Quantcast Any masonry experts - or construction - JeepForum.com
jeeppartsdept.com
Get your jeep parts here. Full line Jeep dealer. HUGE DISCOUNTS!
Go Back JeepForum.com > General > General Discussion > Any masonry experts - or construction
RUBICON EXPRESS Lift Kits and Accessories Available at BasSpartan Lockers FREE SHIPPING Excellent PricesFree Shipping on TIRES at KrawlOff-Road
Old 03-11-2006, 07:54 PM   #1
Rusty Scupper
This home that I am looking at has a block foundation with 3 of the sides built into a hill. The forth side wood construction and entrance to the home. So the ground slopes down the two sides to the 4th side (exposed side)
The block that is exposed on the sides has some calcification on it. What causes this? Gutters need to be replaced. Is it water from the outside, Heat escaping from the inside?
The home doesn't have carpet on the main level (no basement) so are their water issues? Property disclosure doesn't indicate but who knows if the sellers are honest about water or moisture issues.
I have pictures if anybody is interested in looking at them. Just don't want to get into more than I bargain for. Home inspector looked at them and he said that they are inconclusive. The home needs a lot of work, but I don't want to have to gut it.
Rusty Scupper is offline   Reply With Quote
Old 03-12-2006, 07:06 AM   #2
Invisible
It could be from hard water in the area. I'm no PE but I know someone who basically is. If you want to post some pics I can see what he thinks. But honestly, I would try to find a local structural engineer come look at it. He/she should be able to tell you what, if anything, is wrong with the wall. It could just be from moisture, or it could be damage.
Invisible is offline   Reply With Quote
Old 03-12-2006, 07:59 AM   #3
70boss302
If it is a very light and fluffy white formation, then it's called efflouresance and it is just a chemical reaction that happens w/ masonry. Wash the area w/ a good mix of soap and hot water with a stiff brush. Rinse w/ cold water and you'll be OK. Look for cracks larger than a pencil. They indicate movement and settling and are real concerns.
Muscle cars rule
70boss302 is offline   Reply With Quote
Old 03-12-2006, 11:22 AM   #4
RockWoRM
don't fear the Jeeper
RockWoRM's Avatar
Sounds like that is what could be, also. But the way to eleminate efflouresance is with a 10 - 15% solution of muratic acid in water, then rince off with clean water. Soap if you choose. Light sandblasting in more serious cases is sometimes nessarry.
If the block foundation you speak of is block-lite (very common building material) then it is VERY porous, and is NOT waterproof. If you decide to buy the house, then I would look into some form of waterproofing for the block. Check the inside transition areas where the block wall meets the floor or substructure. Check for wetness or rot. You should get a termite inspection, too.
good luck,
WoRM
'92 YJ, 4.0, 5sp, 8.8 w/ 4.56's locked F&R, Teralow 4-1, HD SYE, BDS 5" SUA lifted on 35 MTR's. PSE front trail cage kit, 1ton TRE flip, 1"shackles, 1"BL, 1" MM. <><
RockWoRM is offline   Reply With Quote
Old 03-12-2006, 06:10 PM   #5
Rusty Scupper
No termites in Wisc.
Waterproofing the block isn't a big deal where it is exposed, but the thought of digging up around the foundation and proofing that doesn't sound like fun. I did check transitions and they seemed dry.
Thanks for the info.
Old 03-12-2006, 07:55 PM   #6
70boss302
If you are concerned about excess moisture, go and drop by right after a heavy rain. Just drop by unannounced. Explain to the owner that you saw the house once and just wanted to take a second look at the bedrooms. Once your in, look all you want. Yes, this is a little sly, but we are talking about a big expense here.
Muscle cars rule
Old 03-12-2006, 08:46 PM   #7
Grape Ape
I'm tired
Grape Ape's Avatar
You can purchase a sealer that can be painted on the inside of the block. As long as the transition from the floor to the block is good the sealer should solve any problems of water leaching through the block.
The Final Salute
EVERYBODY is pro-gun, some just don't know it. When an anti-gun person is in trouble, the first thing they do is call 911 and demand that they send somebody with a gun!
We've idiot proofed the world... now its full of idiots. - Spiritof76
You will truly be the same today as you will be five years from now, except for two things...
...the people you meet and the books you read. Charles E. Jones
Grape Ape is online now   Reply With Quote
Glock Forum
