Auto Cad help Converting .JPG to .DWG - JeepForum.com
post #1 of 7 Old 01-30-2008, 05:42 AM Thread Starter
micifus
Original GC'er
micifus's Avatar
can you convert a simple .JPG to a .DWG? Our cad system at work is not autoCAD(although I do have autoCAD) but an older CAD program. I need to convert .jpg objects in a AUTOCAD .DWG file so I can convert it into my CAD program which will only reconize text and lines not objects.
- OME Springs - 30"x9.5" Yokohamma's A/T-S -RE Shocks - JKS Quicker Disconnects - FM70 - E-Fan Conversion - 249->242 Swap -
32"x11.5" BFG A/T
4" Lift
"For every one thing I fix two things break"
micifus is offline
post #2 of 7 Old 01-30-2008, 05:53 AM
lawdogg
Not that I know of, but I only use Solidworks' DWG editor. You could probably import it as a layer, then sketch on top of it?
2002 WJ 4.0 - Blue Jeep Club #255 (totalled by drunk driver)
1994 3000GT VR-4 (11.8 @ 116, 17psi, pump gas & street tires)
lawdogg is offline
post #3 of 7 Old 01-30-2008, 08:55 AM
racer32
racer32's Avatar
This should work:
http://www.downloadjunction.com/prod...894/index.html
That took about 4.2 seconds to find on google...:
Click to View Search Results for Google (Search Results) Google (Search Results)
98 SE XJ
4.0L, AW4
RE 6130 w/ 3.5" springs
31x10.50 High Tec OTR Muds
Cragar 397 15x8 4" BS
Terra 2Lo, HD SYE, Bilstein 5150 & 5100s
racer32 is offline
post #4 of 7 Old 01-30-2008, 09:18 AM Thread Starter
micifus
Original GC'er
micifus's Avatar
have you tried it thought? does it really work? I can not download stuff on my work computer. If anyone has this app or wants to give it a try let me know maybe I could send you the files Help a fellow JFer out and help me score some points with the boss.
32"x11.5" BFG A/T
4" Lift
micifus is offline
post #5 of 7 Old 01-30-2008, 09:43 AM
supes82
supes82's Avatar
1994 XJ Cherokee
Its probably not much help because its not what you are looking to do, but typically I just insert the raster image, scale a reference point to get it close to an accurate size, then trace over the image. Its a tedious process, but it does work.
Curtis
TO ALCOHOL! The cause of, and solution to, all of lifes problems!
RED JEEP CLUB MEMBER #395
supes82 is offline
post #6 of 7 Old 01-30-2008, 10:23 AM Thread Starter
micifus
Original GC'er
micifus's Avatar
yeah that is to much work, I dont want to do it in the first place but its going to have to happen at some point. this img2cad looks like a good program www.img2cad.com anyone use it? anyone want to give it a try?
32"x11.5" BFG A/T
4" Lift
micifus is offline
post #7 of 7 Old 01-30-2008, 10:51 AM
Kyoseki
Inconceivable!
Kyoseki's Avatar
SideFX Houdini has a "trace" SOP that will vectorize a raster image, but at 10 grand, it's a bit much for the one function
(there is however a free version that I believe still allows you to save dwg and dxf objects).
Due to lack of interest, tomorrow has been canceled
Kyoseki is offline
Converting an old fridge into a Kegerator RollerHman General Discussion 43 09-04-2009 07:34 AM
Converting music files to mp3 Jeepfan Jeff General Discussion 7 06-26-2007 08:43 PM
Help Converting Quicktime... jdub_cj General Discussion 4 02-16-2006 09:11 AM
Converting the Heathen outerorbiter General Discussion 11 04-08-2005 10:36 AM
