any concrete experts out there. - JeepForum.com
Go Back JeepForum.com > General > General Discussion > any concrete experts out there.
Travelling with Pets?Amsteel Blue Synthetic Winch line Free ShippingSteering and more from Ruffstuff!
Unread 07-08-2009, 04:44 PM   #1
willyb8
ok i want to have a concrete slab poured in yard for under my new hot tub. is there a chart or something to know how thick it should be for the weight of the hot tub 3000lbs or so. i'm figuring i could dig the hole and maybe put the crushed stone in to save cash. then pay someone to pour crete and put stamp design in.
91 YJ 4.0 HO,
3.5" BDS, 5/8 MORE Booms, 1" BL, MML
AA SYE & CV,
35" Maxxis Bighorn
Smittybilt XRC8 Winch,
8.8 W/Elocker, D30 W/Aussie
Genright tube fenders
willyb8 is offline   Reply With Quote
Unread 07-08-2009, 04:46 PM   #2
Slenny
4 inches thick with rebar or mesh
Slenny is offline   Reply With Quote
Unread 07-08-2009, 05:39 PM   #3
Rob99
You come back...one year!
Rob99's Avatar
Is it going to be just the size of the hot tub? If so, what's the point of stamping/ putting a design on it?
Rob99 is offline   Reply With Quote
Unread 07-08-2009, 05:46 PM   #4
willyb8
no its going to be 8x16 and tub is 7x7.
91 YJ 4.0 HO,
AA SYE & CV,
35" Maxxis Bighorn
Unread 07-08-2009, 06:02 PM   #5
MarkoPo
2005 WK
NOt an expert, but 4 inches is the standard for a garage floor, so it will hold a hot tube no problem.
05 Grand Cherokee Limited 5.7 Hemi
06 pontiac Torrent AWD
96 Grand Cherokee Laredo 4.0 newest edition to the family.
Hemi Club member #2
Bonafide Gun Guru
MarkoPo is offline   Reply With Quote
Unread 07-08-2009, 06:21 PM   #6
sitdwnandhngon
1987 YJ Wrangler
4 inches for a floating slab is fine. Just a word of caution though, if you are getting it stamped be sure to look at the guys other work. Stamped concrete around here gets a bad name because the county/town guys pour red sidewalks and try to stamp it like bricks, and it looks terrible.
It's an art form, from the use of multiple colored release agents to highlights right down to how much to float it before stamping. I have done it for about 5 years and I learn a new trick every time.
My favorite pattern is seamless slate. The pattern is similar to this, but the colors can be anything you want.
I can't bear the thought of losing, I dread the attention winning brings
Originally Posted by northjeep View Post
4.2 has 0.2 more!
sitdwnandhngon is offline   Reply With Quote
Unread 07-08-2009, 06:34 PM   #7
JPete
How 'Bout Dem O's?
JPete's Avatar
4" gravel base, 4" concrete slab with welded wire mesh. Good to go.
Originally Posted by GasAxe View Post
The lesson for today is never steal a Playstation from a Baltimore Samurai.
JPete is offline   Reply With Quote
Unread 07-08-2009, 08:15 PM   #8
willyb8
thanks for all the input
91 YJ 4.0 HO,
AA SYE & CV,
35" Maxxis Bighorn
Unread 07-08-2009, 08:18 PM   #9
xJoshxx
2011 WK
Take the Total holding Capacity x8 water ussally weighs about 8lb/per gal
So If it holds 500 gallons? that's 500x8+weight of pool then peoples better safe and extra thick than to thin and ur pool cracks.
Interested in Amsoil? Sold4" Hybrid lift TeraFlex coils IRO Adjustable LA's Jks tracbar 1.25spidertrax spacers 265/75/16 Dura-tracs
Originally Posted by moPowered View Post
The SRt-8's are a liberty design.
2011 WK2 Laredo with ORA1
xJoshxx is offline   Reply With Quote
Unread 07-08-2009, 08:25 PM   #10
sethco
I dont know if the city you live in has building codes but you should check with them and see what they recommend.
Going to church doesn't make you a Christian any more than standing in your garage makes you a car.
http://zoneoffroad.com/bad-to-the-bone?feat=34
sethco is offline   Reply With Quote
Unread 07-08-2009, 08:33 PM   #11
flhtquick
yea get a permit and ask for trouble
flhtquick is offline   Reply With Quote
Unread 07-09-2009, 06:42 AM   #12
mjrandall
Just get a reputable concrete guy and pay him to do it all. I would imagine the MOST you would save by digging/filling it yourself (stone/rock is $$sky high$$ now) would be a hundred bucks or so--not to mention all of the headaches. You can't beat a man at his own game unless you've done it before and have all the tools/experience to do so.
Jeep: A four-wheel drive vehicle of one-half- to one-and-one-half-ton capacity for reconnaissance or other army duty. A term applied to the bantam-cars, and occasionally to other motor vehicles (U.S.A.) in the Air Corps, the Link Trainer; in the armored forces, the ½-ton command vehicle. Also referred to as "any small plane, helicopter, or gadget."
mjrandall is offline   Reply With Quote
Unread 07-09-2009, 06:58 AM   #13
That1guy
2007 WK
You have to have a good 3-4 inch gravel base for drainge and to support the concrete. They need to be decent sized stones. Being the size it is and the weight you'll want to reinforce it so it doesnt crack apart real quick. Most concrete slabs have whats called welded wire fabric put in for strength. If done right rebar would pprobally be a little over kill. I'd plan on a 3-4 inch thick concrete pour on top of the 3-4 inches of gravel.
I'm forever grateful to Speedycat and RnEmOvr for their generosity
That1guy is offline   Reply With Quote
Unread 07-09-2009, 07:07 AM   #14
2005X
maybe its just around my area but no one puts gravel down first, and no one uses rebar. out of the 6 different concrete guys i called all used like a 6 to 1 mix bag, basically like THAT1GUY said its got the welded fabric already mixed in and the truck comes to pour its ready to go..these pics are 2 years after and still looks as good as day 1
www.youtube.com/kgries
2005X is offline   Reply With Quote
Unread 07-09-2009, 07:27 AM   #15
That1guy
2007 WK
Well I'm a civil engineering student and in my concrete classes they say there should be a gravel base to the slab. Now weither its done or not is a different story. I'd still want a gravel base.
How is the WWF already mixed it? The fabric comes in a big role or in big sheets. I'm not sure how it can be mixed in the concrete. I'm not trying to call you out or nothing. I'm confused on what you're talking about.
