Any AV people? - Page 2 - JeepForum.com
post #16 of 24 Old 12-13-2013, 07:06 PM Thread Starter
JeepComanche89
1989 MJ Comanche
Originally Posted by chowner
Does this 32" dream of a Westinghouse TV have an optical output? I'm assuming the Cable box doesn't since it's non HD.
Does the Cable box have composite(rca) outputs?
Dunno going to check tommrrow. But what does the cable box matter, i thought the soundbar would just connect to the tv?
JeepComanche89 is offline
post #17 of 24 Old 12-13-2013, 07:28 PM
PhilipJ
PhilipJ's Avatar
It can connect to either. Most cable boxes these days should have optical out though, even if it's just a standard-def tuner.
PhilipJ is offline
post #18 of 24 Old 12-13-2013, 08:06 PM Thread Starter
JeepComanche89
1989 MJ Comanche
Which is preferred? I will look tommorrow. Its a standard comcast box, just no hd
post #19 of 24 Old 12-13-2013, 08:20 PM
PhilipJ
PhilipJ's Avatar
It doesn't matter really but probably the cable box, that way you can control everything with one remote (if they have a universal remote.) Pretty sure all of Comcast's standard boxes have optical except for the super tiny space saver one.
PhilipJ is offline
post #20 of 24 Old 12-13-2013, 08:30 PM Thread Starter
JeepComanche89
1989 MJ Comanche
Yeah its not the little tiny box. Looks just like a hd one but black. Ive been reading that some soundbars are programmable to a remote, some come with their own. I would prefer to use the one comcast remote. But are you saying if i hook it up to the box than it will run off that remote no matter what?
post #21 of 24 Old 12-13-2013, 08:35 PM
PhilipJ
PhilipJ's Avatar
Well the box has its own volume output level, so you should be able to control it that way. I only suggest that route because I'm not familiar enough with the TV to know if it can support external speakers directly and/or control the volume of them independently of its own speakers.
PhilipJ is offline
post #22 of 24 Old 12-13-2013, 08:37 PM
chowner
2014 WK
Well if the TV doesn't have any sound output, you are going to have to get the audio into the sound bar somehow...............
chowner is offline
post #23 of 24 Old 12-13-2013, 08:46 PM Thread Starter
JeepComanche89
1989 MJ Comanche
I gotcha makes sense. Im not sure myself but ill check tommorrow to see if it even has an output. The box sounds like the way to go though, because i would like to use only one remote.
post #24 of 24 Old 12-17-2013, 09:47 AM Thread Starter
JeepComanche89
1989 MJ Comanche
Just found this today. I like it because it is only 27 inches and theres limited space. It has the external sub that can fit behind the tv out of view. It sounded nice in the store. What do you guys think? Should i be afraid of phillips? Target was swamped with people so i couldent get anyone to help me, and i had to go back to class. Im going back after this class though, really thinking of buying it. Should this be the same set up as the other lg one? Either rca plugs or an optical? I totally forgot to look at the tv yesterday, but from what i can tell from online it only has rca cables. I want to hook it up to use only the comcast remote as well.
http://m.target.com/p/philips-soundb...f/-/A-14491216
