, Superlift 4" with BFG 33x12.5x15
Honk if you love Jesus...text while driving if you want to meet him!
hoosier724 is offline   Reply With Quote
Glock Forum
